Question about HP Pavilion dv6000z Notebook
Monitor going berserk
Occasionally my monitor on my labtop will start rolling so fast all i see r horizontal lines
    Scholar:
  • 58 Answers
This could be due to corrupt display drivers on the notebook or the video card is going to die. Try updating the graphics drivers on the notebook and check for the issue.
If the issue still persists, then to isolate the exact cause of the issue, I recommend you to connect an external monitor to the notebook and check for the issue on it. If external monitor works fine, then the issue with LCD display screen of the notebook. In case, if the issue persists on external monitor then it states that the video card of the notebook is going to die.
To connect an external monitor to the PC, follow the steps listed below:
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
Posted on May 28, 2010
My ACER P126HL monitor keeps displaying a network of colored horizontal and vertical lines and I need to reboot to return the display to normal. Is it the driver or my video card?
I would open the device manager (in the control panel) and locate the video card driver, then roll it back to a previous version if it will let you do that, then reboot. My computer with a ATI graphics adapter downloaded the driver update and mine went crazy until I rolled mine back. I then turned off automatic updates so I could always choose not to update that driver in the future.
Sep 10, 2014 | Acer P216hl 21.5" 1080p 16:9 Widescreen...
Picture displays horizontal roll
It's the Satellite Disk that is the problem. Just call the guy..
you can also try to unplug and plug it back in.
Oct 23, 2009 | Philips Magnavox 20MS3442 20" TV
Rolling Waterfall Effect going up my westinghouse LCD monitor
try moving the monitors.
it could be feedback signal.
also try different leads or without switch.
you will then be able to narrow down the problem to one component.
Feb 25, 2009 | Acer AL1711 17" LCD Monitor
LG Flatron 795FT Plus - horizontal lines on screen
YOU NEED TO CHECK TO SEE IF THE CAPASITORS ON THE POWER SUPPLY AND MAKE SURE THERE NNOT BULGED OUT OF LEAKING IF THEY ARE THE NEED TO BE REPLACED
YOU SHOULD BE ABLE TO FIND EVERYTHING YOU NEED AT RADIO SHACK FOR LESS THEN 20 BUCKS
Feb 03, 2009 | LG Flatron 795FT Plus Monitor
Rolling horizontal line on screen
What was the reason for aquiring a new monitor?
Nov 23, 2008 | LG Computers & Internet
Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Oct 22, 2008 | Sony KV-32S66 32" TV
Monitor problem
Appreciate the "Ask Me".
I am assuming that you have more than just familiarity with electronic components and circuitry, the use of a DVM and a soldering iron. Further, that you have access to a service manual.
Width problem is basically insufficient horizontal deflection, then analysis would have to be in the horizontal section. Areas to initially focus on:
  1. 12V line and pin 29 of IC401;
  2. 110 V peak to peak at collector of Q403, if yes check Q 402 & 404 as well as T401;
  3. other components that affect the horizontal size are:
  • IC201
  • Q 405, 406, 407 & 408;
  • D409
  • L401
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 06, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Heavy white lines accross the screen
Replace it, it is going bad. I could tell you what would cause this such as bad driver IC etc. but bottom line is its five years old, you got your moneys worth out of it so bite the bullet and get a new one.
Feb 11, 2008 | Envision EN 9110 19" Flat Panel LCD...
Very fast lines appearing on screen
it is due to video failure
check computer to monitor cable for loose.
check crt base for loose.
check connector going to crt base
check for video supply.
if you are not tech person take the tech help.
good luck.
Oct 15, 2007 | LG Studioworks 563N 15" CRT Monitor
HP Pavilion dv6000z Notebook Logo
212 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
