Question about Cameras
Response tv 2000 camera 4 wires red yellow blue black can i use a serial plug or usb or a yellow vidieo lead
    New Friend:
Hi all. I stumbled on this site, & it seems pretty much what I'm looking for. I have a response3 TV2000 camera, but with only bare wires coming from the cam. White, red, blue, green & black. I'm assuming the red is + and the black is -. From the above post, I thought the green may ALSO (in my case) be composite video, may not be. But I'm lost on the other 2. Any help would be appreciated guys. Also, what connectors are needed, to go straight into a PC. Also, would a PC power the camera....
Thanks in advance.
Karel
Posted on Dec 07, 2015
  • Karel Bellic
    Karel Bellic Feb 04, 2017
    Thanks to all who helped. I know it's been some time, but I have been in Wales, now I am back in the NE. I still have the cam, but am giving it to the young mum next door to us. Do our community thing. If it's easy enough, I will install it myself. Thanks again all.
  • Karel Bellic
    Can I post pics here ? I think not, but clarification is always good.
4 Suggested Answers
  • 102366 Answers
SOURCE: when I plug in the usb lead to download the pics,
Consider NOT using the USB connection.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Posted on Apr 01, 2011
SOURCE: i have a blue,red,white,black,yellow and
you need to get a converter cable. you can find them at Best Buy or any appliance store.
Posted on Mar 19, 2011
mbodenhausen
  • 8 Answers
SOURCE: mc6184s how do u wire
Red - +7.5VDC
Black - Ground
Green - Composite Video (like a video game)
Yellow - Audio
If you are using the original harness and want to cut off the phone connector, swap the red and black wires.
Posted on Dec 04, 2011
How to wire the Superstar DM-452 to a Cobra 2000, 5pin plug. Mic wire colors are Sheild, White, Yellow, Red, Blue.
Yellow is your Audio so it will go to Pin 1
Shield will go to Pin 2
Receive will be black wire Pin 3
Red wire = Ground pin 4 (or it will work with out it)
and Blue will be transmit Pin 5
Oct 16, 2014 | Radio Communications
How do i wire up camera after somebody cut off plugs
INDUSTRY STANDARD WIRE CODE COLORS FOR CAMMERAS ARE AS FOLLOWS
RED- POWER SUPPLY POSITIVE
BLACK - POWER SUPPLY NEGATIVE
WHITE- VIDEO CENTER
YELLOW- AUDIO CENTER
THE SHIELDS ON VIDEO AND AUDIO HAVE TO BE JUMPERED TO BLACK - POWER SUPPLY NEGATIVE
NEVER ALLOW POWER SUPPLY POSITIVE TO TOUCH VIDEO OR AUDIO LEADS
Oct 09, 2014 | Lorex Home Security
How do I install the 4 prong electrical cable to the dryer?
I would attach the black wire to the black & yellow, white to white, red to blue & brown. The green wire is your ground wire and needs to be attached to the cabinet. On the connection where your white wire is located see if there is a copper strap that goes from the terminal block to the cabinet. If there is, you will need to remove that strap and attach the green wire to where the strap was attached to the cabinet. Hope this helps!
Sep 16, 2014 | Dryers
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
I have a general lee cb with a 4-pin standard mic. the wires in my mic cord broke at the plug. does wnyone know how to wire this type of mic back and what color wires go to the correct pin?there are 6...
Here are the Pin outs for different mics that will work with your radio. If a wire is not listed then you cut it off. It's best to keep the wires as short as possible no longer than a half inch is suggested. Normally the Cobra pin out is standard for most radios.
Stock - 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - (4 wire) 1- Shield 2- White 3- Red 4- Black
Astatic - (6 wire) 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500, Cobra, CA Series - 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - (4 wire) 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI - 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta - 1- Shield 2- White 3- Brown 4- Green
Turner - 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Jul 12, 2011 | Magnum DeltaForce CB Radio
RIPD CAMERA WIRES!!!
you need power to the red and black, white to a rc plug center pin yellow to the center pin of a rc plug and there should be a bare wire you need to split it off to the outside section of the yellow and white rc plug
Jun 01, 2010 | Lorex SG6153 / Weather Resistant Mini...
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
Which colour wire to use to hook up a trailer for a Kia Carnival 2000,trailer leads are yellow, green,black,brown,red,white and blue(no connection). just want to know which lead goes to which in the Kia?...
Here is a cheat sheet I compiled that you will find very helpful:
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are Color, Function, Mark on the plug.
Seven wire Trailer plugs
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
Oct 28, 2009 | 2000 Kia Amanti
I am converting a 3 prong dryer to a 4 prong plug. The wires inside the dryer are black/yellow, white and blue. The wires on the plug are white, black, red and green. I am assuming the green is the ground...
on plug white is neutral, black is power , red is power, green is ground. black/yellow and blue are power and white is always neutral ie. (white to white) black to black/yellow, blue to red. green to grounding screw on machine
Jan 04, 2009 | Estate TEDX640JQ Electric Dryer
Cameras Logo
321 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
