Question about Little Tikes Fold and Store Picnic Table
I need the stabilizer bar that attaches to the leg to hold the table open Where can I get one
How to attah table leg frame to table bottom panel?
Not quite sure what part(s) you're having problems with. But I'll tell you what I know...
There is a table top (a bunch of boards joined edge-to edge). Under this top is a skirt. The skirt is typically a box that doesn't need the table top for structural support - the legs are attached to the skirt (in the corners). Depending on how the skirt is designed, the legs may be removable (makes the skirt more complex).
Attaching the skirt to the table top can be done in many ways. The best way is to allow for expansion/contraction of the table top. The edge to edge combination of the table top makes for a larger expansion/contraction than the skirt. So the skirt should have a slot instead of a hole for a screw through to the table top.
If you just screw everything together, it will work. But if moisture and/or temperature changes, you may separate the table top, or joints in the skirt.
Apr 23, 2015 | Saws
Tip
All purpose presentation easel a DIY project
You never know when you are going to need or want an easel to show off your art work, maybe your kids want to finger paint who knows they could be the next Van Gogh. Building a display easel is very simple and can be done in just a few hours.
You want to start with two pieces of wood cut to 2x82" these pieces will form the front legs of the easel. Using a table saw cut the tops of the wood to a 15* angle. Take a measuring tape and measure 78" from the bottom of the wood (up to the angle cut) mark this spot on both pieces.
Using a drill, drill a 3/8" hole through the widest side of the angle as a right angle to the cut. Repeat for the second front leg.
To make the back leg cut a piece of wood down to 2x81" long, using your drill, drill two 3/8" holes in the widest side of the wood. One hole should be 39" from the bottom of the wood and the second at 74" from the bottom.
Your art work needs something to sit on so to make the cross bar cut a piece of wood down to 2x47".
Now you are ready to assemble your easel. Take the front and back legs and lay them on the floor next to each other with the back leg in the middle. Rotate the front legs to the angle is facing the back leg and line up the holes. Slide a bolt into the hole and place a washer and a nut on the end, keeping it loose enough to adjust the angle. Stand up the easel and spread the from legs so that they are 45" away from the back leg. Tighten the bolt and you have the angle right and lay it back down.
To attach the cross bar, measure 38" up from the bottoms of the front legs find the center and drill a 3/8" hole in each and bolt the cross bar to the legs. To keep the legs from spreading too far you can attach a chain between the cross bar and the back leg. To do this you thread the chain through the hole in the back leg and tie it off. Attach an eye screw to the cross bar and loop the chain through it to keep limit how far the legs can spread to the angle that you want to work or display at.
on Jan 29, 2014 | Office Equipment & Supplies
Table broken leg
You need some kind of screws/bolts to hold the broken pieces in place before you can apply glue. At the end of your video, you showed the bottom view of the legs. If you can drill some holes at good positions, you should be able to put bolt and nut to hold the legs in place. Then, you can use super glue to keep the surfaces smooth.
Apr 11, 2014 | Furniture
I need instructions to put Wilton's 3 tier party stand together
According to Wilton:
You should have 8" plate, 10" plate and 12" plate
Match the sizes with rings and legs on table.
Attach legs to serving rings,twist threaded end securely into housing on each serving ring. Tighten using wrench.
Attach 8 1/4 Serving ring to Center Footed Base Ring -Position serving ring with footed leg out. Line up the other 2 legs with the correct housing on the base ring, the width between housing should be same as that between legs.. Insert end of legs into housing.
Next attach 10 1/4 Serving ring to Base Ring, You will need to move clockwise around base ring to attach this ring. line up legs and insert legs and tighten.
Attach 12 1/4 serving ring to base ring. Insert legs into last pair of housing on the base ring.
Position plates so lip edge rests inside serving ring.
Apr 16, 2013 | Wilton WHITE 3-TIER CUPCAKE STAND...
How do we close 1 1/4" gap between two sides of table
You probably have either (a) not properly extended the legs all the way, or (b) have attached some of the cross beams on the wrong side.
http://www.sears.com/prince-fusion-table-tennis-table/p-00601215000P
click on this link and you can move the magnifying glass over different parts of the picture to see up close what the table should look like in the correct and finished position.
Dec 15, 2012 | Prince Fusion Table Tennis Table
What type of bar stool is best for overweight individuals?
The best type of bar stool for someone who is overweight to sit in is a floor mounted stool. This type of stool is securely attached with bolts to the floor beneath it, ensuring better support and stability. If you don't want to bolt down your stools, your next best option is to get a four-legged stool. Four-leg bar stools disperse the weight of the person sitting on them evenly. On the downside, four-leg stools have a higher risk of tipping over.
Jul 24, 2012 | Furniture
What is a pilates machine or reformer?
The reformer's basic components include a frame, headrest,foot bar and a sliding platform with attached springs that glides back andforth on rollers. An assortment of adjustable accessories--springs, cables,bars and pulleys--is used to create resistance and allow the body to perform anumber of exercises while standing, sitting or lying down. Leather straps, orropes, facilitate correct positioning of arms and legs, and an adjustableheadrest helps to insure stability and proper breathing patterns. The standardstudio reformer is elevated on four legs. For clinical or hospitalrehabilitation, machines that lie flat are also available.
Jul 09, 2012 | Exercise & Fitness
I need to know the name of the two short bars on the back side of the axel that keeps the van from swaying back and forth
sway bar links or stabilizer links? One end is attached to the stabilizer bar and the other end is attached to the strut I believe.
