Question about Danby DDW496W Free-Standing Dishwasher
Danby ddw496w drain hose connection wont screw on to the back of the dishwasher.
  • godiva bear Apr 08, 2008
    I called Danby, apparently this used to be a common reoccuring problem with this unit, it would be be missing the starter thread piece that attaches to the unit and then allows you to attach the hose when it was shipped. They are shipping the part out to me and say 4-5 days shipping, at no charge for part or otherwise.
    Now I know why I got a new unit on sale, it was missing a part in the box.
    Otherwise I am looking forward to having a dishwasher in another week or so.
Havent solved it yet. Have to call the Danby 1800 number to see what I need to do.
Posted on Apr 08, 2008
I have a danby ddw496w that leaks water from the bottom of the machine when it goes into the drain cycle.it will start coming out the bottom as well as the drain outlet .Could it be a simple hose...
Ditto- same issue, hoses are tight, just leaks through the bottom while draining. Anyone with advice? I just bought mine used, and the previous owner is willing to buy a replacement part, we just have to figure out what we need...
Sep 25, 2011 | Danby DDW496W Free-Standing Dishwasher
Danby ddw496w
Maybe you have the wrong part , contact danby and ask a replacement
Apr 07, 2008 | Danby DDW496W Free-Standing Dishwasher
I have a problem where my dishwasher starts its cycle, filling with water, then as it starts it immediately drains as the spray arms are moving. Since the water is draining the dishwasher then pauses to...
It sounds like your motor is stuck in the reverse position. It could also be in your timer. I would suggest calling a qualified technician for the one. Just because the parts are pricey and depending on how much a new dishwasher cost. Atleast get a diagnosis so you can know if its worth fixing or buying a new one. If you have anymore questions please feel free to comment me back.
Jun 05, 2011 | Danby DDW496W Free-Standing Dishwasher
Where can i get parts fod danbt dishwashers?
Hi
You can order the parts for your Danby dishwasher from this link---
Danby Dishwasher Parts
Please post back if more information is required.
Daniel
Aug 08, 2010 | Danby DDW496W Free-Standing Dishwasher
Soap suds and some water not draining out of washer after cycle is complete
if you read the manual, it states that this is normal. so dont let this bother you
May 05, 2009 | Danby DDW496W Free-Standing Dishwasher
E3 code
Received from Danby customer support:
"The error code of E3 tells us that the unit is not getting the proper water temperature to continue thru the entire cycle. Before starting the dishwasher and attaching the quick connect assembly to the faucet, please make sure that the water from the faucet is warm to the touch; you can then attach the quick connect assembly with hose to the faucet and start the unit. If the water temperature does not reach 120 degrees F the dishwasher will not be able to run thru the entire cycle properly. If this is being done and the same code comes up, we will need a service tech in you area to diagnose the problem for us. For a warranty servicer in your area you can reach us at 800-263-2629 Mon-Thu 8:30-5 or Fri 8:30-4 EST."
Jun 11, 2008 | Danby DDW496W Free-Standing Dishwasher
Danby counter top dishwasher
CLR should do the trick, read instructions on back of the bottle. Also there are some dishwasher cleaners that you buy.
I bought one at Safeway. Small bottle, has a picture of a dishwasher on it. It has a wax seal that melts when you run it on the hottest cycle upside down. It cleans the inside of the dishwasher.
Of course this is assuming that its build up.
May 31, 2008 | Danby DDW496W Free-Standing Dishwasher
Danby DDW496W Leaking Brand new
Check your hose connections in the back for tightness and sealing (there should be some rubber seals inside the screw-in connections) and if tight and not leaking, you might have a loose clamp inside the unit, or a leaking/damaged hose, or even a defective/leaking pump. If it is brand new and returnable I'd return it for a new one rather than try to fix it...
Apr 05, 2008 | Danby DDW496W Free-Standing Dishwasher
Danby DDW496W Free-Standing Dishwasher Logo
135 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
