Question about Sharp EL-2630PII Calculator
Paper jammed in my Sharp calculator
The paper feed became crooked and a piece of it is lodged in the it and I cannot get it out. Is there a way to take it apart to get to the paper?
3 Suggested Answers
SOURCE: Paper Stuck in Printing Calculator
Maybe the commenter should get a life and do something else besides trolling sites like this sniping at people trying to do real work.
We came here to see if someone had solved the problem...sure, we're smart enough to buy a new one, but why throw out something that can be fixed for a few minutes time or a few dollars investment.
My problem ended up being a small piece of paper caught in the paper path...working paper through it several times cleared the issue. Hope that helps someone.
Posted on Apr 20, 2010
SharpCSR
  • 11 Answers
SOURCE: Where do I feed my paper into the Sharp El-1801P calculator
Hello, my name is Curtis, I am a Sharp Customer Servicer Rep. Normally the calculator would have a thin slot on the back, where you would feed the paper through, then once you press the paper in till it hits an inner wall, you would press the feed key which is on the upper left side of the calculator. If there are any problems doing this please call our technical support line at 1-800-237-4277, I am very glad to hear you like the calculator though!!!
Posted on Jun 30, 2009
How do I clear a paper jam in my Sharp EL-2630PIII adding machine?
My paper is stuck and jammed in the feeder. I cant add new paper because of the jam. The new paper crinkles up as it feeds. Is there a way to remove the jam of paper that's stuck inside ?
Jun 13, 2014 | Sharp EL-2630P Calculator
Tip
My X2250 will not feed the single sheet of paper evenly. When looking at the...
Printer would not feed paper no matter how many sheets were in the bin or how clean the printer. I even cleaned the roller. The issue was I just needed a little more tension on the roller that pulled the paper in.
I removed the rear access door (see manual). Off to the left near the feeder roller you will see a spring. What I did is mover the spring to the END of the plastic arm that it is attached to (if it is missing ..you have a bigger problem). If you have moved your printer around a bit, the spring may have slipped down on to the arm and is no longer sitting at the end. This will extend the spring another 1/16 of an inch ...and that is all all it took for me. My printer will now feed a single sheet of paper with no issues. BTW: I put a drop of glue on it after so it would not slip off.
on Sep 28, 2008 | HP PSC 1610 All-In-One InkJet Printer
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    Kodak all in one printer taking in paper crooked and jamming every time!
    look for a piece of paper blocking the path.
    or a feed roller that's crooked.
    something is catching the paper and making it go crooked.
    Mar 29, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
    Paper jam, but no jam + paper feed problem
    check to make sure there aren't little pieces of paper jammed at the ends of the roller. if you can pop out the roller easily you may find tiny pieces of paper still lodged in there
    Dec 29, 2009 | Office Equipment & Supplies
    Paper i feeding wrong, it starts then backs up a
    Generally whenever paper goes "crooked" it's because something is partially obstructing the paper path.
    It could be a small piece of plastic, or paper from a previous jam that tore off and stuck.
    I would suggest looking at the paper path (use a flashlight) to see if there are any obstructions and then carefully remove any found.
    I've also seen where the side plastic has become broken, or has a sharp edge sticking out that will cause the paper to misalign.
    Hope this helps!
    Sep 01, 2009 | Epson Office Equipment & Supplies
    My Dell AIO Photo 926 Printer feeds the paper crooked and jams then says to load paper even though there is paper in it. How do I fix this problem?
    Try cleaning the paper feed rollers with a cloth dampened with alcohol. Also check for a piece of paper that may be stuck at the place where the paper goes crooked.
    Jul 25, 2009 | Office Equipment & Supplies
    Papaerjam lite stays on, no paper jam
    It is possible that there may still be a small piece of paper blocking or lodged in the exit sensor area. It is also possible that when removing the jammed paper that the sensor arm became dislodged and thus creating a false jam code.
    Jun 25, 2008 | Sharp AL-1641CS All-In-One Laser Printer
    Paper not moving forward
    please confirm that nothing droped inside in your printer (pins-stapler-small pieces of torn paper)-double a piece of paper roll and try to insert it while you press paper feed button to remove any object in paper path- apply light grease in gears and test your calculator.if the problem exist pass it to service center.
    Sep 18, 2007 | Sharp EL-2630P Calculator
    Sharp EL-2630PII Calculator Logo
    195 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    k24674
    CheckitRight
    CheckitRight
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
