Question about Goldstar WG8000 Air Conditioner
A/c won't run, only a humming noise when turned on?
When I turn the power on there is only a humming sound and nothing else. there is no cold air blowing out, how do I fix it?
  • Peter Hampton Apr 22, 2014
    easy replace compressor run cap should be around 30-35 microfared at 440volts
    you will need to take the front cove off and on the right hand side behind the switches you will see a very large round can with pins
  • 158 Answers
Was the a-conditioner serviced recently ?Anyways just slide out the "machine "part ,loosen the screws ,holding the top plate and re-insert. check whether it works now .If it works ,it was only a alignment problem .tighten all the screws evenly .
Posted on Jun 11, 2010
  • Goldstar Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on May 28, 2010
Loud humming noise when starting up, worse when cold, also when turn wheels, is this possible power steering pump or bearing in pulley?
If the power steering fluid is low, the pump will hum/whine as it will draw air into the system. If the fluid level is ok, possible internal pump issue
Dec 19, 2015 | Cars & Trucks
Not staying cool
sounds like it is either low on Freon or the compressor is going out. The blowing ice cold is an indicator that it may be freezing up because the low Freon. when it stops blowing cold, turn it to fan only mode and see if it gets colder again. If that is the case then the unit is low on freon and freezing up. I know that sounds confusing but that is how AC works. The low freon pressure means the gas is expanding too fast and the air flow cannot take up the cold from the evaporator fast enough. Turning the compressor off and keeping the fan on will alow the room air to take up the cold.
Apr 22, 2014 | Frigidaire FAM157S1A Air Conditioner
When I turned my pump off to backwash and then turned it back on it made a humming noise then stopped running. Now it is doing nothing. what could the problem be?
sounds like a bad start capacitor, or there is something (rock, sand, or some debris) caught in the impeller.
The start capacitor not working will cause your motor to hum, then it will overheat and trip the high limit. It won't attempt to come back on until it has cooled. It's a common problem.
try clearing the impeller first, if that doesn't work and the motor shaft spins freely, then it's a capacitor.
Jul 27, 2011 | Hayward Power Flo Lx
My outside Kelvinator central ac unit will not turn on. I hear a faint humming noise coming from it so it appears that it is getting power but won't turn on. My fan in the house will turn on and...
Its possible that the contactor that closes to start the outdoor unit is not pulling in and passing power. You are hearing the coil humming since it is getting control power. Also first check that breaker for outdoor unit is not tripped
Jun 22, 2011 | Heating & Cooling
My air conditioner will not Start on it's own. Then temp controller in house makes a click sound, the furnace fan then runs like it should. But when I go outside I hear a buzz and click sound like it's...
compressor locked up. try hitting top of compressor with a block of wood on top and a hammer, wait a few min. then turn on. if it dosen' start u will have to replace it.
Aug 06, 2010 | Heating & Cooling
Both fridge / freezer are not cooling down. It sounds like the motors are not working.But there is power going in. Also there is a small humming engine noise.
Are you sure the humming noise is from the compressor motor being locked up? It is normal for the compressor motor to make a humming noise when it runs. Make sure the fan in the freezer is also running while the compressor motor is running and replace it if necessary.
You need to defrost the coils in the back of your freezer. You can do this the slow, easy way by simply unplugging the refrigerator for 24 hours. Leave the doors open to ensure everything has the chance to melt.
The fast way to defrost the coils is to turn off the refrigerator and remove the rear panel from the freezer compartment. You will see the evaporator coil completely frozen with ice. Thaw the ice with a hair dryer and make sure you thaw the drain at the bottom of the back wall as well.
When you turn replace the freezer panel and turn the refrigerator back on, it will get cold again.
Mar 06, 2010 | Electrolux Refrigerators
My coleman mah 3 roof top will not blowon fan side
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Sep 09, 2009 | Coleman Mach III Air Conditioner
When I turn the unit on the fan does not operate.
either the capacitor is not giving correct voltage and is inop,or the fan motor bearing are out and the motor is inop.
Jul 15, 2009 | Heating & Cooling
No cold air.
Is the air conditioner completely dead? See section 1. Is the thermostat knob turned to the proper setting? Is the compressor motor running? The compressor is a football-sized case with no apparent moving parts. It is located inside the air conditioner at the center. Is it humming or making any kind of continuous noise or causing the lights to dim? If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
  • Compressor
  • Condenser
  • Evaporator
These items are not user serviceable. You will need to contact a qualified appliance repair technician to repair these components.
If the compressor is not running but you do have power to the air conditioner there may be a problem in one or more of these areas:
  • Compressor
  • Overload and/or relay
  • Thermostat (Open thermostat)
  • Burnt wiring
  • Bad selector switch
  • Capacitor
May 26, 2009 | Fedders A7D18E7B Thru-Wall/Window Air...
Heat pump is humming loud>
When the heat is not on. Go to the T-stat and turn the fan to the on position. With the blower now running is it making the noise? If so you probably either have something in there such as the filter that was mentioned, a piece of paper etc. or one or more of the blades on the blower wheel is vibrating. Don't let the condition persist w/o having it checked out or you may turn a simple fix into a costly one.
Jan 22, 2009 | Heating & Cooling
Goldstar WG8000 Air Conditioner Logo
1,103 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
