Cannot open G drive of hard disk , when trying asking for format
  • Adnan Bhatti
    Adnan Bhatti May 28, 2010
    If you don't have any data on it then go ahead and format it.
  • vaddisaru May 30, 2010
    I stored important data and personal files...how to retrive them
    Master:
  • 645 Answers
Maybe the data is corrupt. Try formatting it and u will be able to use it.
Posted on May 29, 2010
Seagate raw drive
Your data is already gone. The drive is raw. No partition no format.
here is a link to a free data recovery program, this probably wont work but may be worth a try
http://getdataback-data-recovery-for-ntfs.soft32.com/free-download/?lp=dsa&tg=us&kw=_cat%3Asoft32.com&mt=b&ad=35354358678&pl=&ds=s&gclid=CIa78aSmk74CFc5ffgod9gEAlA
just be sure to opt out of all garbage they want to infest your computer with.
Jun 05, 2013 | Seagate U6 (ST340810A) 40 GB Hard Drive
My hard drive is asking to format how can i retrieve my data
Save what data you can to a different hard drive then format the unit . When finished reinstall the data from the drive to which you save the data
Feb 25, 2013 | Samsung Computers & Internet
Reformat unmountable flash drive on mac?
Instructions
    • 1
      Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
    • 2
      Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
      • 3
        Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
      • 4
        Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs. If you have questions about the formats, refer to the Apple user's manual.
      • 5
        Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
      • 6
        Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
    May 27, 2012 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
    I purchased a Toshiba Canvio 3.0 500 GB portable hard drive, and plugged it into my MacBook with Mac OS X Tiger. The icon for Toshiba EXT came up on the desktop but wouldn't do anything. The box came...
    1 . Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
    2. Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
    3.
    4. Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs.
  1. 5. Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
  2. 6. Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
    Aug 30, 2011 | Toshiba Canvio 500 GB USB 20 Portable...
    Mac G5, what is pin set up. my computer doesn't see my new hard disq WD1002FAEX
    If it is not seeing it then you will need to format it properly for Mac's most hard Drives are pre-formatted for PC's.
    You also need to make sure the SATA cable is plugged into the right place on the board.
    SATA Hard Drives do not need a pin out. Only IDE drive's have that function.
    If this is an addon drive then
  3. Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
  4. Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
  5. Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs. If you have questions about the formats, refer to the Apple user's manual.
  6. Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
  7. Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
  8. I got these instructions off ehow.com
    Jul 02, 2011 | Western Digital WD Caviar Black WD1002FAEX...
    Hai i have transcand stor get 320GB hard disk. my propblem my computer detect the hard disk but when i try to open that it asks "do you want format it?" what shoud i do?.
    If the computer is prompting that the drive needs to be formatted, this means either the drive has become currupt (not likely) or that the drive hasn't been formatted or is an unrecognised format
    if the hard drive was formatted on a Mac or Linux machine without choose Fat32 format, the drive will be prompted to be formatted under a windows machine
    if there is no information on that drive, i'd suggest just formatting it
    remember formatting a hard drive removes all information off that hard drive.
    May 12, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
    How do I format my new WD Elements SE 500GB for Mac OS Snow Leopard
    hi.
    follow instructions below
    1> Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
    2> Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
    3> Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
    4> Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs. If you have questions about the formats, refer to the Apple user's manual.
    5> Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
    6> Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
    regards
    Apr 23, 2011 | Western Digital Wd Elements Se 1tb...
    Wont let me open or format the device when i try to open it ask to format but when try to format it says it is write protected
    TRY GOING TO ADMINISTRATIVE TOOLS, COMPUTER MANAGEMENT, UNDER STORAGE CLICK DISK MANAGEMENT. WAIT A FEW SECONDS, THEN ENLARGE THE PAGE, LOOK FOR THE DRIVE, THEN RIGHT CLICK THE DRIVE AND SEE IF THERE IS AN OPTION TO MARK THE PARTITION AS ACTIVE.......OR SEE IF YOU CAN FORMAT FROM THERE AS WELL...............USUALLY NTFS. HOPE THIS HELPS..........JEFFXC
    Feb 07, 2011 | Kingston Technologies 512MB DataTraveler I...
    Seagate 750GB usb HDD asks to format,when opening by double click
    The disk is either damaged or the USB interface is damaged.
    1) You could try opening the external case and connect the disk to your computer directly (Using IDE/S-ATA cables)
    2) Format the HD and use data recovery software/service.
    May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
    Hai..my transcend 256 mb pen drive is not opening
    Hi the problem u are facing right now in ur pen drive is due to virus infection in ur pen drive. Whenever u insert ur pen drive to a pc it will ask for this"Disk is not formeted & do u want to format it" option.. To solve this problem format ur pen drive by right clicking and selecting format option or scan ur pen drive with updated version of antivirus...
    thank u
    Jan 26, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
    Computers & Internet Logo
    137 people viewed this question
    David Payne
    David Payne
