Question about Scotsman Ice Maker CM3 30inW Cubed Ice Machine 900LB
My cme306 says bin is full. but theres no ice
3 Suggested Answers
SOURCE: scotsman EC 105 - Bin full!
change the sensor ................
Posted on May 14, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: where are the bin full sensors located for
It is a set of eyes located in the very back right and left hand side where the ice drops into the bin. Take some ice machine cleaner and wipe down the eyes. You should be able to pull the holders out to get to them better.
Posted on Feb 09, 2010
Bin light on no ice water running bin warm
Check the ice-full probe if bad replace this is what tells machine that the ice bin is full. the bin is not refrigerated just a storage bin.
Jan 20, 2014 | Franklin Industries Franklin Chef Ice Cube...
Where are the bin full sensors located for cme256ws-1c full light on will not make ice
The bin full sensors are located behind the water sump tray. Pull the front cover off remove the white plastic guard. Remove the ice deflector grate that is in the water sump tray. Now look where the ice falls down into the bin to the right and left side there is where the bin sensors are you have to pull them sideways you can also open the control panel and look where the bin sensor wire runs and follow it. pull the bin sensors and clean the eyes or replace them.
Jan 03, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Ice machine will not work. bin full light will not go out! Please help!
there are lens on the bin that shoot a beam across if there is ice it stops the beam and tells it's full. It can also become covered with calcuim and also tells the bin it is full. I would clean these lens gently with a cacium remover. they make products for this. its like an acid that clean off the calcium without damaging your lens.
May 17, 2011 | Scotsman Ice Maker 600LB CM3 30inW...
Jenn-air ice maker, stand alone unit, will not shut off, keeps producting ice.
There should be a sensor inside the ice maker bin that tells the ice maker when its full. It may be a wire or an arm on top of the ice. If you accidentally knocked that off the ice maker won't know when the bin is full and just keeps making ice
Jul 07, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ice maker overfill
The metal off/on arm may be disconnected. A full bin should keep the arm in the up position and shut off the ice maker.
Remove, then re-insert the metal arm in the back of the ice maker control head.
Make sure that a full bin of ice activates the control arm.
You may need to buy a replacement arm that is longer so that the ice catches on the arm.
May 20, 2009 | Jenn-Air JCD2295KES Stainless Steel
Ice maker won't stop making ice
OK, there's two possible issues but you have to figure out what is happening. Does the ice maker continue to make ice forever and would fill up the whole freezer section in time OR does the ice maker just "over make" ice that overfills the bin which then falls out? If the ice maker just keeps making ice you need the motor module replaced but if it can be turned off by moving the lever up then you need the "modified lever assy." that is on our service bulletins.
Dec 23, 2006 | Kenmore 55693 Side by Side Refrigerator
Kitchen Appliances - Others Logo
51 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
