Question about Reliance & 50gal Electric Water Heater
What tool do i use to get the element out
My plumbing wrench cannot get a grip on it as it is recessed in the housing
  • Reliance Master
  • 43,501 Answers
Thios tip tells how to replace the element and has a picture of the tool that you need to replace that hot water heating element...
How to replace the Thermostat and Element for Electric Hot Water Heater
http://www.fixya.com/support/r4656414-replace_thermostat_element_electric_hot
heatman101
Posted on May 28, 2010
How do I test the heating elements on Bosch Powerstar AE125 with multimeter
Product manual shows electro-mechanical thermal cutout page 9 but offers no troubleshoot steps except to say that overheating is cause.
http://waterheatertimer.org/pdf/Bosch-AE115-AE125_manual.pdf
http://www.bosch-climate.us/files/201009211859150.EP-23_Removing_and_replacing_element_assembly.pdf
Test elements:
Remove both wires off element.
Set multimeter to read ohms.
Watt and volt rating appear on side of each element.
Ohm = Volts squared divided by wattage.
For example:
Assume 240Volt circuit (240 Volts squared = 57600)
Assume 9000 watt element > check side of element for rating.
So 57600 divided by 9000 watt element = 6.4 ohms
http://waterheatertimer.org/images/ohm-reading-for-emements.jpg
Have you de-limed this unit?
Is there a check valve causing closed system in the plumbing, that might also cause decreased water flow?
Are there reduced-flow faucets or clogged aerators?
What happens when suspect cut-out element is no longer connected? The unit should continue heating.
Sep 25, 2012 | Bosch PowerStar AE125 AE125 Whole House...
Our little gourmet dual hot/cold faucet has just started to gurgle out hot steaming water all day without use. The complete faucet is burning hot. Unit is 4 years old and used frequently.
having hot water trickle out all day will make the whole unit hot,, to the touch,, what you need to do , is turn off both the water supplys under the sink,, then remove the handle by removing the hold down screw,, after that , remove the hot water valve,, Just remove the nut that's on the outside of the fixture, what your going to find is at the end of that valve, is a washer,, made of hard rubber,, that needs replacing,, but also, inside of the fixture is a washer seat, its either brass or stainless steel,, that takes a seat tool wrench to remove that ,, but to make sure its repaired completely, both the washer and seat need to be replaced, seat tools are pretty inexpensive at Lowes , or Home depot,, and thats where you can get the parts you need also,, be sure and compare the old parts with the new, so take them with you when you go, most hardware stores that have plumbing supplies will have what you need, the seat just unscrews , but they can be a little tough,, if you decide to get a seat tool, they have straight ones and 90 degree ones ,, the straight ones you'll need a wrench to assist turning in the removal and install,
Aug 26, 2011 | Mountain Plumbing Products Little Gourmet...
Ge smartwater wholehouse waterfilter main housing failed flooded house
Why did it fail? How did it fail? Was it the plumbing that failed? Replace it with a Pentair filter housing, 10" housing, 20" housing or Big Blue housing and make sure it is plumbed in properly. It is very unusual for a filter housing to fail unless it freezes up.
RJ
Apr 18, 2011 | General Electric GE SmartWater Household...
The center heating element is no working. How much does a replacement element cost?
the price will vary in different localities.
you should call a plumbing wholsaler in your area. Home depot and Lowes will not carry these, neither will you local hardware store.
the replacement is faily simple. Eemax is a nice heater, although faily expensive to opperate.
Aug 20, 2010 | Eemax EX280T2T Series 3 Whole House...
Hi i have a reliance 808 electric water heater. I need a part number for the lower element it appears to be shorting out. I had to disconect because of sparks on the red wire going to the lower element
Check out the upper element and on the side of it should be the same number for the bottom element.
If not write information down and model number along with name and go to a plumbing supply house or Lowes,Home Depoet for a new element.
Aug 08, 2010 | Reliance & 50gal Electric Water Heater
Suddenly stopped heating water
Check the top thermostat2_bing.gif... right above it is a red button that you will have push hard on to reset...
If all that checks out then you have a bad top element...replace that...
heatman101
Apr 12, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
What size socket to remove element on electric water heater
most of electric element is 1 1/2" socket. No need to hire pro , at www.bangslush.com they sell the element socket for only $ 14.95 with free shipping. The socket is especially engineer for 1 1/2" water heater elements, the socket not like other, the elements is snug fit for easy removal and replacement. it also snap on onto the socket the element will not fall off the socket
Mar 19, 2010 | American Standard Water Heaters
How do u remove the lower thermistat from model #E2F40LD045V
you need to purchase an element wrench from a hardware or plumbing outfit, power down unit,remove 2 wires off element and use wrench to loosen element and turn out and reverse to replace
Oct 05, 2009 | Water Heaters
Reliance & 50gal Electric Water Heater  Logo
57 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
