Question about Dewalt 18 Volt Compact Drill Kit
How do I realign the bit grips? One of the three has moved forward 3/16".
  • 2,176 Answers
You cant the chuch needs to be replaced.
Posted on May 31, 2010
How do I change the blades in a Benchmark Utility Knife that has a rubber grip and there is no screw to get it apart.
The knife does not come apart. Push the top button (blade) all the way forward and keep pushing forward now press the side button . Being careful with sharp blade pull the blade forward gently. It may need to wiggle a bit but it will come out. Insert new blade while pressing side button. goodluck
May 04, 2013 | Tools & Hardware - Others
Tip
How to stop silverado truck seat moveing back and forth
This is for the person that don't want to remove seat for repair. If electric motor adjust the seat where you want it to stay and unplug seat motor push seat forward to take out the slack and take a small pair of vise grips and clamp on the seat track. This will stop the seat moving back and forward. Save $$
on Apr 12, 2014 | Cars & Trucks
How to fix the bit
If your Makita matches the one on the picture, you will need a chuck key to attach a drill bit or tool to the machine's chuck. The chuck key inserts to any of the small holes in the front part of the chuck and at the same time its teeth interlocks with the teeth of the chuck. When turning the chuck key you will widen or loosen the grip of the three jaw pieces, that clamps to your tool or bit. Tighten the chuck key by hand until the chuck grips the bit securely. For safety, unplug the power cord whenever operating the chuck key on the chuck.
Jan 09, 2011 | Makita & 1/2 Inch Drill
Unable to grip the bit on the drill
If I understand this correctly, you are trying to have the chuck bite down on a bit. If the chuck does not tighten on the bit, your chuck is bad.
Jan 17, 2010 | Electrical Supplies
Can't take off front off porter cable tiger 747 (rubber boot
Remove 2 screws from under front grip and the swivel foot should slide forward and out (might need a bit of a twist to loosen) plastic grip should now slide forward and off.
Dec 07, 2009 | Porter Cable Variable Speed All-Purpose...
Someone stuck a conventional driver bit into the impact driver and it is stuck tight.
VERY GENTLY. . . . use a flat tip screw driver to try to push the collar forward so that it will release the bit. You may need to gently hold the handle of the impacter in a table vice or something like that to steady the tool, then push forward on the collar with a screwdriver and use a pair of pliers to pull outward on the bit at the same time.
Or instead of a screwdriver try vicegrips that are adjusted loose enough to just lock but not squeeze when closed. Pliers that grip too tightly may bend the collar and keep it from being able to slide forward to release bits.
Dec 03, 2009 | Ryobi 18v Variable Speed Impact Driver...
I replaced the color wheele in my Samsung HLN617W and when I got it put back together the picture was not centered in the screen The TV is a 61" DLP and it is a samsung.
When you replaced the color wheel it sounds like you took the DMD board out or you bumped it? Either way the DMD board will need to be realigned and that involves reaching into the TV while it is in normal operation. The DMD board in the one sitting right behind the digital bard and has a small fan facing the heat sink on it. There are three screws 2 on the left side on one on the lower right that need to be loosened just a bit and then with the set on you will have to move the board back and forth to achieve dead center. Remember from the back moving the board to the left moves the picture to the right and pushing down on that board will shift the picture upwards.
Oct 14, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Black & Decker Quattro, drill, won't tighten to grip drill bit.
give a good coating of oil then clamp chuck in a bench vice or alike and using short bursts with it set in the forward direction to free the chuck
Jul 07, 2009 | Hand Tools
The lever to move the driver's seat forward and backward doesn't
The reason is that your sliding grips have been slipped and therefore jammed at one position.
Remove the seat open it's sliding grips and replace it.
Jan 28, 2009 | 2002 Nissan Pathfinder
1996 Volvo 960, Driver's motorized seat stuck
maybe you got pennies money stuck in the track if not you got 1 motor for that the motor goes in a assembly in there you have 2 cable a left and a right lock under the seat you probably got the right cale disconnect sometime there stuff that push under the seat and push that cable off if its that just push the cable back in let me know and please if you can take the time to rate this thank you pierre
p.s when you try to put the cable back in dont force to mush
PIERRE
Jun 29, 2008 | 1996 Volvo 960
Dewalt 18 Volt Compact Drill Kit Logo
103 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
