Question about Dell Latitude D510 Notebook
How to connect dell Laptop to TV.
I have a VGA to RCA converter going from my laptop to my tv but my laptop says, "no external display attached"
  • roblpetty Jun 03, 2010
    I i did that when i press that, that's when it gives me the no display attached message. I need to find a way to get my computer to recognize that it's attached
    Sergeant:
  • 356 Answers
Press Fn+F8 to enable your external monitor/TV.
Posted on Jun 03, 2010
My laptop is vga,so i have bought a vga cable,and a converter box with HDMI cable. My samsung series 5 tv will not pick up the laptop. i have tried all the options available but it just says check devices...
Wouldn't it be NICE to know what laptop you are referring to
Oh well...........maybe one day
By factory default settings the display should automatically show in the external VGA monitor. (TV. Whatever)
HOWEVER;
Your laptop has at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold the Fn key down, and at the same time tap once on the Display Toggle-Over key.
Which key is the Display Toggle-Over key?
Dunno. Laptop manufacturer and model number wasn't stated.
(One of the F keys at the top.
Generally;
Acer = F5
HP = F4
Lenovo/IBM = F10
Dell = F8, unless it's Alienware - F6)
Did that? That's how it worked on your friend's TV?
Then your TV is the problem.
Settings I assume. NOT a TV tech.
Regards,
joecoolvette
Feb 07, 2013 | Computers & Internet
How to hook up Dell laptop to Samsung Dlp tv?
Your Dell D620 only has a VGA Port for output to a external monitor or tv. Your TV will need to have a VGA Port too, otherwise you will need some type of adapter that goes between the laptop and the tv to convert to the type of connection the tv has (svideo, hdmi, dvi, etc.)
One you have the two connections set up to communicate with each other, just select the input source on the tv (pc, computer, hdmi, etc) and then reboot the computer if the image is not show.
After rebooting if the image is not shown, then you will need to toggle the display by some keystrokes. Press and Hold the Fn function key at the lower left hand portion of the keyboard, then hit the F8 key which toggles the display to be either on the laptop only, tv only, both the laptop and tv.
Apr 22, 2012 | Dell Latitude D620 Laptop (Latitude-C620)...
How to connect my dell inspiron 1501 laptop to my hdtv. am using a vga cable with rca out, to connect to the tv. i have tried everything but none works. if this can work please sent me step by step...
1 - the cable you are trying to use will not work - the RCA inputs in your tv can't accept the signal coming from the VGA. To connect the laptop to a tv the tv must have an VGA input, nothing else will work.
2 - When you start the laptop with an external device (such as an external monitor or tv) attached and turned on, the image may appear on either the laptop's display or the external device.
Press to switch the video image between the display only, the external device only, or the display and the external device simultaneously.
Apr 27, 2011 | Dell Inspiron 1501 Notebook
Use TV as external monitor from laptop
no tube tv won't mirror monitor. needs vga connection at the back of tv.go to store have a look at lcd or plasma screen.the card is ok.
Jun 26, 2009 | HP Pavilion DV6500Z Notebook
Connect to a tube TV
hi mr. pavilion dv6700z. i have the same problem before but after i tried and use my genius mind. i made it. and the television is working in my laptop as a external monitor. pixel is good. just connect in card video out to video iput to television. romsky79@yahoo.com.
Jun 06, 2009 | HP Pavilion DV6700Z Notebook
Connect my laptop to tv with a sound
Your computer may have come with cables to do just that. If not, you have options:
For video, I would check your TV inputs to see if it has a VGA port, since that would be the easiest. You can also get VGA to RCA or S-Video converters online as well if your TV does not have a VGA port. Almost all TV's these days have RCA inputs.
For audio, you can get a headphone jack (3.5mm) to RCA converter.
If you can't find the converters at your local electronics store, just google VGA to RCA and headphone to RCA.
Once you have the necessary cables connected to your TV, your computer will recognize that it has been connected to an external video source. I'm not sure, but I think it is either key combination Fn+F6 or F7 to perform a monitor switch. You can also right-click on the desktop and select properties (or personalize in vista). Then switch to the settings tab (or Display settings in vista) and click on the alternate display.
May 03, 2009 | Sony VAIO VGN-FE550G Notebook
Vga to tv
The answer to your question is Yes. You can use a VGA to RCA converter and view the output on your TV. I am assuming that you are using a Inspiron 1200 laptop. Couple of things you may need to check.
1. Toggle display using Fn + F2 (Hold down the Fn key and press the F2 function key), this will toggle the display between Laptop, TV, & Laptop + TV .
2. Right-click on desktop, goto display properties, make sure the second display is set to 800x600 or 1024x768, these are the only display resolution supported by analog TV’s
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 23, 2009 | Dell Inspiron 1200 Notebook
Connect Laptop to TV
It depends on what kind of TV you have. If you have a flat-panel LCD or plasma TV, it may have a VGA connection already installed. If that is the case, all you need is a standard VGA cable to connect from your notebook to your TV.
If you have a TV without a VGA connection you will need a scan converter to convert your signal from VGA to RCA or composite video signal. These can be purchased online or from electronics stores like Radio Shack. You plug your VGA connection from the computer to the scan converter, then RCA or composite video cables from the converter to the TV.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 16, 2009 | HP Compaq 8510p Notebook
Dell Inspiron 2200 to Phillips 47 " TV
check this out http://answers.google.com/answers/threadview/id/762913.html *A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable. you will need a seperate audio cable unless you are going to use your laptop's speakers
Feb 04, 2009 | Toshiba Tecra M1 Notebook
Dell Latitude D510 Notebook Logo
263 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
