Question about Craftsman 675 Torque 190cc 21" Briggs Stratton RearBag Push Lawn Mower (CA) ()
My craftsman lawn mower was running fine, then I bumped the front into a swing and all of a sudden it lost power. Now it sounds like it is running at half throttle and I can't figure out how to fix it.
  • 196 Answers
If your plug wire is in the front, check it. It may have come lose and is making sporatic contact with the end of the spark plug. My wife did the exact same thing last week. You may have to look in the plug wire cap at the connector.She bent ours so it was larger than it should have been and not "snapping" onto the plug when pushed on. I just lightly squeezed it together with a plier and then it snapped back on night and tight. Ran great after that.
Posted on May 28, 2010
Lawn mower won't start new plug flywheel key okay
Posted on May 29, 2010
Craftsman MRS 650 Series (Self Propelled) After priming the mower runs for 40 seconds but not at full power, then suddenly stops.
sounds like the jet is slightly clogged,
Take the carburetor bowl down and clean holes in jet with small wire (SEARCH : acetylene torch tip cleaner)
Aug 27, 2013 | Garden
Lessening power to blade, less cut grass lift
check your spindels on the mower deck sounds like they are going bad if you dont fix it it will overheat the engine .
Dec 17, 2017 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman tractor making a bumping noise in front end
if it ran loose for a long period of time the slot for the key way might have been damaged pull the pulley's off and inspect them
Apr 05, 2012 | Craftsman Garden
White smoke coming out of mower
It sounds as though you are losing power (electrical power); see if charging the battery fully allows it to run longer or if charging the battery helps.
Jul 15, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a brand new Crafsman 22" Rear Bag Front Propelled High Wheel Lawn Mower with a key start. It worked fine for about 20 minutes but then would not turn off once the power lever was released. It just...
It sounds as if the connector for the handle harness became disconnected. Check the wiring connectors and see if one of them came apart. (including the switch...) If it is not that simple please provide a model number and I will dig in the manuals to do what I can do to help you.
Thanks for using FixYa.
Kelly
May 30, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Walk behind craftsman lawn mower. starts but shuts off after 15 minutes then will restart after it sits for 10 or 20 minutes
not sure what model but it sounds like it runs hot? make sure the fuel/oil mixture is correct, exhaust is not clogged, sparkplug is in good condition. hope this helps.
Jul 12, 2009 | Garden
Craftsman 19.5 riding mower starts runs quits no power
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
May 22, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 675 Torque 190cc 21" Briggs  Stratton RearBag Push Lawn Mower (CA) () Logo
661 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
