Question about Northstar Explorer 550 GPS Receiver
After the wiring for 550i to Navman 7200 VHF - Northstar Explorer 550 GPS Receiver
Uniden um425 vhf to navman trackfish 6600 what coloured wires do I connect.
Hi Gil!
Easy peasy.
From your 6600, the data sends are the white wire NMEA (+) and the black wire (-). There are two black wires. Doesn't matter which one you use as they're interconnected anyway.
To your UM425, the green wire is NMEA in and the bare wire is ground.
So...
white from 6600 to green and
black from 6600 to bare.
Hope this helps you out.
-Steve
Jan 09, 2015 | Uniden Boating
Cant connect to Navicom RT550 VHF radio
Could you please give me a little more information on your problem?
Oct 16, 2011 | Navman TRACKER 5505 GPS Receiver
My navman 7100 vhf radio is mall functioning. the buttonns on the mic are doing different options than what they are suppose to do. also unable to transmit messages but can make mmsi digital calls, i can...
Too late to help op, but trying to fix one with same symptoms, found a broken wire in the microphone cable near the handset, as I'd suspected. The cable appears to be a curly shielded 8 conductor, one of which (presumably the mike) appears to also have a shield - found a seller on ebay US that appears a suitable cable for about £16
Jul 16, 2011 | Navman GPS
I am not good with electronics. Have bought a jensen antenna for a tv - tv611 - how does the UHF n VHF wires both fix into the 300/75-ohm balun????
Go to walmart but UHF/VHF connector,one that you can connect both wires too and then plugs into TV.Cable IF
Aug 21, 2010 | Televison & Video
IC-M302 VHF Marine Radio: need to have wiring schematic coming out the back ...
Blue: Speaker (+)
Gray: Speaker ( -)
Yellow: NMEA IN (+)
Green: NMEA IN (- )
May 17, 2010 | Icom IC-M302 VHF Marine Radio
Need 5 pin wiring code for Navman Tracker 900 marine device
Dan,
Did you receive the color wiring following order? I ask this because I need the colorcoding as well. If you have please mail me chrisjord4@zeelandnet.nl
Kind regards Chris Jordan Holland
Apr 23, 2010 | GPS
Navman VHF 7100 Radio neither receiving nor transmitting
I would suggest checking your antenna/coax connector. I am not sure what kind of antenna or ,mount you are using but I would suspect it being something in the antenna. Most radios are designed to not transmit if the antenna is broke or not connected at all. When you say bent do you mean metal bent or bent at the base? So that would be where I start. Can you try a different antenna? Hope you track it down. N5ARK
Aug 10, 2009 | Navman Tracker 5600 GPS Receiver
Icom vhf radio
i have the same unit. i get interferance from my depth finder wire touching the antena wire off the back of the radio. make sure that no wires are touching the antena wire.
Aug 12, 2007 | Icom M302 VHF Radio
Northstar Explorer 550 GPS Receiver Logo
107 people viewed this question
Top Northstar GPS Experts
Jose Ma DM.
Jose Ma DM.
Are you a Northstar GPS Expert? Answer questions, earn points and help others
