Question about Canton AS20 Subwoofer
Canton Sub not working
I have a Canton AS CD 1 subwoofer, it powers up, well, the little led lit up at least, but no sound. I have run it via coax, as well as passive from my receiver to the binding posts, no luck. I then took the unit apart and visually inspected the board, nothing out of the ordinary. I then connected speaker wire from my receiver directly to the speaker cone, bypassing the circuit board, and I got sound out of the speaker, so obviously, the problem is within the circuit board.
And a bit of history, I work for a AV installation company, and we pulled this from a clients home who said it stopped working, we installed a new system, so this was garbage. So I thought I would see if i could get it working. All the settings on my receiver are fine, as well as all the cabling.
Any help is appreciated.
2 Suggested Answers
  • 586 Answers
SOURCE: Canton Movie 120 MX wiring diagram
For connection of the wiring please see the give below instructions and pic.
Hope this will help you.
Thanks.
Posted on Nov 24, 2009
Aperion bravus 10d subwoofer no sound
The amp inside the sub has failed. Basically a sub is a mono power amp with a speaker. Though it seems to be getting power it could be that the main semiconductor that does all the work has gone open circuit. If it went short-circuit it would have killed the fuse and power.
Nov 20, 2017 | Aperion Audio Players & Recorders
How do i connect subwoofer (canton movie 125 mx) to amplifier(onkyo txnr609)? there is one subwoofer output on the amplifier with either L & R(mono) high level input or L & R(mono) low level input...
Connect front the sub out (single) on the amp to one of the rca inputs on the sub, This will work reasonably well but to make the most from the sub buy a 2 rca to 1 rca cable and use it to connect both rca inputs on the sub to the single output on the amp
Mar 10, 2012 | Canton Movie 125 MX Speaker
Hi ive got a b&w as2 subwoofer but theres no sound? the power light works but my denon recievers not picking up the sub is there a fuse in the sub which may have blown ive tried all the settings on...
Are you running this subwoofer via an LFE (RCA line level) connection, or via high level (speaker lines in and out of the subwoofer)? There may be different ways to hook up this unit and it would be helpful to know how you have the unit connected. Thanks!
May 04, 2011 | B&W Audio Players & Recorders
Well I also have a S112PS AR Sub Woofer Problem...
Are you sure it is receiving an audio signal to make it wake up? You don't mention what's upstream in the audio chain.
To eliminate mis-settings or lack of sub-related signal upstream, plug an RCA cable from a CD player directly into it and start a CD that fades in slowly because you won't have any way to lower the volume except to pause the CD. If the sub works you'll hear a muffled version of the program.
Apr 09, 2010 | Acoustic Research S112PS Subwoofer
Hello. I have one (1) XS-L1035 being powered by a JBL gts 180X 2/1 channel amp. The sub works fine if i power two(2) subs thru 2 channels BUT if I try to bridge the power to one sub the amp cuts out. Is it...
It sounds like the problem is with the amp. try using the other sub in bridged mode and see if it still turns it off. If it still turns off then its definitely the amp. In 2 channel mode you are using each channel at 4 ohms right? and in bridged mode to 1 speaker it should be throwing a ton of power on a 4 ohm load as well,it should work fine bro -its gotta be the amp
Jan 30, 2010 | Sony XS-L1035 Car Subwoofer
No sound from subwoofer Solo Baric L7
check the resistance of the sub with a digital multi meter, make sure you dissconect the sub from everything before you check the resistance, if your sub is supposed to be 4 ohms than it should be between 3-5 ohms, if it is under 1 that the sub is blown, while the sub is dissconected from the amp, turn the system on, does it still go into protection?
Jan 17, 2010 | Kicker Solo-Baric L7 10'' Car Speaker
Thanks.
Nov 24, 2009 | Canton Audio Players & Recorders
My calibra amp lit the red power led (to show protection )now my subwoofer won't play
disconnect sub woofer , amp may reset and light will be steady , if so replace wireing to sub and sub its bad
Oct 06, 2009 | Car Audio & Video
Is amp big enough for speakers
To run 2 subs, the amp would be a little small. The subs will run OK, they just won't be very loud.
It's usually better to compare and match up the RMS power rather than the peak power. The Sony XS-L10P5B sub has a peak power handling figure of 1200 watts, but the RMS is 300 watts. The Sony XM-ZZR3301 monoblock amp puts out 1100 watts peak, but only 330 watts RMS. They would work great together, 1 sub, 1 amp. But if you add another sub, each one would only be getting about 165 watts. They'd work OK, just not as loud as they could be.
Hope this helps!
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Power LED lit, Servo LED lit as well, no output
check the power cables on the amp and the inputs.isome time when ground cable disconnect the lioghts will light up any way. depending on the way ur vehicle is ground ed .toyota chssis r usually posite un like the norm which is neg.rating please
Jan 21, 2008 | Infinity BASSLINK Car Subwoofer
Canton AS20 Subwoofer Logo
370 people viewed this question
Top Canton Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Canton Audio Player and Recorder Expert? Answer questions, earn points and help others
