Question about Pds GE Profile Bottom Drawer Freezer Refrigerator Energy Star 22.2 Cu. Ft. Stainless Steel, PDS22SFS
I have a GE Profile 30" wide single door over bottom freezer drawer stainless steel model about 6 years old. The ice in the icemaker bin melts and refreezes solid and small amounts of water appear under the unit occaisionally. Is the drains clogged or is the ice maker leaking? Can I fix it myself or do I need a technician? Thanks Michael
5 Suggested Answers
SOURCE: removing freezer drawer
my son fixed it - thx. problem solved
Posted on Nov 24, 2008
tborn6
  • 700 Answers
SOURCE: GE Profile 25.1 cu. ft. fridge is too large for door entrance
yes you can, or just removed the bottom drawer, open the upper doors and slide the refrigeraro thru the doorway by just swinging it thru. a mover friend of mine showed me that trick at it work great.
Posted on Jan 24, 2009
heatman101
  • 43501 Answers
SOURCE: 16 month old GE Profile
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 12, 2010
  • 1796 Answers
SOURCE: GE model pds18sbmarbs stainless steel
Hi!!
The evaporator fan motor is located right in between freezer and the fridge compartment on top of item #19. The fan motor can be accessed thru the bottom of the fridge. Click on the following link if diagram below is not clear enough and to get parts names. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5100598&diagram_id=22155726#d22155726
To get to the evaporator fan motor, you need to remove item #2 or items #14 & #15 on the graphic depending on your model, to access the evaporator drain pan, item #8, the fan motor is attached to the back of the drain pan.
If you haven't bought the replacement fan motor, you should order it from this site, it is about $30 less than if you order it from GE.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Nov 15, 2010
How to remove samsung imc701 icemaker from refridgerator
Take out the ice bin, remove the side panel with a screwdriver, press down the lever on the front middle top of ice maker and slide out the icemaker, unplug the wiring on the side, you're done.
Jul 26, 2011 | GE Profile Energy Star? PFSS6SMXSS...
The GE side by side is roughly 10 years old and when the turbo cool bin is on it makes a rattle noise every 5 mins. like a toy gun sound. I turn it off and it stops. It only happens when the bottom bin...
It's freezer fan hitting with your bin drawer when it's over ice formed behind the freezer. It's due to malfunction of defrosting. Keep 5 degree thermostat setting. And check thermostat by turning counter clock wise. If shuts off the fridge, it's working. If not replace thermostat. Check defrost timer set in proper setting. Once defrost cycle is good, no banging sound will be there. Thanks.
Feb 01, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Melting/refreezing ice in the ice makes
If the ice is the only item that appears to be melting or defrosting. I would believe the most possible issue. The icemaker is leaking intermittantly into the bin and freezing the cubes inplace.
Ric
Mar 09, 2010 | Amana ABB2527DES Stainless Steel Bottom...
Freezer is warm at top and cold on the bottom.
Sounds as tho your evap fan is not running. Open door to freezer and should hear a fan running smoothly. If not most of the time the problems is with the main control board on back of refrigerator.
Jan 27, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ice Melting
ok check the door gaskets they must be toushing forming a compleate seal nothing else is acceptible also there is a possibilty that your ice maker heater is stuck in the on position.also these units are known for a having a bad control boared in the back
Aug 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
My GE Profile makes ice but then the ice cubes melt!
repl main board and make sure your out let is properly wired and grounded those main boards are sensitive when not grounded
Oct 29, 2008 | GE Profile PSW26P Stainless Steel Side by...
Dispenser doesn't dispense
ICE AUGER IN BIN IS BROKE,REPLACE,WATER VALVE TO DOOR WATER DISPENSER IS BAD,LOCATED ON BACK BOTTOM OF REFRIG.REPLACE,THANKS-MIKE
Mar 21, 2008 | GE Profile Arctica Stainless Steel Top...
Ice maker not working
have you felt water in the ice maker or ice cubes thats the only way you know for sure.. just cause water in doors works doesnt mean icemaker getting water.. got different valves giving water to different places Is your freezer temp. right.. has to be right temp for icemaker to work.. check back wall in freezer make sure no frost buildup and if fan working
Sep 02, 2007 | GE Profile PSW26P Stainless Steel Side by...
Pds GE Profile Bottom Drawer Freezer Refrigerator Energy Star 22.2 Cu. Ft. Stainless Steel, PDS22SFS Logo
127 people viewed this question
Top Pds Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
LARRY BARAN
LARRY BARAN
Level 1 Expert
Are you a Pds Refrigerator Expert? Answer questions, earn points and help others
