Question about GPS
Turns on and then immediately turns off. not holding a charge
  • 973 Answers
Your battery could be dead.
Posted on May 28, 2010
Porsche 928 starting problem, battery related. My car needs to be jump started after I turn it off at each stop. It jump starts immediately and runs fine. The battery says its charging on the voltmeter on...
Your battery probably isn't holding enough of a charge. I bet if you get a new battery your problem will go away. Alternatively, it could be that your starter is going bad and you need the extra power to get it going, but my guess is the battery.
Sep 30, 2013 | 1988 Porsche 928
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Feb 16, 2012 | Gateway MD7818u Notebook
I have charged the player for the first time, when the battery was full I tried to turn it on....The display shows HOLD and then immediately the screen shows POWER OFF....Cannot turn this on ...
turn the hold switch off at the side if its still doing it then re set it switch the hold to on then of and hold down the menu button untill it re starts
best of luck
merry christmas
Dec 22, 2010 | Sony Walkman NWZ-B142 MP3 Player
96 SportTrac, started fine drove it and when I stepped on the brake the battery light came on and the truck died, tried starting the explorer it will try to turn over but will not start any ideas
Sounds like the immediate problem is getting the battery up to full charge and/or having it's condition checked, it may need to be replaced. It may be worn out and unable to hold a charge. Then a check of the charging system to verify the alternator is charging the battery. If the charging system isn't working properly it will just drain the battery again. Also take a look at the belt turning the alternator and connections. Ans as always use proper safety precautions when working with the battery. Do you know how old the battery is?
Jan 20, 2010 | 1996 Ford Explorer
Flip Mino won't turn on!
I had the same problem. Here are the steps I took to fix it.
1. Adjust the power options on your laptop to ensure it does not sleep/hiberate ever.
2. Reset the camcorder by inserting a paperclip into the hole in the tripod mount. Hold the paperclip in there for about seven seconds.
3. Then immediately plug the flip into the cpu.
4. You may not see anything besides the little blinking white light on the USB arm for a while (about 30 minutes maybe) but leave it in.
5. Eventually it should spring to life and show the recharging battery on the little screen (the Flip Share program may start too.)
6. Leave it charging until the little white light stops flashing - full charge about 3 hours.
7. You can then remove the flip and change the power settings back to normal.
Feb 03, 2009 | Pure Digital Flip Video Ultra Camcorder
Camera turns off
Are you sure the battery is holding a charge? you can get one off of ebay pretty cheap. Just to check. It is acting like a battery issue but it could be a damaged lens that can cause the same out come. I hope this helps lead you to a easy repair.
Mar 28, 2008 | HP Photosmart R927 Digital Camera
GPS Logo
32 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
