Question about Teledyne Laars END CAP - 10403800
Pool heater laar 350000btu
The pilot is on,but the propane do not come , no ignition.
  • 279 Answers
There are a number of things it could be. Check for an open High Limit switch. If that is okay, check the thermostat. If there is a way to use a jumper wire around it without hurting other componets, do it. If that is not the problem, I would look at the gas valve. That will be the most expensive part so try the others first. If you change the valve and it does not cure the problem, you may not be able to return it. Good luck...Lee
Posted on May 28, 2010
Convert Laars lite model lg125n to LP gas
That involves changing out the complete burner tray including the igniter/pilot assembly, burners and the gas valve. It runs deep into the cost of a new heater, (well over $1000, not installed).
Nov 27, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars lx won't ignite
hot surface igniter may not be hot enough to ignite the burners
Jan 09, 2013 | Teledyne Laars Laars Lx Pool Heater /...
Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
Apr 01, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
I replaced the ignition transformer in my Teledyne Laars epc325 pool heater and cleaned everything. When I switch the heater on the burners all work fine but they only cycle on for about 10 seconds then...
This is probally your ignition wire is bad and not reading flame at the pilot or your pilot is bent or something so that when the pilot lights the flame isn't hitting the sensor probe at the pilot. When looking under the heater use a mirror so if you get roll out of the flame you don't get burned. Good luck and be careful.
Feb 26, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot will stay on but burners will not ignite, checked all switches seem to be working allright, still no burner ignition
Possibly a flow switch not closed, or a limit switch open. May even be the pilot generator not producing enough mili-volts to operate the gas valve. Safest way is to have it serviced by a heating contractor. You dont have to call a pool company unless you wish.
Aug 20, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot will light but heater will not ignight
You may need to replace the Ignition Module. Have someone check to see if it is sending power. I have the same problem and need to replace the Fenwal automatic ignition system. The part cost $390 - check inside the heater for the model #
Jul 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars END CAP  - 10403800 Logo
Top Teledyne Laars Pool & Spa Experts
paulcarew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
