Question about Refrigerators
I have an Amana(BB120) refer with the freezer on the bottom. The unit is ten years old. The refer is working fine. The freezer, however, won't lower the temperature below 31-32 degrees regardless of the setting of the coldness control. Since it is cooling to some extent, I'm confused as to what the problem may be.
  • 1 more comment
  • handel Apr 08, 2008
    I don't think you understood what I said when I stated my problem. The problem is with the freezer; not the refer part of the unit. However, the freezer's thermostat may be a possible culprit. I'll have it checked out.
    Ginko, you certainly have given me some avenues to pursue. At this point I can tell you that:
    The door (s) shut properly and the rubber seals are intact and functional.
    The freezer's fan is running.
    The coils are not obviously obstructed or dirty.
    So, I guess I'll have to employ an appliance tech to check for thermostat, circuit heater, fuse, defrost thermistor or control board performance. Thanks for your assistance.
    Melnavz, your response is unintelligible. Maybe you ought to read what you said and figure out what you meant to say.
  • Refrigerators Master
  • 19,396 Answers
There may be different causes when the freezer is not reaching to the low themperature it should get to.
Check that the doors are closing properly and the gaskets are ok.
A common cause can be related to evaporator coil problems. Check that the fan is working and that the the coil is not iced up.
Leave the fridge off , and with door opened for over 24 hours, until you defrost ice condensed on the evaporator coil.
After this the fridge should cool up properly , at least first few days. Check also: Cleaning the condenser coils
Check that the evaporator fan is working , if it is not you will need to check the voltage coming to the fan , and eventually replace the part. Check here :
  • Some help for an Amana refrigerator fan motor that will not run
  • Being the fridge quite old it is also possible that you need to take out gas weigh and recharge it, this may resolve problem.
    If at this point it still does not cool properly you will need to identify the fault testing parts eventually involved. It'may be a open circuit heater or fuse, or a faulty defrost thermistor on the freezer evaporator or a faulty control board.
    Start checking fan and coil and doing a two-days defrost, if this does not work recharge gas.
    Regards
    Posted on Apr 08, 2008
      Genius:
    • 3,422 Answers
    It is always recommended that the temp. should be between 35-37degrees.
    If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. i recommend you contact a qualified appliance repair technician if you cannot replace it by yourself.
    Goodluck..
    Posted on Apr 07, 2008
      Genius:
    • 1,226 Answers
    Hello
    when the freezer is full of ice accumulated in the box, that could maintain to the freezing point. i guess that is normal, however if that the case. only the temperature control or the thermostat maybe something wrong. melnavz
    • Emelio Navaja
      Emelio Navaja Apr 08, 2008
      Yea i realize as what i say, but that is the common problem, when The fridge not function properly, there something wrong with the thermostat which monitor the temperature of the fridge. this caused by leakage, Dirt accumulated in condenser, motor comes to an end which cannot support the needed requirement of the evaporator, not proper alignment of the condenser that affect the effeciency. Gas recharging only is possible if there is a leak to your condenser means that no more gas. Gas is no way to exit because that is closed. Gas recharging is the SOP to all mechanical servicing pretending that is the cause but that is not.
      General cleaning is the only way to your problem and checking the motor, evaporator, condenser alignment. if found leak inevaporator thats the time gas recharging is needed.
    Amana. Buzzing and humming. Does not stay cold. Ten hrs old Amana ARB 2217CS
    It sounds like some packing material was left in the unit. You will need to look in your manual and look for set up instructions, since you probably have some packing material left on.
    Jul 14, 2011 | Amana ABB1927DE Bottom Freezer...
    I have a ten year old Amana bottom freezer refrigerator bx21v1c,and the compressor has died. I am debating as to whether to buy a new refrigerator or to pay up to $800 to replace the compressor.
    There is no way that I would spend $800.00 on a ten year old fridge... I can do my own and I would not replace a compressor on a ten year old unit...too many problems afterward...too many other things that could go wrong shortly...
    You will be better off to take the $800.00 and put it towards a new unit...
    heatman101
    Jun 10, 2011 | Microwave Ovens
    Bottom freezer is fine but top refrig. is warm. Have vacumned bottom front coils, unit less than 2 years old. Any suggestions, other than calling repair? thanks.
    Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
    Refrigerator not Cooling or Fridge not Cooling
    How to Defrost Refrigerator Defrost Timer Problem
    Water Running in refrigerator from Freezer
    heatman101
    Sep 26, 2010 | Amana AFF2534FE Bottom Freezer French...
    Amana botton freezer buzzing 10 sec, freezer not cooling
    CHECK MICRO/ SW WIRES @ FREEZER INSIDE THE CABINET COULD BE LOSE
    Aug 19, 2009 | Refrigerators
    Amana ARB2217CSR freezer not working right
    You have defrost control parts failure.
    Either defrost timer, defrost thermostat or defrost heater.
    Feb 21, 2009 | Amana ARB2217CSR Bottom Freezer...
    Frozen food in refrigerator
    turn your freezer up all the way and your refrigerator down a little. this will block some of the airflow going to the refrigerator.
    Jul 05, 2008 | Amana Refrigerators
    Amana bb120 bottomfrezer ice makerwon't work
    HOLLOW ICE IS ALWAY A SIGN OF A WATER INLET VAVLE FAILING
    May 31, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
    Refrigerators Logo
    314 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Brian Coughlan
