Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Since the digital switch over I can't find a channel on my Philips Flat Screen HD Ready TV. I have tried searching for channels, I've set the search to UK and tried both auto and manually and there is nothing. Is there anything else I could try. The channels were there before and another TV in my house find the channels so I don't think is it an ariel problem. Many thanks
  • Philips Master
  • 8,457 Answers
U have a digital antena?Or a roof atena?Have one of these.U well increase ur arial ranges to recieve free air DTV signal much stronger and farter ranges.
Posted on May 28, 2010
I have a flat screen TV and i got the digital channels but I did something and now i can't get any digital. Please help me.Thanks
Well im not an expert on this but by wife keeps deleting channels... you can just go to setting and anything the reads channel search or digital search just run it or scan... your tv will scan all channels... make sure that your antenna is connected or digital receiver... when you tv searches it needs something connected to the input of the tv antenna... you can try goggling it too
Apr 27, 2016 | Televison & Video
WHAT is this tv digital ?
Dear Friend,
First, search for available air channels by going to you menu and then search for channel setup.
Second: change the option from Cable to Air Channels.
Third: after performing the channels setup you should be able to see free channels trough the air.
Good Luck!
Aug 06, 2014 | Shopnbc Insignia 39", 46" or 55" Full HD...
How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
Only shows channels 3-23 and then only shows a few hd channels
Are you using a Cable Card? Have you tried the Channel search function in the user menu. Select Channel set up and do a channel search.
Apr 12, 2010 | Samsung HP-P4271 42 in. HD-Ready Plasma...
47'' philips flat screen does not install channels
Go directly to theback of the set via the back RCA connectors(yellow, red, white) or component video, and turn set on Aux. If it works the tuner is Messed!
Apr 08, 2009 | Philips 42PFL5332D 42 in. LCD Television
Channel setup
You will have to run the Autoprogram menu function from the menu. Here are the steps
Press the MENU button on the remote control.
Use the cursor down to select Installation in the Settings menu.
Use the cursor right to enter the Installation menu.
Select Autoprogram in the Installation menu.
Use the cursor right to enter the Autoprogram menu.
Press the OK button.
Select Cable or Antenna in the Installation mode.
When Antenna is selected, the TV will detect antenna signals and will search for antenna TV (NTSC and ATSC) channels available in your local area.
When Cable is selected, the TV will detect cable company supplied signals and will search for cable TV (NTSC,ATSC, QAM modulated) channels available in your area.
Make sure that registration with your cable TV provider and connection of equipment are completed.
Press the green button “Next” on the remote control.
Press the green button “Start” to start autoprogramming.
The menu screen disappears and the progress of autoprogramming is displayed.The progress bar indicates the number of analog and digital TV channels found. (Also digital channels via CableCARD are being programmed.
When Autoprogramming is complete, a message appears confirming the completion and the TV switches to the first installed TV channel.
Mar 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Can not get hd channels on my new tv..
First of all, digital/HD signals are broadcast at UHF frequencies. You need to know if you have an UHF antenna and, if you do, that it is pointed to the TV stations broadcasting HD.
Second, since most TV's have a setup mode that automatically searches for channels that are able to be received, go to that "Setup" menu on your TV and start the auto search. It will list both analog and digital stations. Note that the analog channel may be, for instance, Channel 39 but the digital channel will be Channel 39-1. Tune to the "dash 1" channel.
Dec 30, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Philips LCD TV wont change aspect ratio
In your philips menu there is an option to turn of your auto aspec ratio to OFF then using your sky remote go to services, 4 then picture and ensure that this is set to 16:9
Job done
Cheers
Little Dish Fitter
Dec 24, 2008 | Philips 32PF7321 32 in. HDTV-Ready LCD...
Blank screen no access
try setting up the tv using the default setting
make sure that the tv searches and installs al of the channels
Lou Margo
Allied electronics
Jul 16, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
128 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
