Question about Epson Expression 1680 Professional Flatbed Scanner
I have a transparency adapter for my 1680 which
I have a transparency adapter for my epson 1680 which has worked well for a number of years. Recently, when we attempt to import a scan, we get message to 'close the lid' and the lap moves back and forth a short distance repeatedly. Any ideas?
5 Suggested Answers
Davroslives
  • 29 Answers
SOURCE: Scanning slides with the Epson Perfection 1250
To be honest, I have no idea of how you were able to scan larger transparencies in the past. The scanner and its software were never designed to do this and there is no workaround.
Posted on Sep 10, 2007
  • 110 Answers
SOURCE: Scanner wont scan transparencies properly
On the 4990, make sure that you have unlocked the lid of the scanner. The lock is located underneath the lid.
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Posted on Aug 22, 2008
cookiestork
SOURCE: Transparency adaptor won't close
Remove the transparency adaptor from the scanner bed (unscrew the two smaller screws, then slide back and off) and then remove the glass (and plastic frame) of the transparency adapter (there are six screws).
By the hinge there is a small white plastic switch. Usually the transparency adaptor hits this when it's closed, letting your computer know that it is ready to scan. What I did, as bcvideo did, was take duct tape and firmly taped the switch to the side of the transparency adaptor, using several small strips of tape.
The scanner works well now. You may need/want to put something on top of the scanner if it does not fully close.
Posted on Aug 21, 2009
  • 526 Answers
SOURCE: Epson Perfection 1200 Photo Flatbed Scanner Transparency Adapter
it could be a couple things without looking at it. one, the one you got also is bad.
two, the bent prints from the first one, may have ruined the interface boared on the scanner.
three, are you sure you have it setup for the transparency.
four, the bulb could bad on the transparancy adapter.
Posted on Dec 20, 2009
Just bought it at thrift shop,new never used, no instructions, How do I use? can I use it on any scanner?
No these only fit on epson scanners due to the specific plug on the attached cable.you need and epson most models from 1200 series,1600 or 2400 series or 3600 will accept the transparency adapter.i have an old 1640 series that has one of these adapters.you can source a cheap scanner off eBay and download the drivers off epson site.then attach the scanner AFTER you install the software and it will find the scanner and connect to computer.Epson do provide a good scanning program as part of the download.you will need to choose negative or positive to scan.higher spec scanners have built in transparency hoods and can scan at higher resolutions.quite honestly if you are okay with say 6x4 inch prints a basic scanner is fine if it scans at least 2400 dpi.
Jun 10, 2015 | Epson Film Adapter EU33
Keeps saying paper jamed when I try to print
On the Epson website it is confirmed that the Epson WorkForce 610 will not recognize transparency media. It is just the way the printer works; if it can see through the media, it doesn't think it's there.
However.....you can tape a sheet of white paper to the non-printable side of the transparency, and it prints just fine. I put two strips of scotch tape on either side, top and bottom. Works great. It's kind of a hassle, but better than not being able to print transparencies at all!
Jul 22, 2010 | Epson Workforce 610 All-In-One InkJet...
Expression 1680 Professional Flatbed Scanner: Transparency adaptor stuck in open position. The h...
Had the same problem. By lid I assume you mean transparency unit. To fix, it is necessary to remove the transparency unit from the scanner. Then IN A CLEAN AREA! with the glass side up unscrew the 6?screws that hold the top unit together. There will be a hinge assembly inside. You must remove it, clean it, and re grease it thoroughly. I used lithium grease from an aerosol can. Has not given me problem since. the whole process took about a half hour. just make sure you are gentle, and keep everything clean.
May 05, 2010 | Epson Expression 1680 Professional Flatbed...
Lid will not close and is very difficult to put down
Feb 18, 2010 | Epson Expression 1680 Professional Flatbed...
Door/Hinge is very tight, have to push down hard when scanning
Remove the transparency unit from the scanner. Then carefully remove the six screws holding the hinge. Use WD 40 to lubricate hinge.
Jan 13, 2009 | Epson Expression 1680 Professional Flatbed...
Apr 08, 2008 | Epson Expression 1680 Professional Flatbed...
Sep 19, 2007 | Epson Perfection 1200 Photo Flatbed...
Feb 04, 2007 | Epson Perfection 1250 Photo Flatbed...
Epson Expression 1680 Professional Flatbed Scanner Logo
82 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
