Question about Dryers
I have a Kenmore Elite HE4 dryer that has the 4E code... from everything i can tell the door is closing properly... however the light in the dryer stays on when the door is closed.... There is a "button/switch" that the door presses on when the door closes...i believe that the light in the dryer should go off when i press this with my finger is that correct? It does not what do i do?
    President:
  • 949 Answers
You are correct in your theory. The drum light should go off when the door is closed, the problem would be either in the switch itself (the button you are pushing with your finger) or the control that the switch connects to (behind the console).
If you could send me the entire model number from the tag just inside the door I can assist in getting a part breakdown diagram for you, if you wish to make the repairs yourself.
Posted on May 28, 2010
  • shanechrapko May 28, 2010
    here are the numbers from the door
    Kenmore
    MOD 110 C85862400
    SER MS4006985
  • Philip May 28, 2010
    Thank you for the information. I am attaching a link that will show the service information on this model. It will explain how to test the door switch, how to take the unit apart and what to look for. The door switch section is on page 9. If it is too technical let me know and I will help explain things as you proceed.
    Service Guide
Kenmore he4 error code 4E, Light is burnt out and just makes beepin noises, i have unpluged it what should i try next?
From what you described it sounds like the door switch is faulty. In the test mode when you saw the 4E you should also hear a beep when opening or closing the dryer door.
Here is a link to the replacement part.
Oct 16, 2012 | Kenmore Dryers
I have a kenmore elite dryer hE4. the dryer will run for a while then shut off... and will not restart for a while, i have changed the moisture sensor, thermistor, thermal fuse, the moisture sensor wire...
its a door switch problem. Make sure the door is latching properly at the top. If the top latch doesn't engage properly the door switch won't make contact.
Try holding the door switch closed with your finger and starting the dryer. If it still wont start and you have no error codes displaying you will most likely have to replace the switch. if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Apr 13, 2011 | Dryers
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite Smartheat Quietpak 4 will not start. F70 code
leave door open and press the rubber botton inside, \ I just hooked up mine and it did same thing, i pushed botton light went out, so this told me the door wasnt closing correctly, you have to push hard on door first couple times. hope this helps you.
dave
Feb 09, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 - Smartheat Quietpak9 ERROR CODE 4E
Buckeyw,
Huuum,at your service!
With an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems.
if they are not serious, or they are a temp glitch!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Bless You
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Thank You
Sep 18, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he4 dryer wont run
Hi! crystal2hd
My he3 dryer does not have a door lock. The door switch turns off the light and allows the dryer to start. Make sure this switch is not damaged. Unplug the dryer before removing the front cover.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite He 4 model number 11085087400
Sorry to take so long getting back to you. 4E is a door latch error code. It means your door latch is not working. Double check the wiring to make sure you don't have any loose or broken connections. More than likely, you will have to replace the switch. This is not one of your standard error codes that you will find in any tech sheet. I have experienced this problem before. If you go to searspartsdirect.com and type in your model number, you can find a replacement listed under the "Cabinet Parts" heading as item number 41 (part number 8519323). HINT: If you order this as item number 19 (part number 8283288) it also includes the wire harness. I hope this helps you. If you require additional assistance, please let me know. Good luck to you.
Aug 20, 2008 | Kenmore Elite HE4 Electric Dryer
4E problem on kenmore dryer
Same problem, no panel lights, nothing, but drum light works. Several postings on othe sites say the cuicuitry board is faulty. Sears, in the Phillippines, or India, do notheing. Paid lots for this dryer, live alone and really don't abuse it or even use it that much. Is the there a class action suit maybe? all I want is for it to work!
HE4 Kenmore Elite Dryer error code 4e
If you have ever removed the lint filter area completely via the screws that hold the plastics in so you could clean it then remove it again and insure that you plugged in the two wires that go to the strip sensor.. (moisture sensor)
May 16, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
