Question about Samsung SyncMaster 2032BW 20" Monitor
How do you open the monitor up to get inside? Samsung SyncMaster 2032BW 20 inch Monitor
    Brigadier General:
  • 10,406 Answers
If you need to ask "how", I recommend that you STOP, and instead take the LCD monitor to a qualified technician, for _safe_ and _proper_ repairs.
Posted on May 28, 2010
How to open a samsung monitor syncmaster B2330
Try separating the wiring. Touching wires cause cross-talk of signals.
Feb 08, 2014 | Samsung B2330 23 inch Monitor
732nw
k open it from the top side
Aug 27, 2012 | Samsung SyncMaster 732NW,SyncMaster Magic...
Where can I find a driver for MAC for the syncmaster 2032bw or for the LG E2340? thanks for your support
What do you need a driver for? The only driver you should need is for the video card, wich is already installed on your Mac. (for settings go system preferences and then screen)
If what you are looking for is some sort of calibrating software, those are not necessarily made by Samsung or LG rather than third party providers.
Feb 25, 2011 | Samsung SyncMaster 2032BW 20" Monitor
I have to turn it off and on several times to get it to stay on
It may have dying power supply due to bad caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 20, 2010 | Samsung SyncMaster 2032BW 20" Monitor
A small line is appearing on my monitor
I am sorry to be the bearer of bad news but It is defective. You cannot fix it. You either need to send it in for service or replace it. Hopefully it is still under warranty.
Sep 11, 2010 | Samsung SyncMaster 2032BW 20" Monitor
I want to ask how to open case on SyncMaster SAMSUNG T200 monitor 20'
Its sitting around snapped first remove the hoof and look for some screws to find open with a putty knife or very flat tool, but beware the cap has tabs that must be slowly loosened otherwise they will break.
Aug 26, 2010 | Samsung SyncMaster T200 LCD Monitor
How do I tilt the monitor?
Look on the back/side of the stand for a little locking button.
Jun 20, 2010 | Samsung SyncMaster 2032BW 20" Monitor
When i turn onmt Samsung SyncMaster 920LM 19 inch LCD Monitor it blinks on the left upper corner for a few moments
WQhen you get strange problem like this, first place to look will be the caps in the power supply section.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 14, 2010 | Samsung SyncMaster 920LM 19" LCD Monitor
SyncMaster 203B (Black) LCD Monitor: Monitor will not stay on (Samsung Syncmaster 203B)...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 16, 2010 | Samsung SyncMaster 203B LCD Monitor
How to open the back cover of Samsung SyncMaster 794mg CRT .
"Don't kill yourself just to save some bucks"
Here are the instructions:
http://www.josepino.com/?open-samsung-back-cover
Apr 24, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung SyncMaster 2032BW  20" Monitor Logo
245 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
