Question about Miele W404 Washer
Dosent spin at end of programe has to be done manual
  • 327 Answers
Hello,If you are having a problem with your top load washer then check out this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
Thanks
Posted on May 28, 2010
GE GFWN1100LWW. Can the high speed spin work on the lower wash cycles?
From my experience, the lower wash cycles are set to only do certain things. For example: the Delicate won't do a high speed spin, even though a high speed spin wouldn't really be destructive to delicates, but would force more water out of them! I usually just run a "Drain/Spin" after the Delicate cycle.
Nov 27, 2015 | GE Washing Machines
My creda simplicty washing machine W200FW) is not finishing programs - it spins and fills but doesn't end - on a rinse cycle it just keeps spinning with water in, on a spin cycle it will drain but on
This is sometimes caused by water not exiting during or at the end of the wash. I have also encountered door lock issue for the same reason.
Jan 21, 2015 | Creda Washing Machines
Wme8227b broken?
Possibly blockage in pressure system
Jun 13, 2013 | Washing Machines
Electrolux EWF 1495, Starts but dosent wash. Drum turns about twice then stops for a couple of minutes, turns then stops. It then indicates cycle ended but didnt rinse, spin or drain or spin. These can be...
OK, first remove the rear access panel. You will see a drain boot going from the tub to the pump. You will need to remove that boot and inside is a filter that you need to clean out. Reassemble and run a load and let me know what happens.
Dec 02, 2012 | Electrolux EIFLW55HIW Front Load Washer...
Zanussi washing machine pause button flashing machine wont work iz141s
Disconnecting the wires from the main PCB helped resolve half the problem, but the machine still does not rinse and spin. Unless programmed manually. Still, that's easily done at the end of a wash cycle. Is liveble.
Jul 24, 2012 | Zanussi ZWF1440 Front Load Washer
Washer won't spin water out
it could be the last programe is not finnished and it is stuck on it. i had this problem when the macheane cut out from out of balance and then would not spin, always got code E03 finaly after two day i found the electronics where stuck on the last programe, hence done a wash as normal untill the time was up then it stopped saying end only half way though the new wash so i set to stop and then to spin and it worked again and has worked ok since. i hope this helps someone i could not find any info on a reset button for the system ?????
Jan 01, 2011 | Washing Machines
Where is the drain pump (and how do you access it on the Neptune MAH6700 front load washer?
i have maytag neptune mah6700 and dosent rince good in the end of each wash the cloths steell to mutch water in the cloths dosent rince it good i thing the speed of the spin not that strong and the motor its very good but i thing is someone played with the fron the code and i dont have the manual to check those code
Oct 03, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Brush bar dosent spin and the belt is still in tact
Hi there SmartAlec from NelsonVacuums.com.au here. Sounds like you have a brush roller bearing or bearings problem. Undo the base plate off your dyson vacuum cleaner and remove the brush it will be toughto slide it out but can be done. Hold it in your hands and see if it turns freely if not you can try and remove the end caps (bits on end of brush) and clean it out with an air compressor or small brush.Put the caps back on and retest. If its greatly improved excellent refit and vacuum. If its not freely spining it will have to have new bearings or replace the brush complete ads they are not very dear. I can supply a brush for you to buy if you are not near a parts shop. hope this helps regards SmartAlec.
Happy Vacuuming :)
Aug 10, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Drum will not spin
I am the new owner of a used Asko Cylinda 10504.
The last owner briefly demonstrated the washer starting a wash cycle and entering the agitation cycle of the wash before stopping and pumping the water out and spinning in a final end cycle. I bought it. I had the machine installed turned it on and cannot get it to go through the wash cycle. After starting at #1 it goes through a perpetual spin cycle of sorts--water and soap soaking the drum and laundry but not enough water to fill up half way or less. It stops at number 4 on the program knob sits on a red dot (next to the #4) and does nothing. I then manually move it to the next cycle and it repeats the spin cycle again until I have advanced the program to the end. No wash cycle no rinse cycle. Nothing. When it advances to the red dot I wait for at least 5 minutes before manually advancing the knob. The instructions say that I should get the water pumped out by turning the program knob to #7 or #9 but in both cases it just spins and does no empty or finish in the end spin cycle of several (9?) minutes. Nothing but banging and spinning. The water seems to get into the drum as well as the detergent but nothing else is happening.
No mater where I start the program it spins and sloshes soapy water, pumping almost nothing out.
Any suggestions short of putting it on the curb or paying a kings ransom to fly a tech out to look at it?
MY GUESS.
It seems that it is repeating the same brief cycle over and over. During the move to my house the electronics re set(??!?!?) and now need to be set to the normal mode after being re connected?
Can you help?
Blessings,
Douglas
May 20, 2009 | Asko Washing Machines
Miele W404 Washer Logo
203 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
