Question about Acer Aspire 4720 Notebook
Bios Problem i removed my cmos battery, for my acer travelmate 4720 when i put the battery back in and turn the machine on, the keyboard is not responding to my F2 button and the acer screen just keeps restarting. Can anyone help me here. Thanks In Advance..
    Brigadier General:
  • 10,406 Answers
Check that you did not re-insert the battery "upside-down".
Posted on May 28, 2010
How reset bios password form a acer travelmate 240
You will need to turn your travelmate upside down and remove the ***** from the hard drive panel or Ram cover...try both.You will see a small battery(cmos battery). If you can see where it is plugged in and can reach it,unplug it for about 10 seconds and plug back in then put your covers back.That should reset your bios so you dont need a password.You can go back in your bios at a later time and set a new password if you wish :)
Aug 23, 2014 | Acer Unlock Bios Password: Aspire 7735g...
Bios cmos password reset
Remove the laptop battery, locate the cmos battery inside the laptop, remove it then wait 5min, plug in the power, switch on the laptop and then the moment it switches on remove the power plug. Then put the cmos battery back, then the laptop battery and turn it on. All should be right. Referring
Oct 31, 2013 | Acer TravelMate 233X PC Notebook
BIOS
Step 1:
This might not be your laptop it might give you a guide into the cmos battery
The CMOS (Complementary Metal Oxide Semiconductor) battery saves basic settings on your computer. If the date and time function on your Acer notebook isn't working, chances are your CMOS battery needs to be replaced. Separate from your laptop's main battery, the CMOS battery is about the and shape of a coin and is located inside of your computer. Changing the battery yourself isn't the simplest task that relates to your Acer, but it isn't terribly difficult either. Here's how.
Open the notebook screen until you can easily access the keyboard. Locate the plastic bar that borders the top of the keyboard. Insert the flat head screwdriver at one end of the bar and gently pry it up until you can grip the edge with your fingers. Pry the other side of the bar up with the screwdriver and pull out the entire bar, being careful to mind the ribbon cord that connects the keyboard to the computer. Remove the two screws on either side of the keyboard that secure it to the computer. Slide the keyboard up and place it to the side. Remove the four screws on the exposed metal plate that covers the motherboard and remove it. You should now see the CMOS battery in the bottom-right-hand corner of the motherboard. Remove the battery by gently pulling it up and off the motherboard. Replace it with the same model battery (available at any computer store or online). Reassemble the computer the same way you took it apart. Acer TravelMate 6592G Keyboard Replacement Guide http://tomkaminski.com/acer-travelmate-6592g-keyboard-replacement-guide
http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
Apr 01, 2013 | Acer Aspire One Netbook 8.9" Notebook
I tried to turn off my fingerprint security from acer travelmate 7730 laptop and now it started ask bios password. I dont know the password(never set it) three times wrong and system disabled and numb
hello try to connect the Acer support or search on Google for bios password. A lot of computer the come with a same bois password that company put on it. For example your Model is Acer may be the Company put Acer password for it . Even if you remove the bois battery from the motherboard and you see same thing again i think you will have to take it to Acer Branch the only help it their. i tried to find the password for you put can't find it. Please rate my comment thanks
Nov 21, 2011 | Acer Computers & Internet
Acer travelmate 2700 bios password and where is the CMOS battry on the mother board
your bios battery is soldered into the mainboard, its under the keyboard, next to the modem board and the bios chip itself.
In order to get to the battery you would first have to dissasemble the laptop, remove the keyboard, power buttons, and the top of the machine. You may also have to remove the display if its holding the top of the cover in place.
Removing the battery is no guarantee of reseting the password. You need to study the bios chip and find out which pins of it you need to short in order to reset its memory. In some cases the password might be stored on another chip.
Oct 09, 2011 | Acer TravelMate 2700 Notebook
How to Disable Acer Travelmate 240 BIOS Password?
To disable the bios password on your laptop, you will need to remove the cmos battery on your laptop for some minutes and insert back, the cmos battery is located on the motherboard of your laptop, once the cmos battery is removed from the motherboard for some minutes, the bios password will be reset, and the bios password will be disable.
Take care.
Nov 19, 2010 | Acer TravelMate 240 Notebook
Hi I am having a ACER TRAVELMATE 4720 LAPTOP I forgot the CMOS password kindly help me..
when I have had this issue in the shop, we would open the bottom of the laptop , find the cmos battery (looks like a watch battery) and short out its terminals for a minute or so. this will reset the bios to defaults, and likely dump any passwords set in the bios. if this helps you leave some feedback. Cheers
Aug 26, 2010 | Computers & Internet
How to remove keyboard to change cmos battery for Acer TravelMate 529ATX PC
I have an Acer travelmate 529ATXV and need to change the CMOS battery. I think it is under the keyboard but I am not sure how to remove the keyboard. Any help would be appreciated.
Mar 08, 2010 | Acer TravelMate 529ATX Notebook
Acer laptop does not boot up but gives no errors
Go to the Acer Website and see if you can update your BIOS. That's where the problem lies, in the future it is a good troubleshooting tip to either use a digital camera to take a picture of all your settings in case you need to revert back. You will have to go thru each section of the BIOS and change one thing at a time, reboot, and continue process until you find the error.
Pls rate this solution
Apr 21, 2009 | Acer TravelMate C100 Notebook
Where is the cmos battery for an acer aspire 1690 laptop
CMOS is usally on the back side of the laptop. you might have to take the back panel off. The bios is flashed onto the board its really not a chip that is interchangeable it is just there to hold the info for your bios
Feb 12, 2009 | Acer TravelMate 2300 Notebook
Acer Aspire 4720 Notebook Logo
163 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
