Question about Network Computing Devices (NSH800S/A) Networking Switch
On my hub right, on broadband it's shows that it's red meaning that it's not working properly. can you tell me what's the problem please
    Brigadier General:
  • 10,406 Answers
Power-off the hub.
Power-on the hub.
Did the problem go away?
Call your Internet Service Provider, to check if they are supplying a broadband connection "into" your hub. If they are not, then they need to fix a problem at their end.
Posted on May 28, 2010
Can't get my 95 Geo Trackers 4WD to work. The indicator light works still but the wheels themselves won't engage. Can anyone plz help me out with what might be my problem?
For Trackers (and Sidekicks) of this era (1989 to 1998) the front axle locking device is a locking hub on each front wheel. (There are no actuators until the model change in 1999.) Locking hubs come in two flavors, Manual and auto locking hubs. A look at the from wheel should tell you what you have. Manual hubs have a knob like lever with the word "lock" and "free." Auto hubs say "Auto-Locking" right on them. Both types of hubs require servicing periodicity. (Normally annually.) This means removing and disassembling. Then cleaning and light greasing before reassembling. There are some good videos on the web on how to service the manual hubs. Auto hubs are a little harder to ensure they are working properly, but some people like them. (Not me.)
Please note two things:
1. Due to differential action, BOTH hubs need to be locked for any power to be applied to the front wheels.
2. Trackers of this era are PART TIME 4x4, NOT all wheel drive. They have nothing providing for different wheel speeds front to back like a center differential. This means they should NOT be used on non-slippery surfaces like dry pavement. Beside causing handling and braking issues, it can destroy your transfercase driving on dry pavement in 4x4 due to what is called "driveline wind up".
PLEASE if you do not understand this, look it up... if you still do not understand, ask and do not use the 4x4 until you do.
Feb 18, 2015 | 1995 Geo Tracker
Sky broadband not working. Red light showing
is the red light that your referring to is the power light? if yes that means that the modem is defective
Jun 06, 2011 | Computers & Internet
My two computers cannot pass through my broadband provider (through the switching hub) at the same time.
that is not possible for an single isp connection you can only connect one computer at a time and hub is basically a repeater that is it simply repeats the packets it receives from one input out the others.
May 18, 2009 | Encore ENH905-NWY (ENH905NWY)
Broadband red light is on;
I have the same router. If you have a red broadband light on it means that you aren't getting a dsl signal from your ISP(internet service provider). Call your ISP and tell them to check the line.
Apr 20, 2009 | 2wire (1000-400108-001) Router
Switch compatibility problem.
I think you need to go from the leased line to the ROUTER first. The switch you said was unmanaged...so as far as I can tell there is NO IP for the DLINK. If that's the case your router needs to be before the switch and after the modem.
Mar 10, 2009 | Linksys (NH1005) 5x10/100 Mbps Networking...
Usb 2.0 hub - how to test it is working at the correct speed
Get a USB Storage device - if you can copy a file of about 100mb in under 10-20 seconds, then chances are it's USB2. USB2.0 is 480mbps where as 1.1 is 12mpbs (or something tiny in comparison)......
Oct 11, 2008 | Computers & Internet
A red light is showing at the top right of phone
The red light is a message light and when it is red it means you have a message either in your voicemail or someone in the office called you and you did not answer so they pressed their message button and it turned on your light. Does your display have any information about messages?
Aug 06, 2008 | Panasonic KX-T7630 Corded Phone
Problem in wireless connection and showing limited access
typing incorrect password weather in wireless setting or in computer
Jan 28, 2008 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
D-Link DFE 916
The D-Link DFE-916 hub is unmanaged, there is no web management console. You will need setup your broadband modem setup as DHCP to assign your workstations IP address, (or you could go static IP, but DHCP is suitable for most situations)
Topology should be like this:
MODEM-----Hub/Switch-------Computer.
here the link the manual,
http://dlink.support.etop.pl/manuals/dfe916.pdf
concerning the bandwidth pirate, you will need the offending computers mac address, (Media access Control)
to do this:
click start,
Run,
type in: ipconfig /all
the line that reads: "Physical Address" is the MAC address
the format will read like this: xx-xx-xx-xx-xx
Now check your broadband modem or you routers management console for a MAC filter, this is where you can allow or ban a device or computer from the network.
Good Luck!
Jan 01, 2008 | D-Link DFE 916 (DFE-916) Networking Hub
D-Link Vpn Router model DI-804HV
Can you tell me the setup with your router? It should be Internet->Modem->Router->Computer If that's setup properly (the wires in the right spots) then go to the gateway IP of the router...it might be something like "192.168.0.100 "so you put that in your internet browser. The default user is "admin" with no password. Make sure to run the "Wizard" while on that page and after that go to the "Status" page and check to see if the WAN connection is connected properly.
Aug 28, 2007 | D-Link DI-804HV - 4-Port Broadband VPN...
Network Computing Devices (NSH800S/A) Networking Switch Logo
48 people viewed this question
Top Network Computing Devices Computers & Internet Experts
1860ph
Level 1 Expert
Michael Terence...
Michael Terence...
ray gallant
Are you a Network Computing Devices Computer and Internet Expert? Answer questions, earn points and help others
