Question about Honeywell HV-180 Floor / Box Fan
HV-180 fanFan has dust on enclosed blades and on cover. Would like to clean. How?
    President:
  • 405 Answers
The blade cage has locks and screws that you can remove from the back. once the cage has been removed, you can remove the blade attached to the motor using a vacuum cleaner or you can remove the blades by undoing the screw on the center detaching it from the motor.
Posted on May 29, 2010
Dell inspiron one 2205 touchscreen overheating
Had a similar problem a non-touchscreen 2205 model. The cooling radiator was clogged with dust. You can unplug the power cable, remove the back cover and clean the dust out. I removed the cooling fan and used a toothbrush and vacuum to gently remove the dust matt from blocking the radiator. Use q-tips to gently clean the fan blades as well. Reattach the fan and the computer no longer overheated. By the way, Dell designed the 2205 with not enough ventilation. After cleaning. the CPU idle temperature ran at 39C with the back cover attached and only 29C with the back cover removed. The air flow intake for the cooling fan is taking in warm air due to the Hard drive heat being captured by the back cover.
Dec 30, 2013 | Dell Computers & Internet
Hello i have a hv-180 18" when i plug it in
Yes. These fans have thermal protection in the motor, as well. The thermal fuse or thermal breaker may be bad.
Mar 09, 2011 | Honeywell HV-180 18" Commercial Grade...
HOW DO YOU CLEAN THE FAN BLADES?
there should be just some sort of snaps, or hooks holding the guard on. I have yet to see a fan that doesn't. but if there is any, take the clips off of the guard, and clean the blades.
Aug 12, 2010 | Honeywell HV-180 18" Commercial Grade...
Motor just hums, won't turn
If you remove the cover screen and take compressed air or just a brush to clean out all dust and dirt from the motor the fan may run again
Dust is a standard contributor of these fans to quick turning
Aug 01, 2010 | Lakewood HV 18-c Floor / Box Fan
I have dust accumulation on the blades, and need to know how to open the housing to clean. There are two screws, on the top and bottom, that are irregular. The rest of them are Phillip Head screws. How do...
LOOK DOWN INSIDE THE GRILL OF THE FAN. yOU SHOULD SEE SOME SCREWS. IF NOT THEN THE COVER JUST SNAPS ON AND IT WILL TAKE A FLATHEAD SCREW DRIVER TO PRY IT OFF. hOPE THIS DOES IT FOR YOU. THE RAZ
May 13, 2010 | Honeywell HV-180 Floor / Box Fan
Cleaning blade not function
You will have to get a new image unit since the Cleaning Blade is enclosed inside the image unit. Or you can buy a drum kit and replace the drum and cleaning blade yourself.
Apr 13, 2010 | Konica Minolta DiALTA Di200 Copier
Dust under screen.
The camera has to be taken apart. First - the front cover, then the back cover. You will need some compressed air.
Tom
Sep 20, 2009 | Kodak EASYSHARE M1063 Digital Camera
Motor running a lot
9360gabbs,  The significant thing that you list is... it is louder than usual.  You indicate that you have cleaned the coils under refrigerator.  Try and roll the refrigerator out from its normal location so you can get behind it.  Remove the cardboard or metal cover across the bottom area of the refrigerator.  Check and see that the fan next to the compressor is running and that the blades are clean from dust, etc. Sometimes the condenser fan dies and must be replaced sometimes the blades are covered in dust, etc and causes a decreased volume of air to be moved by the fan.  Make sure the entire area is clean from dust, etc.  Be sure to replace the rear cover that was removed.  Very important!  Hopes this helps you! HandyHenry
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Cleaning a 14F0 Honeywell Fan
thank you for using fixya. The blade cage has locks and screws that you can remove from the back. once the cage has been removed, you can remove the blade attached to the motor using a vacuum cleaner or you can remove the blades by undoing the screw on the center detaching it from the motor.
Jan 04, 2009 | Honeywell HV-180 Floor / Box Fan
Honeywell HV-180 Floor / Box Fan Logo
329 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
Tom Chichester
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
