Question about HP LaserJet P2015dn Printer
Printer failure, the printer can not recognise commands
  • 241 Answers
The printer may have mother board issues. This has been a big problem with this printer model. If your printer is still under warranty I suggest you contact HP and have them fix it under warranty, if not take it to your certified printer technician to get assessed and see if it is worth spending the money to have it fixed or replaced.
Posted on May 28, 2010
I have canon ip1880 when i give a print command it shows the message on my monitor ink cartridge cannot recognised - color
Solution: press and hold (10 second) reset button/resume (Button reset/resume, under the power button)
Sep 23, 2011 | Canon Office Equipment & Supplies
"Ink cartridges not recognised" it
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Mar 12, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Printer doesn't recognise the color ribbon and print only in mono.
Try !SA command to calibrate ribon and printer, send command from the driver
Oct 07, 2010 | Zebra P330i Thermal Card Printer
Cartridge not moving from one place to another
check if there is any particles or dirt on the track. If not responding to the command, then disconnect the printer and uninstall the printer. Reinstall the printer software and connect the printer. The new harware will be detected and installed fresh. Now the command should work the printer, if not I am afraid the printer harware is faulty, a possible failure of the drive mechanism circuit/motor. I hope you check this out. Find me helpful? Good day
Aug 18, 2010 | Canon Office Equipment & Supplies
My x4650 is not recognising when I refill the black 36XLA cartridge. Just keeps telling me it is empty. There is not a problem with the cartridge itself just the failure to recognise it has been refilled....
turn on/off, unplug, plug in2_bing.gif, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats. or take cartridge out and put back in to insure in securely.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | Lexmark X4650 InkJet Printer
HP M1522nf not recognised by computer
No longer a problem as Hard Disk completely failed - suspect that imminent failure may have been a contributory factor.
Oct 15, 2009 | HP LaserJet M1522nf Multifunction Printer...
Error code when copying... C6103 on Bizhub C451
C6103 - Scanner overrun failure
The Scanner Home Sensor detects the Scanner at its home position during a period of time that begins with the time when a prescan command
and a scan preparation command are executed and ends when a home return command is executed.
Apr 14, 2009 | Konica Minolta bizhub C450P Laser Printer
Failure of Hp photosmart printer
hmm..
remove all s/w for printer through add/remove
then go to www.hp.com and get full version for your model and operating system
re install
http://tinyurl.com/6qcpgy
Aug 19, 2008 | HP Photosmart C6180 All-In-One InkJet...
Lexmark x 1185 on windows vista
hi you can get the drivers from lexmark site here Windows Vista --
if you need em for download
riz.
Apr 25, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Installing HP 1410 All In ONe Printer
change the directory off istalation and it will work
Oct 24, 2007 | HP PSC 1410v Printer
HP LaserJet P2015dn Printer Logo
110 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
