Question about DCS PHFS Phoenix III Outdoor Patio Heater
I am trying to light a heater that is a couple of years old. The pilot will light but the main burner will not. I have changed tanks but no luck. Can you help.
  • 494 Answers
So the pilot flame stays lit after you release the pilot button, but goes out when you turn the knob to on. First make sure the pilot flame is a strong blue flame that is actually heating the thermocouple. If it's a lazy yellow flame, then it is dirty and will need to be blown out with a can of air with attached straw (to remove dust, spiderwebs, etc). You also might check the burner and orifice to make sure they are not blocked by a bug nests, etc and clean out as needed.
Make sure the thermocouple tip is not burn't off from the pilot flame. It should be a smooth rounded tip. If it's not, then replace it.
Lastly, make sure you're not turning the propane tank valve on too fast. To check this; disconnect the tank, reconnect it and then turn the valve on very slowly. Hopefully one of these solutions will fix your problem. Have a great weekend! Douglas
Posted on May 28, 2010
U can light the pilot lite,turn 2 ON it will stay lit 4 a couple of minutes then go out? If u turn the knob 2 low,med. It goes out pretty much immediately?I changed the thermocouple,blew the lines ou
Is the thermocouple secure, routed properly, no kinks, no sharp bends? Is the end of the unit properly aligned so the hottest part of the pilot flame is hitting the unit. Did you hold pilot switch in the light position for at least 30 seconds, before you set the gas valve to on? If all above OK, try this. Light the pilot using barbeque lighter once it lights keep the lighter on the t-couple for 30 seconds, then set the valve to ON and keep the lighter where it is. Once the main burner lights, remove the lighter. If the burner and pilot go off, your gas valve is bad.
Feb 17, 2015 | Rheem Richmond 75 Gal Natural Gas 6 Year...
I can get the pilot light to stay on but main gas burner won't fire up
If the pilot is lighting and the thermo couple is in the fire and turned red and the pilot still does not stary on change the thermo couple. They are available in any home improvment store.
Nov 04, 2014 | RTO Suburban Rv Water Heater Dsi Gas Valve...
Junkers manual gas hot water
What are you expecting to happen?
I assume the water heater and water inside it is cold (otherwise you would not be lighting it). You light the pilot. The main burner comes on and the pilot lights it. The main burner should stay on until the tank is hot, When the tank gets hot the main burner should shut off but the pilot stay on. If you draw hot water, cold water will run in and cool the tank. If yu do nothing the tank will eventually just cools off. then the main burner should come back on to reheat the tank.
Nov 05, 2013 | Water Heaters
Fireplace burner won't stay on
try cleaning the pilot sounds like its a short pilot and when the burner comes on it pulls the gas from the pilot light .
Feb 22, 2013 | Heating & Cooling
My 2 year old (rusted and looking like a 10 year old) Pilot goes on lights the heater, burns for about 2 minutes and goes out. I tried another regulator, same problem. Gas tank is full. The pilot light...
Heaters that have rusted are tin plated or chrome finish, it can be hard to get a stainless steel heaters since some traders sell heaters as stainless steel but don't tell you the burner is made of tin. If you get a new heater just ask the question, is the burner tin or stainless steel? The problem with a burner that goes out can be a simple as changing the thermocouple, these are consumable and last between 2 to 5 years depending on use and storage. But if you have a yellow tipping this is not good, this can be caused by wrong fuel mix or faulty gas valve and is not an easy fix. Found this site very useful patio heater problem solving. Lots of info.
Oct 23, 2011 | Coleman (5040B750) Patio Heater
The pilot won't stay lit on gas hot water tank.
Make sure thermocouple tip is seated inside the burner flame.
Make sure thermocouple is not overtightened. Finger-tight + 1/4 turn.
If the pilot lights, then ECO energy cut off is not tripped, but gas control valve might be bad.
Check color of pilot flame: it should be strong and clear blue.
If pilot flame is weak, or color of flame is yellow-orange: Clean pilot orifice and burner and combustion parts on yearly basis.
Clean air intake screen if applicable.
Increase air supply to water heater. Open a window and see what happens.
Check for adequate draft going up chimney using match under vent hood to see if smoke drafts immediately upwards.
Bleed air out of gas line.
Check gas pressure.
Open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Pilot-outage-troubleshooting.pdf
http://waterheatertimer.org/pdf/Vent-spillage-test-atmospheric-gas-water-heater.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 21, 2011 | Water Heaters
Greenhouse Heater pilot light will not stay lit
replace the thermocouple. it is a small copper tube that screws into the gas valve and goes to the pilot assembly. a good haedware store that sells heaters will have one. they come in various lengths 18"-48".
Nov 30, 2009 | Heating & Cooling
The pilot light does not stay on so heater won't light.
to thermocouple where the pilot light sits is either dirty/carbon out of alignment flame not burning on it correctly or damaged/broken which would mean replacement
Oct 19, 2009 | Uniflame Patio Heaters Stainless Steel...
Propane heater goes out after heat cycle
I've seen excessive draft draw the pilot flame away from the thermo couple when the burners light so when the burners shut down so does the pilot.
Feb 08, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
191 people viewed this question
Top DCS Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a DCS Heating and Cooling Expert? Answer questions, earn points and help others
