Question about Intel Computers & Internet
USB not working under Windows
My device manager shows no usb option. System information file also shows empty usb section. However, usb option is coming under BIOS. I have tried activating, deactivating usb and usb legacy from BIOS, no good. Any resolution?
    Master:
  • 645 Answers
Try resetting BIOS and also check whether the Plug and Play service is activated.
Posted on May 29, 2010
Windows run doesn't keep my work history
you have to physically save any work
save the history to a usb drive in case you have computer failure
Plug the flash drive into your computer's rectangular-shaped USB drive.
Wait for Windows to recognize the system.
Windows operating systems use "plug and play" technology, which means that computer peripherals like USB flash drives can be recognized instantly by the system without further need for device configuration.
Open the drive on your computer.
Open the "My Computer" directory if using Windows XP or the "Computer" directory if using
Windows 7 or Vista. Locate the flash drive letter and icon under the section named "Devices with Removable Storage." Double-click the flash drive icon to open it.
Transfer files to the flash drive.
Click the "Restore" button in the top-right corner of the "Computer" or "My Computer" directory to shrink the window so that you can view your computer's desktop background.
Open the folders or locations of the files which you want to save to the flash drive.
Click and drag with your mouse each of the files and folders you want to save to the flash drive over to the empty space in the "My Computer" or "Computer" window.
Release the mouse button to let the files "drop."
Close the windows and directory locations when finished.
Save files directly onto the flash drive. From an open file (i.e. text, spreadsheet, image files. etc.), click the "File" menu and "Save as" option.
Select the "My Computer" or "Computer" directory in the drop-down menu at the top of the "Save As" box. Double-click the flash drive letter under the "Devices with Removable Storage" section.
Click the "Save" button to save the file onto the flash drive.
Close the windows and files when finished
hope this helps
Oct 17, 2012 | Microsoft Windows XP Professional Full...
Transcend usb v30 2gb not working .. usb recognised..?
Try connecting USB drive on some other systems if it is being detected by them there is something wrong in your system else the usb drive is damaged.
When you attach the usb drive, after that right click on my computer icon and click Manage option. After that under Manage console select Disk Management, look for removable drives (that is your usb drive) under it and then format it. It will be formatted. If that also does not work then probably some of the windows files is corrupted and you need to either repair your windows or reinstall it.
Thanks !!
Nov 18, 2010 | Computers & Internet
Ive downloaded the driver from the jasco website and still after i anstall it the cam doesnt work. how do i get it to work?
Once the drivers are installed you should either see the web cam show up in "My computer" or in Control panel under scanners and cameras.
If it is not showing up in either of these locations, check your device manager.
On windows XP, go to Control panel, system, select the "hardware" tab and select device manager.
On windows vista or Windows 7, simply go to control panel and select Device manager.
In the device manager, you want to look under the "imaging devices" section to see if your web cam shows up there.
If it has a yellow ? or ! then you want to try and update the driver.
If it does not show up in device manager at all then try a different USB port.
Mar 25, 2010 | GE EasyCam Pro Webcam
TARGUS High Sped USB Memory Card Reader/Writer failure...
1. Go to Start>> Right click My Computer>> Manage>> Device Manager 2. Expand the USB Controller section 3. Right click and Uninstall all of the listed USB devices 4. Reboot the system
Feb 27, 2010 | Electronics - Others
In vista , when i plug usb message display usb can't recognize
Method 1: Use Device Manager to scan for hardware changes loadTOCNode(2, 'resolution'); Use Device Manager to scan for hardware changes. After your computer scans for hardware changes, it might recognize the USB device that is connected to the USB port so that you can use the device.
To scan for hardware changes, follow these steps:
  1. Click Start, and then click Run.
    Note If you are running Windows Vista, click Start, and then use the Start Search box.
  2. Type devmgmt.msc, and then click OK. Device Manager opens.
  3. In Device Manager, click your computer so that it is highlighted.
  4. Click Action, and then click Scan for hardware changes.
  5. Check the USB device to see whether it is working.
If scanning for hardware changes fixed the problem, you are finished. If this method did not fix the problem, go to Method 2. uparrow.gifBack to the top Method 2: Restart the computer loadTOCNode(2, 'resolution'); If scanning for new hardware did not fix the problem, try restarting the computer. After the computer has restarted, check the USB device to see whether it is working.
If restarting the computer fixed the problem, you are finished. If this method did not fix the problem, go to Method 3. uparrow.gifBack to the top Method 3: Disable and re-enable the USB controller loadTOCNode(2, 'resolution'); Use Device Manager to disable and re-enable all the USB controllers. This lets the controllers recover the USB port from its unresponsive condition. The USB controllers represent the USB ports in Device Manager. If you are not comfortable with advanced troubleshooting, try the steps in the "Workaround" section.
To disable and re-enable the USB controllers, follow these steps:
  3. Expand Universal Serial Bus controllers.
    Note You might have to scroll down the list to find this item.
