Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
Hello, I just bought the lacie portable hard drive 250G and its not working at all. Initially, it showed up on the computer but now there is a light but its not showing up on the laptop or desktop computer.
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
Lacie Case Only lighting up when HD is disconnected
I had the same problem with a 1TB hard drive. The fault was caused by the casing being knocked from the computer and falling onto the desk. If the hard drive hadn't been powered up it would have been ok...
I removed the hard drive from the casing and fitted it into my computer as a slave drive, hoping to access all the music and movies stored in it. No go .. But, it's worth you fitting your hard drive as a slave and trying the same. It's worth a shot.
I took the hard drive to a computer market here in China, where I work. These guys take hard drives apart to fix them, if possible. They couldn't fix my hard drive as it had been powered on when it fell ..
However, I bought a new desktop hard drive and they were able to transfer 95% of all things from the old hard drive to the new one. The cost of transferring from the old hard drive to the new hard drive was the same as the price of the new hard drive. That specialist service doesn't come cheap ... but it can be done. I paid simply because I didn't want to lose what had taken more than a year to download.
Try fitting your hard drive as a slave to see if you can access the information on it. If not, a new hard drive and the cost of transferring your music from your old hard drive may be the only course of action left open to you
Jun 05, 2013 | LaCie Big Disk External USB 2.0 1TB Hard...
Hi, I can't find LaCie program on my XP where can I find it?
the LaCie Rugged drive does not require any specific software to operate under windows XP, but maybe you are talking about the bundled software that came with it.
Those are initially on the drive itself at the time of purchase. If you formatted the drive, then they are gone and you will need to download them from LaCie website. Some of them are not available for download there so you will need to contact LaCie customer support to get those.
The link for the LaCie US download page for hard drives is: http://www.lacie.com/us/support/drivers/index.htm?id=10007
Regards,
Jan 30, 2011 | LaCie Rugged All-Terrain (301017) Hard...
Hello I bought a lacie hard drive model 301103U, my pc didn't recognize it because I can't to find the drive, I would like to have the drive for this deveice
Try connecting it to a different computer.
If it still is not detected, then it is "defective".
Take it back to where you bought it, and get them to repair/replace it, or for them to connect it to one of their computers, to "prove" that it works, at least some of the time.
Oct 23, 2010 | LaCie 301103U 500 GB USB 2.0 Hard Drive
If I try and format my LaCie drive through my computer its capacity shows as 9.99 MB why is that if I do format it (NTFS) will it have the correct capacity of 250G
You may have two or more partitions on this hard drive. If you delete all the partitions and then format the hard drive then you will have the full unformatted 250 Gb capacity.
Sep 24, 2010 | LaCie (300770) 250 GB Hard Drive
Computers don't recognise my lacie portable hard drive it registers as yyyyyyyyyy yyyyyyyy USB device
thats because you need to update your computer...or you need drivers in order for your usb to work
Nov 30, 2009 | LaCie Silverscreen 80GB USB 2.0 - Portable...
Hello there! I have an external hard drive with lot of documents, when i downloaded a HD video on the drive, it plays a bit and the picture just stuck but the sound continues and the video continue after...
The throughput of the connection to the computer, including the latentcy time of the external drive, is too high so the video has to buffer up more data before continuing the video. This is NORMAL.
Oct 19, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Same problem
uninstall the driver and reinstall it or do a driver rollback,via your device manager(XP)
Sep 01, 2009 | LaCie (300770) 250 GB Hard Drive
Can't access my lacie external hard drive
I would first plug it in to a different PC, this will tell you if the problem is the Lacie or Windows Vista.
if it works on a different PC then remove it from Device manager or go to the Lacie website for Vista updates.
If it does not work on a different PC then there are 3 possibilities
1. the drive got cleared data lost
2. the enclosure is bad (I would bet on this)
3. the drive is bad
purchase a USB enclosure, remove the drive and install it in the new enclosure plug in and test.
Hope this helps
thanks for rating
Jan 09, 2008 | LaCie (300728U) 250 GB Hard Drive
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
69 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
