Question about HP LaserJet 4 plus Printer
KEP THE MACHIN IN THE BEST CONDITION TO THE EXTENT POSSIBLE.
IT HAS BEEN FOUND THAT PEOPLE WHOME WE HAVE COME ACCROSS ARE NOT FAITHFULL IN GUIDNG TO MAINTAIN THE MACHINE WITH THE BEST RESULT.
MADESH.Y.G
    Brigadier General:
  • 10,406 Answers
Thanks for the information.
Posted on May 28, 2010
Green static lines accross tv when switching on then after a while disappears
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 15, 2014 | Televison & Video
I have an LG 42'' PDP42V60001 plasma TV it has a white line running from top to bottom covering around a 1/4 of the screen, it moves accross the screen and the rest of the screen is black. Intermittently...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 17, 2017 | LG Televison & Video
Basement flooded now hot water tank does not work
Where flooding has occurred, the entire burner and pilot assembly should be removed, inspected and if it possible to clean or repair these items, the heater may work again.
However, the problem is there isn't any good way to determine the extent of damage that may have occurred. Only a qualified technician should attempt this work and inspect the entire heater.
Depending on the extent of the damage that occurred to your dwelling, it might be best to add the water heater to the homeowner's insurance claim.
Dec 11, 2009 | Water Heaters
Copy machin SHARP SF-7320
Check the copy lamp and its thermal fuse if they are okay, then clean optics, check drum and blade and clean or replace and finally clean or replace fuser rollers. If the above is ok and still black copies, check the copy lamp wire harness for continuity or the copy control board located underneath the display panel and check for bad component like triac and replace. If OK replace the main control board.
Sep 21, 2009 | Sharp SF 2020 Copier
Having a new floor in the kitchen and my faithfull
Buy a machine that will is the first thought , otherwise get the kitchen fitter to raise the worktops above the washer
You could try taking off the top lid and removing the feet underneath which will give you some room
Make sure that you place a sheet of plastic over the top of the machine from side to side and tape it in place if you do remove the top
That is in case you spill anything on the worktop which then drips inside the machine
Sep 16, 2009 | Zanussi FLE1416W Front Load Washer
Horizontal grey lines accross screen on Panasonic LCD PT-43LC14
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Aug 08, 2017 | Panasonic PT-43LC14 43" Rear Projection...
Seiko watch mechanism replacement
nice day to you! your watch is need of general cleaning and recondition ,efter cleaned and condition the machin ! be sure that the case back gasket is good and apply a small amount of silicon greas to avoid water damage ! close it verry tight ! good luck !god bless !
Sep 02, 2008 | Seiko Watches
HP LaserJet 4 plus Printer Logo
27 people viewed this question
Seeker5211
Seeker5211
