Question about Hotpoint HSM25GFRSA
Water works on door but ice maker isn't making ice occasionally hear noise like trying to dump ice cubes but no ice
  • 166 Answers
The water valve located on the back of the refrigerator that the water line is connected to could be bad. if no water is coming to the ice maker then it shouldn't have any ice or water in the ice mold. if it is empty you can try pouring enough water in the mold to make ice cubes. wait an hour or so and see if the ice maker dumps the ice. if it does you probably have a bad water valve.
if your ice maker has ice in it but had been making small cubes you should check to make sure you don't have a jam. small cubes could be from low water pressure or a blockage. if your refrigerator has a water filter it may be time to replace it if the water dispenser water pressure is also low.
Posted on May 28, 2010
My ice maker inst working Whirlpoo; model gz25fsrxyy2
By "ice maker isn't working" do you mean it isn't filling with water, it isn't freezing the water in the ice maker, it isn't dumping the ice cubes into the bin, or it isn't dispensing ice cubes?
Was it previously working and it is not working now?
Typically one can hear the valve when it opens to fill the ice maker with water. Can you hear it attempting to do so? If so, and there isn't any water in the ice tray, check that there is water supplied to the valve at the wall and the valve is open. Is there a water filter? Has it been replaced per the manufacturer's recommendation? (Typically, the water filter should be replaced every six months.)
Is the "full" bar pushed up? It shouldn't be. The bar above the ice cubes should not be in the horizontal position. That position tells the ice maker the bin is full so it should wait until the bar goes down, indicating some ice has been used.
Can you hear the bayonet turning? Is the ice maker attempting to dump out cubes whether or not they exist? The next issue after you confirm there is water going into the ice maker that is being frozen and the ice maker knows to dump the ice, is the bayonet. There is a motor that turns the bayonet and a mechanical connection. Either could be at fault.
Jan 22, 2018 | Refrigerators
Freezer won't make ice cubes, but does provide cold water.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
Jul 08, 2012 | Frigidaire Refrigerators
Ice maker will not make ice. no ice is being made. no water appears to be in ice cube making area. can hear a ticking noise from icemaker area
Carefully pour water from small glass into ice maker, until the cavity is near filled. Wait a few hours. If it dumps ice, you can usually rule out the ice maker.
If ice maker dumps, then it will be either a bad water valve, Ice building up in fill pipe going into the icemaker, or blocked water line that runs from your water source to the machine.
Caution. If the fill tube going into the ice maker is filled with ice do NOT
use heat such as a hair dryer to melt it. It will melt things you do not want to melt. If it is this problem, you must also replace the water valve because it is leaking slowly causing your problem.
Lastly, in rare cases, the microswitch in the ice maker fails and does not allow water to enter the icemaker.
Oct 22, 2009 | Kenmore Refrigerators
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
Ice Maker stopped making Water Whirlpool model (ed5phexnq00)
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | Refrigerators
Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Apr 27, 2009 | Whirlpool GS6NBEXR Side by Side...
Kenmore Coldspot not making ice
sounds like the flap that u can usually hear once the ice has stoppped coming out it sounds like a pop or thud ...what happens is the magnet goes bad and keeps the ice maker constantly open to the outside air causing ice melting and massive ice cubes.....usually a costly repair...check and lemme know
ps. id have a licenced repair guy check it out
Sep 30, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Ice maker jambed-now no water
The ice maker must be re-primed with water to sense frozen ice in the tray, dump, and refill. Use a cup or glass to manually pour the water into the tray just below the top of the blades. It should freeze, dump, and refill.
May 15, 2008 | Whirlpool ED2FHEXN Side by Side...
The water supply line had gotten chewed by the dog. Now the we have the line repaired its up and running. But its got the same noise and not ice is dropping. The noise I am talking about is the same noise...
IF THE ICE MAKER IS TRYING TO DUMP ICE, IT MAY HAVE A PARTIAL CUBE JAMMING THE EJECTOR BLADES, KEEPING THEM FROM COMPLETING THEIR CYCLE. FEEL THE EJECTOR BLADES, ONE AT A TIME TO SEE IF THERE IS SOMETHING WEDGED BETWEEN THEM AND THE ICE MAKER MOLD. THERE SHOULD ALSO BE ICE CUBES IN ALL THE SLOTS, ALL THE WAY UP TO THE FRONT. IF NOT, THERE IS INSUFFICIENT SUPPLY OF WATER TO THE ICE MAKER.
Apr 10, 2008 | Refrigerators
Hotpoint HSM25GFRSA Logo
264 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
