Question about Sony VPL-EX5 Projector
Projector and help with Sony VPL-EX5 ... the lamp/cover light is blinking even though the lamp/cover is off, wath is happening
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Posted on Feb 02, 2008
SOURCE: sony vpl cx5 no voltage to lamp
I downloaded the schematics and drawings for $US9.00 and found what I thought may have been a thermistor turned out to be a fuse. Obtained one from Sony spares and it is now OK. If it is possible would you guys know the value of the fuse [amp/milliamps??] If you are familar it is fuse 2P connected to C board, it looks like a small lump of plastic or diode block. The cost of the fuse is outragous from Sony. I hope I do not have to replace it again. However, if I do I would love the valua and I could see if I could get one from Radio shack or someplace similar. If I was not retired I would buy one and put it on a step tranny and watch the ampmeter for the blow current. But, thats life when you decide to retire. I believe the voltage value is 3volts??
Would appreciate any feed-back on the value of the fuse.
And I hope this may help others
Thanks and Good-day
Leckie
Posted on Mar 01, 2008
Marrie
  • 563 Answers
SOURCE: Sony VPL-CS1 projector
Hi there
You should first check if there is any visible damage on your lamp. If not then it could be a faulty Ballast ( lamp powersupply )
Posted on Mar 26, 2008
  • 4234 Answers
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
Posted on Apr 09, 2009
welcomejee
  • 10594 Answers
SOURCE: how to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
Posted on Jun 01, 2009
Picture not projecting from RGB input A of my Sony projector Model Number VPL-EX5. What could be the problem
First...Check that all cables are connected correctly..If they are then look at the condition of the cables you're using to see that they are not damaged..Second..Your projector has a lamp that may need to be replaced because even though your unit may not show you a picture then seeing the light will eliminate having to replace the bulb
Nov 05, 2016 | Sony Office Equipment & Supplies
Green light is continuesly bling but the projector is not given the display
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Dec 11, 2014 | Sony VPL-BW5, VPL-ES5, VPL-EW5, VPL-EX5,...
How to removed Lamp/cover error of Sony VPL-EX5 projector?
Take the lamp cover back off. Check the mechanism that the projector uses to sense the door. It might be a small pressure switch. Check whatever triggers the mechanisms is still attached to the door and hasn't broken off.
Sep 15, 2014 | Sony VPL-EX5 Projector
Sony ex5 rgb not working
replace the LCD panels (USD220)
Have a good day!
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 25, 2014 | Sony VPL-EX5 Projector
Sony projector vpl ex5 yellow display problem
try replacing the bul/lamp.
warning! $200 part http://www.amazon.com/Projector-LMP-E190-VPL-ES5-VPL-EX5-VPL-EX50/dp/B003ISW2KM
May 21, 2011 | Sony VPL-EX5 Projector
Lamp/cover lite is blinking and projector can't start
Remove the lamp and reseat it carefully, following the instructions in the user manual.
If this doesn't help you may find that you need a new lamp.. if you are in the UK you can purchase a Sony VPL-EX5 Lamp here or from here if you are in the USA
Feb 14, 2011 | Sony VPL-EX5 Projector
Sony VPL-CX61 lamp/cover blink. Power on, it
hi,
your projectors lamp cover may be open. or there is some thing happened (may be contact problem) with the lamp cover open sensing switch. just open the door and close it. and then try again.
ok
Dec 20, 2010 | Sony VPL-CX61 LCD Projector
Frequency out of range on one VPL-EX5, but no
change the resolution to 800x600 and if it works raise the resolution step by step
Oct 28, 2009 | Sony VPL-EX5 Projector
Need asistent
my sony vpl ex3 will not light up, has a lamp/cover light on all the time can somebody help
Jun 21, 2008 | Sony VPL-EX1 Multimedia Projector
Sony CS5 Wont turn on
the cover switch is probably not fully made.
Ensure that the cover tangs are pushing the pin
on the miniswitches.
Try putting slight pressure on the fan or lamp cover to see if the lamp/cover light
stops flashing.
you will need to do a restart on the PJ to check this out
Jan 15, 2008 | Sony VPL CS5 Multimedia Projector
Sony VPL-EX5 Projector Logo
209 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
