Question about Karcher PSI Electric Pressure Washer
I HAVE A KEW ALTO FORCE THAT IS 9 YEARS OLD IM VERY HAPPY WITH IT THUS FAR ,BUT NOW MY PISTOL HAS A CRACK INSIDE AND IM LOSING PRESSURE MAKING IT IMPOSSIBLE TO USE WITH WATER COMING OUT FROM TWO AREAS. PLEASE HELP IF ITS NOT POSSBLITE TO FIX .WHERE CAN I GET A NEW PART BEING THAT ITS OLD MODEL I WOULD LIKE A NEW PART. THESE ARE MY ITEM NO#6531010 TYPE: P11897
  • 422 Answers
SOURCE: Alto Force Kew washer stopped working.
To remove the cover, undo the two screws holding on the equipment tray on the handle. Then turn upside down and undo the two screws on the bottom. You will need a very long handled screw driver to reach into the deep recesses. I think they may to TORX screws (working from memory and has been a while since I pulled one apart). The blue cover will now pull off. The only trouble you may have is that the bolts are ordinary black steel ones and may have rusted through
Most likely fault is that the pressure switch has failed open. A combination of dirty water leaking past the seals and rust will eventuall jam the switch. The switch assembly is the white plastic part directly bolted onto the pump. A plunger is pushed by the pump when it is up to pressure which trips a micro switch and turns the power off. You will need to replace the complete pressure switch which is about $60. If you take care the micro switch assembly can be removed and then put back onto the new switch. If you break it, then another $40.
Posted on Jan 12, 2009
  • 33 Answers
SOURCE: i have a alto pressure washer i have problem with the trigger
GO TOO WAL MART AND SEE IF THEY HAVE A COMPARABLE TRIGGER AND NOZZLE ASSY. REPLACE THE THING WITH SOMETHING DIFFERENT. WHAT YOU HAVE IS JUNK AND WON'T NEVER WORK FOR LONG.
Posted on Apr 21, 2009
SOURCE: Karcher pistol gun has broken
Make sure you DO NOT have a check valve (this is what stops your hose running when you disconnect from the hozelock fitting) in your hose pipe system, This will send a shockwave through the pressure washer and destroy the fitting you mentioned. They can be easily removed.
Posted on Jul 25, 2009
  • 389 Answers
SOURCE: Alto Kew pressure washer stopped working!
Hi Steve, In 3 years of repairing pressure washers I've only ever seen one of these, and am having a hard time remembering much about it, except that it was really awkward to work on! Strictly speaking, many small pressure washer repairs are uneconomical, because the labour time involved costs almost as much as the machine is worth. However, a "motor won't go" problem does narrow things down a lot. To state the obvious, we're looking at an electrical problem. The challenge is to find the cause! Did the motor stop while you were using it, or did it fail to start when you got it out of storage? If you are in the UK you should first check the plug-top fuse and the full length of the flex for any damage. If you have any kind of low-voltage electrical testing device, you can test for continuity between the live and neutral pins of the plug (with the machine switched on you should have continuity). If you have no continuity (and the fuse is OK) there may be a problem with the switch on the machine. Unfortunately, unless you are a really keen DIY person, there's not much you can do by way of self-help. A repair centre may be able to help you, but beware of costs spiraling beyond the cost of a replacement machine. I hope this will be helpful - if you can give more details I'll help further if I can. Good luck!
Posted on Aug 16, 2009
  • 12 Answers
SOURCE: when connected to water and working water
open case and find sorce of leak probaly busted plastic line of fitting
Posted on Mar 16, 2010
Leaking water, losing pressure and locking out - this boiler is 9 years old and recently kept losing pressure and then locking out.
9 yrs old its like anything else depends on maintenance and quality of unit --not safe since if safety doesnt shut down unit much more damage can occur
Sep 21, 2016 | Water Water Heaters
Kew 1640H with display flashing A 2 fault code
Hi really hope someone can help as I couldn't find a manual for my kew alto 1640hot and cold diesel pressure washer, problem is when I turn it on from been stood over night !i press on button and I see a f then a 1 flashing on the display ,anyone know what it means or we're the fault is,
Sep 18, 2011 | Garden
Where can I obtain a manual for the alto L-12 mixer
You can download the manual using this link:
http://www.directproaudio.com/images/products/alto-l12-manual.pdf
Please rate my answer if this helps.
Many thanks,
Chris
Mar 03, 2011 | Alto L-12 12 Channel Passive Compact Mixer
Kew Alto Force X-TRA cold water supply pressure sensor problem
Have the same p-washer (5-6 years old) and the same problem. Opened it and the pressure switch is the crook. A plastic pin has an inner and an outer spring on it (two consentric springs). The smaller inner spring is completely rusted away so the switch no longer operates correctly. Obviously the spring was of a too low quality. The service office say a new switch cost around 400NOK (50 euros) - so the washer is too expensive to mend. But I will try to get it working without the inner spring. Doubt if I succed. So will have to dump the washer.
Mar 19, 2010 | Garden
Water pouring out of the pump on my kew powerwash
Hi, You can get this seal set for a 1502v from nilfisk alto or any alto dealer.
Dec 27, 2009 | Garden
Aug 14, 2009 | Garden
ALTO FORCE KEW COLD WATER POWER PRESSURE MACHINE STOPPED
Hi FRANK,
The answer of "Firehead" is correct. You have a start/stop valve with springs (springs = maybe broken by the rust). Kew sells a kit to repair. If you want i'll send a diagram to you.
JJ (Brussels)
Jul 04, 2009 | Garden
Cant change the high pressure hose on a Karcher
On the Kärcher, you have a bayonet mount at the base of the tip end of the pistol grip. This is where you attach different types of nozzles and gadgets after having removed the existing sprayer tube. Just push in and turn a quarter of a turn, then you pull it off the pistol grip. The hose is possible to remove from the machine as well, an ordinary threaded mount but since you need the pistol grip to regulate on/off this is probably not what you want to do. If the telescopic wand is made by Kärcher it should be very easy to snap it into place just like when you removed the sprayer tube/nozzle. If the attachment was made to fit Alto washers there is an inexpensive adapter that works very well. Good luck!
Jun 03, 2009 | Karcher G 2600 VH Gas Pressure Washer
i do not think there is a pressure release valve , sounds like the plastic inside the pistol has become brittle and has failed under pressure , you dont say how old the pistols are ? and if you run strong detergents through them .
May 26, 2009 | Karcher PSI Electric Pressure Washer
Nov 15, 2008 | Garden
Karcher PSI Electric Pressure Washer Logo
310 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