  4. Right-click the first USB controller under Universal Serial Bus controllers, and then click Uninstall to remove it.
  5. Repeat step 4 for each USB controller that is listed under Universal Serial Bus controllers.
  6. Restart the computer. After the computer starts, Windows will automatically scan for hardware changes and reinstall all the USB controllers that you uninstalled.
  7. Check the USB device to see whether it is working.
If the USB port recognizes the device and if you can use the device, you are finished.
If this method fixed the problem, you are finished. If this method did not fix the problem, go to the "Workaround" section.
Aug 25, 2009 | Microsoft Windows Vista Ultimate Edition
I don't have driver of pen drive in windows 98
Let's check your Windows 98 Version first :)
  • Right click on My Computer and select Properties
  • On the System Properties page that opens up click on the General tab, if it is not already on that page.
  • Under the System heading, look for the version number (see right)
    • Version 4.10.1998 is the original version of Windows 98 (98FE)
    • Version 4.10.2222 is Windows 98 Second Edition (98SE)
  • Click the link below for the download and installation instructions for your version of Windows 98
Fo Windows 98 FE:
  1. Download and install the Windows 98 Service Pack (35.5Mb)
  2. Download to your desktop the driver file from the Download section below
  3. Remove ALL drivers for USB flash drives in Device Manager (Optional)
  4. Remove ALL drivers for any USB 2.0 controllers (many have an uninstall option) (Optional)
  5. Remove ALL unknown devices from Device Manager
  6. Run the exe file you downloaded, and follow the instructions, rebooting after installation
  7. When the computer boots up again, it may detect new USB 2.0 controllers, in which case you may need to reboot again
The drivers can be downloaded from the following link:
Windows 98 FE Generic USB Mass Storage Device Drivers v3.20
For Windows 98SE:
  1. Download the exe file to the desktop
  2. Remove ALL drivers for USB flash drives in Device Manager
  3. Remove ALL drivers for any USB 2.0 controllers (many have an uninstall option)
  4. Remove ALL unknown devices from Device Manager
  5. Run the exe file you downloaded, and follow the instructions, rebooting after installation
  6. When the computer boots up again, it may detect new USB 2.0 controllers, in which case you may need to reboot again
Windows 98 SE Generic USB Mass Storage Device Drivers v3.3
For detail explanation, please visit http://www.technical-assistance.co.uk.
It's help for me :)
Thanks
AkulahPathub
Mar 13, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
All my usb ports are not working when i connect any pen drives or external hard disk or bluetooth deice my computer doesn't read them what should i do?
Plese make sure that your USB port is enabled in BIOS Mode,
if it is enabled make this steps....
Download USB Driver files....
usbehci.sys
usbport.sys
usbhub.sys
usbui.dll
usbccgp.sys
usbohci.sys
Feb 20, 2009 | Microsoft Windows XP Professional With...
Pls help me man
CAUSE loadTOCNode(1, 'cause'); During initialization, devices are reset too soon after they are powered on. In this situation, some devices may use the wrong connector.
Solution:
Power Management system can sometimes cause issues. follow these instructions:
Right-click on My Computer/Properties/Hardware Tab/Device Manager. Now look for the Universal Serial Bus controllers tree....then expand it. You should see a number of USB Root Hub insertions. Right-click one of them/properties/Power Management. Take the check out of the box labeled "Allow the computer to turn off this device to save power".
If you still get "Usb device not recognized" in Windows and the above solution doesn't work for you, there might be other causes:
A) USB device worked before but suddenly stopped working:
The following solution might be applicable:
1) Remove all oem*.inf files
1. Click start and click run then under the run line type in the command “cmd” (without the quotation marks)
2. In the command line, type in the following (without the quotes) and press enter after each command:
“cd \windows\inf”
“ren infcache.1 *.old”
“ren oem*.inf *.old”
“del C:\windows\setupapi.log”
2) Removing all entries under HKEY_LOCAL_MACHINE/Enum/USB that start with VID ==
Removing the VID entries from the registry will cause them to be redetected at restart.
CAUTION: If you have a USB keyboard or mouse, do not remove the VID entry for these devices, otherwise, Windows may not restart correctly.
1. Click Start and click Run. Type regedit and click OK. The Registry Editor window will open.
2. Go to HKEY_LOCAL_MACHINE\System\CurrentControlSet\Enum\USB.
3. Highlight and delete all the VID_…. entries.
Permissions may be set allowing the deletion of the VID_ entries by following the steps below:
a)Right-click the key to be deleted, and then click Permissions. The VID_… Permissions window will open.
b)With Everyone highlighted in the Group or User name section, select Full Control in the Permissions section.
c)Click Apply, and then click OK.
4. Turn off the computer.
Reconnect the USB device to the computer system: ==
1. With the computer system turned off, reconnect the USB hub to the the USB port.
2.Restart the computer.
3.A New Hardware Detected window should open and reload the drivers.
low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not
dilipbagdi
Apr 18, 2008 | Computers & Internet
Serial adapter need driver for xp
no need to install serial adapter it is built in for windows xp. but if you want to connect other devices using serial connection you need to install the driver e.g printer, modem etc.
Apr 17, 2008 | Computers & Internet
Computers & Internet Logo
110 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
