I HAVE SIX WIRES COLORS ARE RED, WHITE, BLUE, ORANGE, YELLOW, GREEN, OFF-WHITE. I NEED HELP WIRING A HUNTER BRAND, DIGITAL THERMOSTAT. MY A/C PUMP WILL NOT WORK MY HEAT WORKED BACK IN THE WINTER BUT MY A/C WILL NOT WORK I MUST HAVE MY WIRES HOOKED UP WRONG SO WHAT CAN I DO.
  • 43,501 Answers
Here is a tip that I wrote that will help you with wiring you thermostat... Thermostat Wiring and Terminal Designations
http://www.fixya.com/support/r3623083-thermostat_wiring_terminal_designations
heatman101
Posted on May 28, 2010
Testimonial: "i got it i can wire it up thank you sir and have a great holiday."
Need help installing a Hunter 44277 thermostat. Instruction manual here: http://www.hunterfan.com/Support/Manuals-and-Parts-Guides/ Wires I have are as follows: Blue: C Black: E White: W2 Yellow:...
Your wires Hunter thermostat
Blue C
White E
Black E
Yellow Y
Orange O
Red R
Green G
Since i don't know what brand heat pump you have, i am assuming you have a cool active reversing valve, therefore the orange wire will connect to the "O" terminal. If you have a heat active reversing valve the orange wire would be connected to the "B" terminal. You will know it is wrong when you turn on the system in cooling mode and it blows hot or warm air. Another way to know quickly is to go out to your outside unit when you turn it on in the cooling mode and feel of the suction line(the large copper line coming out of your condensing unit) and see if it is cool. If it is, great. If it is hot then you would have to switch the orange wire to the "B" terminal.
Hope this helps.
Sep 04, 2011 | Heating & Cooling
I am replacing a White-Rodgers thermostat with a Hunter 44155C and dont know where to connect the wires. I have white, red, green, blue, and yellow wires and none are labeled as to what they are.
The Yellow wire is for cooling, the white is for heating, the red is for power, the green is for blower fan, the blue is your common wire, all you should have to do is color code the wires to the thermostat. The thermostat should have the colors labeled R,W1,G,Y,B or C for common if it's wired correctly at the Air Handler or evaporator. The blue wire should go to B, or C.
May 28, 2011 | Hunter Fan Company 5/1/1 Programmable...
I bought a Hunter 44155C programmable thermostat to replace my Carrier non-programmable one. The wiring on the carrier is: W- white wire O- no wire G- green wire R- red wire C- blue wire Y- yellow...
Hello,You need RH/RCjumper together=red wire...C=blue wire...G=green wire...Y=yellow wire...W=white wire...O/B unused for reversing valve for heat pump.Hope that helps. : )
Nov 10, 2010 | Hunter Heating & Cooling
Carrier 6 wire, installed programmable hunter ther...
Is this a heat pump? Look in the thermostat. You should have something like the following.
Red wire to R terminal
Green wire to G terminal
Yellow wire to Y terminal
White wire to W or W1
Blue or Orange wire to the O or B terminal
Brown wire to C terminal.
Let me know what you have in the thermostat. The wire colors are not always the same.
May 21, 2010 | Carrier 38BRC048 Air Conditioner
Switching old thermostat to Hunter thermostat model 44155c
By describing the wires from your new thermostat and your old one, it sounds like your new thermostat is not compatible with your system. If you have seven wires now, then you more than likely have a heat pump system and you have to get a thermostat that is compatible with this type of system. Then you will have the connections you need.
Jul 11, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44100A programmable thermostat
Yes you will need the orange (o) wire for the reversing valve in your heat pump. T-stat color code is red (r) for 24v power from transformer. Blue (x or c) is the common or the other 24v power from transformer and this will power your programmable t-stat. Orange is for the reversing valve that will switch your heat pump from cooling and heating. Green (g) controls your inside blower. Yellow (y) brings on your outside unit. White is your backup heat.
Sep 28, 2008 | Heating & Cooling
Hunter 44155c wiring from manual thermostat
I have a manual thermostat with the following wire connections (Y, G, R, O, C, & E) with the respective wires attached (yellow, green, red, orange, blue, white). My 44260 has available G, Rc, Rh, Y/O, W/B, Y1. Which wires should I connect to which terminals on the 44160. Thanks.
Jun 19, 2008 | Hunter Fan Company 5/1/1 Programmable...
Changing thermostat matching wires trouble
Brown my friend is for the 4 way valve solenoid, that is if you have a heat pump, ( it uses freon for heating instead of natural gas) perhaps you got the wrong thermostat, if you have a brown you need a thermostat for a heat pump, a regular thermostat is not going to have a brown connection.
May 08, 2008 | Heating & Cooling
Need help !!
have you tried there web site for the wireing instructions or manual to installing it.
Programmable thermostats at discount prices at
hunter-thermostats.com.
riz.
Feb 17, 2008 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
202 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
