Buy a new shredder. At $19.95, this likely is not something you can keep running indefinitely. Part support seems non-existent and the website the label on the shredder says to contact (www.championshredder.com) does not work. I tried looking for blades for the MQ60B, but seems best to just go for a reputable brand that offers support if needed.
Mine now just has the same problem. On mine it was because two of the cutting blades have become bent. It still shreds, but not as fast. You have to turn it on for a split second to see all the blades. You can only see about 1/4 of the blades at a time.
There is nothing you can do. And because my blades are bent it does't dispose of paper properly and also will not turn off automatically now.
My champion shredder runs very slow and gets hot. It is a WQ120 D.
Please help
want shut off after shredding paper
Axus Champion Cross Cut Shredder MQ60B. It cuts/comes on and off except 2 facing roller blades are out of shape and shredded paper is getting stuck in those blades. Is there anyway I can fix it? May be replace those blades or move them to on end and stop using that side. Any help appreciated. Thanks!
My champion shredder runs hard when it runs and gets hot also.It is a WQ120D.Can you help?
