Question about Gestetner - DSm660 Digital Imaging System Copier
Copier my ricoh 5560c is showing a sc412, sc 416 , sc413 what are those any tech I brought in they do not know what it is
  • airalan8 Jun 06, 2010
    Now all the errors are gone but the toner is light I have tried to the toner fill and it still is not working
  • 903 Answers
SC412, 413, and 416 are development errors for cyan and yellow. If you open up the front door, there is a release lever (I believe it's blue) located on the right side under the far right development unit. (The lever has a squarish handle.) Make sure this lever is vertical with the handle facing upward.
If that lever is not the problem, you may have toner density issues and you should have a service technician (one who knows what they are doing) look at the machine, but most likely if you reset that lever the problem will go away.
Hope that helps!
Posted on Jun 05, 2010
  • gggg Jun 06, 2010
    All of the colors are light, or just one or two? If it's all of the colors, did you check that lever to make sure it's set correctly? If it's just some of the colors, it may need new developer.
WHY RICOH AFICIO MP 171 SPF IS SHOWING SERVICE CALL SC 542.
Reseting SC 543 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Oct 18, 2016 | Ricoh Office Equipment & Supplies
Problem Ricoh CL 7200 error SC 542
fuser assy replace it and reset code or have tech come out and fix it
Jul 19, 2013 | Ricoh CL-7200 High Yield Toner Refill Kit...
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
I am getting SC412 on my Ricoh Aficio 1224C, how do I fix it, and what is it?
sc412 on a 1224 is 2nd transfer (paper transfer) disconnection (+).
The possible causes are:
- The right cover is open
- The transfer roller contact mechanism is broken
- A bad high voltage supply board
- A bad BICU-to-HVSB cable
Parts for the 1224 will be obsolete soon if they are not already, so you're probably better off upgrading to a newer copier if closing that right cover and resetting the machine doesn't fix it.
May 18, 2010 | Ricoh Aficio CL7000 Laser Printer
Ricoh 1045 showing code SC545. First was SC 546 and now SC 545 can somebody help?
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
Jan 26, 2010 | Ricoh Aficio 1035 Copier
Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Jun 09, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio 1515mf SC 121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Apr 29, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Sc 326 -322
What is your make and model of the copier....If it a Ricoh or Savin or Aficio... You Have First and Second Laser Sinc Issues. and probably will continue to have these arrors. I may be able to help if I know your Make and Model. I am a Trained Ricoh Tech
Apr 04, 2009 | Office Equipment & Supplies
Gestetner - DSm660 Digital Imaging System Copier Logo
657 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
