Question about Honeywell Home Security
Can i run fire rated 18 gage wire in the same wiremold with other lowvoltage wire ie burg wire
    Sniper:
  • 54 Answers
Yes, provided the 18 gauge wire is being used in a low voltage application. You do not want to run any type of high voltage wire in any raceway with low voltage. Hope this helps.
Posted on May 29, 2010
Wiring diagram for sentrex pa120t
I found this, it might help: http://datasheet.octopart.com/PA120T-Wiremold-datasheet-30218.pdf
http://images1.cableorganizer.com/lutron/maestro-wireless-controls/switch-dimmer_Wiring-Diagrams.pdf
Feb 10, 2013 | Electrical Supplies
Wall light switch timer inline with Extension cord GE 15313
Black to black (hot), Green to green (ground) and the only one left is of course white to blue. The (neutral) white wire can be many different flavors (blue, red, orange, brown, etc.).
If the outlet your plugging into (or controlled by the service panel breaker) is 15 Amps use a minimum of 14 gage wire (or 12 gage is even better), if its a 20 Amp outlet use 12 gage wires (or 10 gage). Don't use a 16 or 18 gage wire because it may get hot and start a fire because its undersize for the Amps.
Nov 13, 2012 | Hardware & Accessories
When you pull the trigger air comes out near the trigger and no nail is fired.
The problem that you describe indicates that the orings within the trigger failed. You could replace the orings if you have a source for very small rings (2mm x 1.5 for the firing pin inside the trigger valve) or just replace the whole trigger assembly (under $10). Lube all orings with white grease or silicone paste lube (remove head and lube head valve assembly). Good luck
Oct 11, 2012 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
There are two wires coming out of a fuse box under the hood, one to the battery one to the alternator,the one to the alt has a fuse link in it and from the fuse link to the box someone had spliced the wire...
There should be a tag or marking for the amperage on the fuseable link, this should be rated lower [ say the original wire is 8 gage, the fuseable link should be a lighter, like 10 gage ] then the wire it protects and should fail first. Is the spliced wire smaller then the Fuse link?, If so then you should replace the wire with the same size as the orignial one from the factory.
NOTE: Fuseable links have a isulation that's fire resistant, common wire shouldn't be used in this situation as there's a fire danger.
Apr 22, 2011 | 2001 Oldsmobile Intrigue
12-2 cables will not fit in my wiremold racetrack
The trick is remove the outer sheath on the Romex cables. The installation still meets code because the wiremold is protecting the wires.
Jun 25, 2010 | Wiremold B2s Surface Wiring Switch Kit
I have a small length of surface raceway (wiremold by LeGrand) which has one finished receptacle, about four feet from that, at the opposite end of the raceway, is another power outlet box with no...
Yes , that seems high to me also .. when adding receptacles to an existing circuit, you simply connect them color to color, all the blacks together and so forth .. the black wires should be connected to the brass screw on the receptacles , and the white wire to the silver screws. please do not use the stab in connections in the receptacle, you will have a longer lasting job using the screw terminals
Feb 11, 2010 | Wiremold Switch And Receptacle Box
Type of wire needed for 60 amp upgrade
Got to use the 75 amp rating. otherwise you risk buring up your wires from over amping, fire, blowing fuses continiously, and breaker tripping. Not to mention possible damage to unit.
Jan 27, 2010 | Haier Energy Star ESA3183 Air Conditioner
How to hook up a engine temperature guage.
After market ---  Electrical or Mechanical? If you have a A/M Mechanical this is easy.Find where you want to mount it, in side the cab. run the sensor tube out to the eng. bay. thru the fire wall. Find a place on the engine head any where you find a plug that is the same size as the fitting in the kit. Drain coolant and install your sensor tube. Some come with lights, find your fuse to your running lights and push your gage light wire in next to the fuse and your done. Sim. if dealing with a electrical gage- Mount your gage, run your wiring out thru the fire wall out to the sensor fitting, drain coolant mount your sensor wire it up. hook up the light same way.
Aug 04, 2009 | 1983 Ford Bronco
Cooling fan inop
the cooling fan is a one speed motor. operates only with key on.
The integrated control module (ICM) and the engine computer control the fan.
on at 102 degree C (@ 230 F), off at 99 degrees C (@ 230 F).
You have 3 fusible links, 2 18 gage brown and on 20 gage dark blue providing power to the ICM. You should ahve 12 volts the pink/black wire, the black/orange wire and the yellow wire going into the ICM.
First, jumper 12 volts from the battery directly to the terminal on the motor where the dark blue wire goes. Make sure the black wire is grounded. If the fan works, check the items above.
I can sell you this Ford wiring diagram book for a 91 Mustang for $10 if you are interested.
please rate as solved if this helps you, thanks.
Apr 22, 2009 | 1991 Ford Mustang
Rockford 800.2
what gage power wire are you running sounds like you need a smaller gage wire i have mine hooked up to a 4 gage wire and its working great
Oct 18, 2008 | Rockford Fosgate 800.2 Car Audio Amplifier
Home Security Logo
177 people viewed this question
Top Honeywell Home Security Experts
Sean
Jay Finke
Jay Finke
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
