Hi. I have a symphonic phonograph model 1716 telefunken west germany. I want to buy a nail for it and I wanted to know where to get it. I don't know what year it is from. Please give me an answer. Thanks.
Benimur
  • 6966 Answers
SOURCE: TELEFUNKEN TV DOES NOT SHOW PICTURE OR SOUND
Without knowing the specific model, I can only venture that somehow the Parental Lock has been engaged. Often to disable/disengage, a password/code of some sort is required with entry through the remote.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 26, 2008
janson0
  • 4 Answers
SOURCE: Mission Impossible Nintendo 64
Maybe you can watch and learn from here?
Posted on Apr 02, 2009
SOURCE: rpd 552 cd reader problem
Message Possible cause Recommended action
E-01 Dirty disc. Clean the disc.
Scratched disc. Replace the disc.
Up-side-down. Check the disc.
E-02 Focus error. Try ejecting and re-inserting
under normal temperature
conditions.
E-03 Data and focus error. Under normal temperature
conditions, eject and
insert clean, undamaged
disc properly.
E-04 Mechanical problem. Eject and re-insert.
Posted on Apr 06, 2009
SOURCE: Symphonic DVD/CD player SD200E
works like the denon 1910 heres a link to info if you have the european version im looking for US one my self to make it region free so i can play german DVD's pal
http://www.geocities.com/denon_1910/download.html
Posted on Jun 04, 2009
rowdy45176
  • 2176 Answers
SOURCE: were can i buy a instruction manual for a paslode
go to Paslode.com and you can download the manual for free. Let me know if you have any problems
Posted on Dec 11, 2009
I AM LOOKING FOR SCREEN FOR TELEFUNKEN MODEL TLCD 46 FHD
you must search in the Internet for to supplier Telefunken. This company is coming from Germany. EU.
God bless you
Oct 11, 2013 | Audio Players & Recorders
Need replacement battery for prs-950. Where to buy (in Germany preferred)?
I cant seem to find what you are requesting but I did find a service manual for your model (US and Canada model.) Sony does sell the part you need but I dont know if that are able to ship it to Germany.
Part Number: A-1792-542-A
Ref: https://www.servicesplus.sel.sony.com/sony-part-number-A1792542A.aspx?CSRT=2917644549430923001
Ref: http://projects.mobileread.com/reader/users/porkupan/PRS950/PRS-950_sm.pdf
Dec 21, 2012 | Computers & Internet
Need to find Telefunked 250 reel to reel belt for friction wheel # 339730710
Try fry's electronics, if they don't have it they should be able to cross reference or order it .
Mar 13, 2012 | Audio Players & Recorders
I want a MANUAL for TELEFUNKEN (radio machine 1958) Super Heterodyne D778 WK TROT. My father own this from my grandfather and it does not tune to radio stations. Please let me know if you can help us with...
Hi, I will do the best I can to help you. I remember these radios from my childhood. There may be some things you can do to help it tune to FM radio stations. On the back of the radio, there should be 2 screws referring to an "FM" antenna. If the radio is making a "hissing" sound through the speaker, but you are not picking up any stations, then connect a single wire about 1.5 meters in length to the screw labeled "FM antenna". The other screw, if it is labeled "ground" leave with no wire attached. Make sure that the wire you use does not touch both screws. The piece of wire should act as an FM antenna. If that is the only issue, then you should pick up radio stations.
That is a very well made, good quality radio, but it is over 50 years old.
Here is a link to Telefunken in Germany. They may be able to find a manual for you.
http://translate.google.com/translate?hl=en&sl=de&u=http://www.telefunken.com/de_DE/home/&ei=Vn46TYSVOcXegQfr3ZGDCQ&sa=X&oi=translate&ct=result&resnum=4&ved=0CDoQ7gEwAw&prev=/search%3Fq%3D%2522TELEFUNKEN%2522%26hl%3Den%26lr%3D%26safe%3Doff%26prmd%3Divns
I would suggest having someone fill out the request in English.
I hope I have helped you. Let me know.
Best Regards,
Mark
located the Telefunken website.
Here is a link to it.
Jan 22, 2011 | Audio Players & Recorders
Trouble recording records
When recording from a phonograph, I use the following items.
Depending on the phonograph whether or not it's MC or MM makes a difference in sound although most can't tell the difference. Also, you need to know if your phonograph requires a pre-pre amp or if that pre-pre amp is built in and the line coming out is at line level. The Rolls item is a pre-pre amp unit which takes to older phonographs signal level to that of input levels which allow the phonograph to be connected to any aux line in.
On the back of the computer, you can plug the RCA jacks from the phonograph into the adapter and directly into your computer via the MIC (usually pink) input. Most of the time this is sufficient. If the volume is too loud, or sounds horrible, chances are you have a pre-pre amp and you then plug it into the line in (usually blue)
First I would connect the RCA's from the phonograph to the adapter and plug it into the mic and see how the sound is.
Keep in mind that you do not use the ROLLs unit when connecting this way. If it's too loud or distorted, plug it into the line in.
For recording, you can download Audacity which is free and a wonderful editing program.
Nov 26, 2008 | Televison & Video
Delivery to Germany
Hey FrankyM,
Our Best Buy™ stores or BestBuy.com do not ship products to Germany. The only way I can see doing this is if you know someone in the U.S. that can buy what you want and then they can ship it to Germany for you. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 11, 2008 | Cameras
Telefunken, Model TTV (215E) HAD A CHILD LOCK
i had same problem with telefunken ttv2931 child lock, tried turning off power,holding power button on and pressing each button, found by accident that holding down the display button for 5 to 10 seconds worked.
Feb 05, 2008 | Televison & Video
44 people viewed this question
 Grubhead
Grubhead