Nov 03, 2010 | 1999 Chevrolet Venture
How to replace a sway bar end links to a 94 intrepid
REMOVAL & INSTALLATION
The rear suspension on LH platform vehicles is a fully independent suspension. A stabilizer bar (also called a sway bar) is mounted in rubber isolator bushings and connects the rear struts through links. Note that the fuel tank must be removed to remove the stabilizer bar.
CAUTION OFF. The fuel system pressure must be relieved before disconnecting any fuel lines. Failure to do so may result in fire and/or personal injury.
  1. Disconnect the negative battery cable. Relieve the fuel system pressure.
  2. Raise and safely support the vehicle.
  3. Remove both rear wheels.
  1. Position a transmission jack under the fuel tank just forward of the crossmember to help support the fuel tank when crossmember is removed.
  2. Remove the four crossmember to frame rail attaching bolts. Remove the fuel tank.
  3. Remove the stabilizer bar to link assembly attaching nuts and remove the bar and isolator bushings as an assembly from the vehicle. Inspect the isolator bushings for damage or excessive wear and replace, if necessary.
To install:
  1. Inspect for broken or distorted retainers and bushings. If bushing replacement is required, replacement bushings can be installed by locating the split in the bushing, prying open and removing the defective bushing from around the stabilizer bar.
  2. Install the stabilizer bar and isolator bushings back into the vehicle as an assembly making sure bar is centered in vehicle so it doesn't contact other suspension components.
  3. Install stabilizer bar attaching link onto stabilizer bar. Install new link to bar attaching nuts and tighten to 70 ft. lbs. (95 Nm).
Replace the sway bar bracket bolt with new after loosening or removing them. Only use original equipment bolts as replacements.
  1. Install the fuel tank back onto the vehicle.
  2. Position the crossmember on frame rails and install four mounting bolts. Tighten attaching bolts to 70 ft. lbs. (95 Nm).
  3. Remove transmission jack from under the fuel tank.
  4. Install the rear wheels and lug nuts. Tighten the lug nuts, in a star pattern sequence, to 95-100 ft. lbs. (129-135 Nm).
  5. Lower the vehicle. Reconnect the negative battery cable.
  6. Pressurize the fuel system and check for leaks.
  7. Check and reset the rear wheel toe to specifications as required.
Jul 03, 2010 | 1994 Dodge Intrepid
Front Sway bar(Stabilizer bar)
please give good rating if this helps
Section 04-01: Suspension and Wheel Hubs, Front 1996 Taurus, Sable Workshop Manual REMOVAL AND INSTALLATION Stabilizer Bar Removal
  1. Raise vehicle on a hoist. Refer to Section 00-02 .
  1. Support vehicle with hoist or safety stands behind front sub-frame (5C145).
  1. sth~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use extreme care not to damage boot seal. Do not use power tools to tighten nut, or bearing and seal damage will result. Install nut using hex hold feature to prevent the stud from rotating.
    Remove and discard nuts retaining stabilizer bar link (5K484) assembly to front stabilizer bar (5482) and front shock absorber (18124) with an 8 mm closed-end wrench and an 18 mm open-end wrench.
  1. Remove nuts retaining steering gear (3504) to front sub-frame, and move steering gear off the front sub-frame.
  1. With another set of support safety stands under front sub-frame, remove two rear subframe retaining bolts. Lower rear of the front sub-frame to obtain access to stabilizer bar brackets (5486).
  1. Remove front stabilizer bar U-bracket bolts and replacestabilizer bar brackets and/or front stabilizer bar as required. Discard lower suspension arm stabilizer bar insulator (5493) and bolts.
Installation
  1. Clean front stabilizer bar to remove dirt and contamination in area of stabilizer bar insulator installation position.
  1. Lubricate inside diameter of new lower suspension arm stabilizer bar insulator with Rubber Suspension Insulator Lube E25Y-19553-A or equivalent meeting Ford specification ESF-M99B112-A. Do not use any mineral or petroleum based lubricants as they will deteriorate the rubber lower suspension arm stabilizer bar insulators.
  1. Install new lower suspension arm stabilizer bar insulators onto front stabilizer bar and position them in approximate location.
  1. Install stabilizer bar bracket on front sub-frames and install new bolts. Tighten to 30-40 Nm (22-29 lb-ft).
  1. Raise front sub-frame and install new front sub-frame-to-body retaining bolts. Position steering gear onto front sub-frame and install retaining nuts. Tighten to 115-135 Nm (85-99 lb-ft).
    Install stabilizer bar link to front shock absorber and to front stabilizer bar, making sure that the stabilizer bar link is properly positioned. The letters "Top LH" and "Top RH" are moulded into the stabilizer bar link for correct assembly to the front shock absorber strut.
  1. Install new nuts and secure stabilizer bar link assembly to front stabilizer bar and front shock absorber. Tighten to 77-103 Nm (57-75 lb-ft) at front shock absorber strut and 47-63 Nm (35-46 lb-ft) at front stabilizer bar.
  1. Remove safety stands.
  1. Lower vehicle.
Apr 11, 2009 | 1995 Ford Taurus
Little Tikes Fold and Store Picnic Table Logo
35 people viewed this question
Top Little Tikes Toys Experts
 Russ Hill
Russ Hill
Brett Duxbury
Brett Duxbury
Bill Boyd
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
