Yo need to get some space on your disk check it out and delete something.
Did you check that the sd card is not full?
If it is not that the sd card is full you may need it to connect to a computer and do a reinstall of firmware.
If it is completely jammed and does not connect to a computer you will need to take it to service to have the firmware reinstalled
Here you can download the firmware.
If you breack the procedure while updating firmware, you can damage your mp3, then be careful.
If your Coby is completely fried up check your guaranty and eventually contact Coby.
If is not under guarantee find a service in your area, eventually contact factory to get directions for service in your area.
Nothing functions. I've taken the battery out several times, replaced the SD card several times, tried to turn it off and on and the display only says "Memory full" at all times.
I used a new SD card. I tried formatting the internal and external memory with and without the SD card. The player is completely locked up. It won't display any files when connected to the computer. It will not accept transfers, firmware, or even formatting. It will not erase files, either.
