Question about Maytag Neptune MDE6800A Electric Dryer
NO power I plug the dryer in and get nothing at the control panel. There is power at the black wire at the control panel, power at the blue wire at the motor, all the thermal cutoffs and thermistors are good and the door switch is good. I am thinking the control board is fried? Am I right.
  • jandvshavers May 28, 2010
    Tested all of the thermal cutoffs and the thermostats with an ohm meter all checked good. If there is a fuse I cannot find it.
    Problem Solver:
  • 4 Answers
My first question is how do you know that things you mentioned are good? You will need to disconnect the wires and test them disconnected with a voltmeter. Not to mention one of these will be a fuse. Those go out ALL of the time.I would hire someone to look at everything unless you are willing and able to take apart the dryer and confident with testing the parts.
Posted on May 28, 2010
How do I pair a three wire source to a four wire outlet for my electric dryer?
The difference between the 4 wire plug and the power source wire is that the plug has and additional seperate ground wire. Basically ttwo legs, a neutral and a ground. Your power source wire only has the two legs and the neutral (the white) which used to act as a ground. Notice that the white (neutral) is hooked up to the ground bar along with the grounds in the panel box. The "correct" thing to do is replace the wire from the panel box with the correct size/amperage wire.
Nov 29, 2014 | Dryers
Tip
Whirlpool Dryer Various Test Procedures - Part 1
TEST #1 Supply Connections
This test should only be done after confirming proper voltage at the outlet.
1. Unplug dryer or disconnect power.
2. Remove the cover plate from the back of the dryer.
3. Check that the power cord is firmly connected to the dryer’s wire harness.
4. Access the machine control electronics without disconnecting any wiring to the control board.
5. With an ohmmeter, check for continuity between the neutral (N) terminal of the plug and P8-3 (white wire) on the machine control board. If there is continuity, go to step 6. If there is no continuity, disconnect the white wire of the harness from the power cord. Test the continuity of the power cord neutral wire . If an open circuit is found,
replace the power cord. Otherwise, go to step 6.
6. In a similar way, check the continuity between the L1 terminal of the plug and P9- 2 (black wire) on the control board. If there is continuity, go to step 8. If there is no continuity, check the continuity of the power cord for power cord’s L1 wire. If an open circuit is found, replace the power cord. Otherwise, go to step 7.
7. Replace the main harness.
8. Visually check that the P5 connector is inserted all the way into the machine control electronics.
9. Visually check that the user interface assembly is properly inserted into the front console.
10. If both visual checks pass, replace the user interface assembly.
11. Plug in dryer or reconnect power.
12. Perform the Console Buttons and Indicators Diagnostic test to verify repair.
13. If indicators still do not light, the machine control electronics has failed: Unplug dryer or disconnect power.
Replace the machine control electronics. Plug in dryer or reconnect power. Perform the Console Buttons and Indicators Diagnostic test to verify repair.
TEST #2 Machine Control Power Check
This test is used to determine if power is present at the machine control electronics.
NOTE: The drum light is controlled by the machine control on all models.
2. Open the door.If the drum light illuminates, then power is present at the machine control, and it is functional. Go to TEST #6. If the drum light fails to illuminate, do not assume the machine control electronics needs replacement. Several conditions may cause the drum light not to illuminate, including a bad bulb. If the drum light does not illuminate, go to TEST #1.
TEST #3 Drive Motor Circuit
This test will check the wiring to the motor and the motor itself. The following items are part of this motor system:
Harness/connection Belt/belt switch Drive motor Centrifugal switch Door switch Machine control electronics
2. Access the machine control electronics and measure the resistance across P8-4 and P9-1.
If resistance across P8-4 and P9-1 is in the range of 1 to 6 ohms, replace the machine control electronics.
Otherwise, go to step 3.
3. Check the wiring and components in the path between these measurement points by referring to the appropriate wiring diagram and strip circuit in Section 7.
4. Check the belt switch and drive motor. Access the belt switch and drive motor by removing the front panel/drum assembly. Slowly remove the drum belt from the spring-loaded belt switch tension pulley, gently letting the belt pulley down.
5. Remove the white connector from the drive motor switch.
6. Check for the resistance values of the motor’s Main and Start winding coils. NOTE: Main and Start winding coils must be checked at the motor.WINDING RESISTANCE ω CONTACT POINTS OF MEASUREMENT
MAIN 1.4–2.6 Blue wire in back at pin 4 and bare copper wire on pin 5 of black drive motor switch
START 1.4–2.8 Blue wire in back at pin 4 and bare copper wire on pin 3 of black drive motor switch. If the resistance at the motor is correct, there is an open circuit between the motor and machine control electronics.
Check for failed belt switch. If the Start winding resistance is much greater than 4 ohms, replace the motor.
7. Check the belt switch by measuring resistance between the two blue wires while pushing up the belt switch tension pulley.If the resistance reading goes from infinity to a few ohms as pulley arm closes the switch, belt switch is OK. If not, replace the belt switch. If belt switch is OK and there is still an open circuit, check and repair the wiring harness.
8. Door switch problems can be uncovered in the Door Switch Diagnostic Test; however, if this was not done, the following can be done without applying power to the dryer. Connect an ohmmeter across P8-3 (neutral, white wire) and P8-4 (door, tan wire).With the door properly closed, the ohmmeter should indicate a closed circuit
(0–2 ohms). If not, replace the door switch assembly.
on Apr 11, 2009 | Whirlpool LER4634J Electric Dryer
I have a LG DLE0 442W dryer. I am getting power to the control panel but when I push the power button nothing happens.
Check this website for the correct wiring procedure:
http://electrical.about.com/od/appliances/ht/wirea4prongoutlet.htm
Mar 10, 2014 | LG DLE0442W 7.3 Cu. Ft. Electric Dryer -...
LG DLE0442W won't start
It sounds like the control PC board has been damaged.
Mar 10, 2014 | LG DLE2301 Electric Dryer
Dryer will not start
If you manually turn on timer can you hear the faint ticking? #1Verify breaker is not tripped. #2 Unplug dryer. Remove back cover. On many makes there are 2 blue wires that connect to a white and black "fuse" towards the bottom of the unit. Unplug both wires and electical tape them together. plug in dryer and start the cycle. If it works, unplug and go buy the fuse. Clean lint out of air system from dryer to lint screen through exhaust.
Jan 09, 2014 | Dryers
I have a Maytag Dryer model # MDE5806AYW Quiet Series 200 today we had to replace the belt but we took the top panel off the dryer including the control panel and disconnected the wires but now i forgot...
http://www.apwagner.com/large_image_viewer.php?image=images/diagrams/00191/i385263.GIF
Here is the link to the wiring diagram for your dryer, I'm assuming you are looking for the wires as they connect to the incoming power cord? They appear to be the only ones with that specific wire color code.
Hope this helps!
Jul 13, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I am converting a 3 prong dryer to a 4 prong plug. The wires inside the dryer are black/yellow, white and blue. The wires on the plug are white, black, red and green. I am assuming the green is the ground...
on plug white is neutral, black is power , red is power, green is ground. black/yellow and blue are power and white is always neutral ie. (white to white) black to black/yellow, blue to red. green to grounding screw on machine
Jan 04, 2009 | Estate TEDX640JQ Electric Dryer
Roper electric dryer
go back to timer ck continuity with timer in any run postion from black to blue wire (i think..better ck wiring diagram under console..you're looking for the contacts in timer to make that control motor)
Sep 01, 2008 | Roper REX4634KQ Electric Dryer
Maytag Neptune MDE6800A Electric Dryer Logo
51 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
