Question about Crane Frog EE-3191 1 Gallon Humidifier
Need to know how to use it?
What besides water do you put in it? How do you replace the light in them? we need an owners manual.
  • 903 Answers
Here's the link where you can download the manual, which will have everything you need to know about cleaning it and maintaining it:
http://www.crane-usa.com/manuals/HumidifierManual2008.pdf
Posted on May 28, 2010
Computation of load base to the cable size of the crane
Posted on Oct 21, 2010
I have one of these and I have no clue how it works, sometimes the water reserve catches water.. does that mean its dehumidifying? What are some of the settings I should put it on?
Yes, that means it's working, Basically, the lower the humidity setting, the more moisture it removes from the household air. The higher the setting, the less it will remove and run less, too. Once the water reservoir or "bucket" as most folks call it, is full the unit will shut off automatically and the bucket FULL light will come on. You will need to remove the bucket from the front of the unit and empty it (I prefer emptying it in the bath tub or shower). Then carefully replace it the unit, so that it triggers the safety switch and the FULL light goes out and the unit will restart automatically, if necessary.
You didn't list the model number of your Danby Dehumidifier. But all Danby units work pretty much the same. To help you further I have included a link to the Owners Manual for the Danby DDR25E (this also covers 2 other models) that you can download and print for future reference. Read it thoroughly and become familiar with it's operation and the required Routine Maintenance.
http://www.danby.ca/cms/uploads/products/en_manual
/DDR25E%2C_DDR30E%2C_DDR45E_EFOM.pdf
Hope this helped you. Please let me know. Thanks.
May 25, 2011 | Danby (DDR600R) Humidifier
How much water and where do I put it I don't have a manual.
Kenmore is a Sears brand. If you have the Model Number, go to http://www.searspartsdirect.com/partsdirect/brands/Kenmore-Parts and you can search for and download the Owners Manual.
Mar 11, 2011 | Kenmore Humidifiers
Is set to 60 end is no water coming
First, is the saddle 'T' valve open on the water supply line? If it's not turn it ON no water can fill the tank. If after that, it doesn't work, there may be a problem with one of the solenoids.
I have included a link to your Owners Manual, which may be of assistance, since it has a Trouble Shooting Guide.
http://www.autofloparts.com/manuals/autoflo-sc15-250-owners-manual.pdf
Hope this helps you.
Rich
Feb 07, 2011 | AutoFlo 250 Humidifier
Should water be continualing running through the drain tube?
Water will flow over the filter pad as long as the unit is calling for humidity. once the unit is satisfied the solenoid valve should stop the water flow. if the water continues to flow with out call then solenoid valve has failed open. hope this helps.suppling an owners manual in case you need one.
http://www.aprilaire.com/themes/aa/en/manuals/AA-Humidifier-Owners.pdf
Dec 21, 2010 | Aprilaire 600 Humidifier
On my Aprilaire 560 humidifier it says to replace water panel evaporator annually. Are there any documented instructions on how to do this?
Dear Reader,
If you visit aprilaire.com, you can go to the "OWNER'S CENTER" tab at the top of the page. With the cursor on "OWNER'S CENTER", more options will appear. Click on the "OWNER'S MANUALS" option. Scroll down to the bottom of the page and you'll get to a list of our older model humidifiers. Click on the first link which includes your model 560. By clicking on this link, you will be able to download the owners manual for your 560. On page 16 of this manual will be the step by step instructions explaining how to perform the water panel change.
If you have any further questions regarding this or any of our products, please feel free to contact our customer service department 800-334-6011 at your earliest convenience.
Kind regards,
Zach Handyside
Customer Service Specialist
Research Products Corporation
www.aprilaire.com
Nov 16, 2010 | Aprilaire 600 Humidifier
How do you set and or reset the "filter replacement"schedule on the April air #700 model?
The owner's manual reads "After the Water Panel is replaced, turn the Control knob to the “Test/Reset” position until the green “Humidifier ON” light flashes, to reset the Water Panel change timer."
Hope you find this to be very helpful.
Let me know if you have any questions. :-)
Mar 20, 2010 | Aprilaire 700 Humidifier
Aprilaire 600 - change water panel light stays on
Turn the control knob to the test/reset position untill the change water panel light blinks to reset the change panel timer. Make shure the furnace is running calling for heat.Turn control knob to prior setting after resetting timer. Hope this helps.
Feb 16, 2008 | Aprilaire 600 Humidifier
Honeywell HCM-525 owners/operation manual NEEDED PLEASE!
The filter should be located below the tank. the tank should lift off of the unit and there should be a rectangular cavity where the filter fits. You will most likely find the old filter dried up and filled with a white crust. That is salt and other minerals in the tap water that the filter catches.
Jan 01, 2008 | Honeywell HCM525 Humidifier
Crane Frog EE-3191 1 Gallon Humidifier Logo
531 people viewed this question
Top Crane Humidifiers Experts
Danny Kuhlmann
Andrew Taylor
Andrew Taylor
solver2010
Are you a Crane Humidifier Expert? Answer questions, earn points and help others
