Question about Bose Companion 3 Computer Speakers
I have bose computer speakers. they include 2 little speakers with a sub. the 'nucleus' of the unit is a hockey puck size/shaped controler that lets you tap it to toggle from on to a mute state. it also can be turned for volume... and headphones can be plugged in here as well. when it is in the on state the puck has a little green light... (it is a sort of orange in the 'mute' state). the speakers no longer work - the puck is no longer tappable - it just luminates with the faintest green light. if i put headphones in the puck the DO work. is the speaker system gone for good? thanks for any help. --------------- btw - it looks like the same problem someone else recently posted: By mobozak on May 17, 2010" " My companion 3 computer speakers stopped working. The controller light stays on a faded green. The controller will not respond at all and
  • 13,433 Answers
Hey,
How old are the speakers, how long have they been in use? Possible fault can be the power supply of the speakers, in these it might be internal, inside the sub.
It is most likely a power supply issue, the speakers don't wear out like a power supply does.
could be bulky or leaking capacitors inside, you might want to take it to a electronics repairer, might be a simple fix.
Or you can of course take it apart yourself, take a good close look at the caps and if any of them are not flat, replace them, with same voltage rating caps, preferably same UF rating, a bit higher is OK.
Posted on May 30, 2010
  • 679 Answers
Bose® products are covered under limited warranty for at least one year from the purchase date. Please refer to your Bose owner’s guide for specific details. If you are under a year you are in good shape, can you try these on another acoustimass, it sounds like a wire came off to me. If there are any fuses that you can change do that first. Last resort is to open the module and check to see if all that tapping somehow loosened a connection or a wire came off. Please use extreme caution and unplug everything. If there are resistors , capacitors or diodes in that controller, thay shouuld be checked obviouslly something blew or is intermittent. If you know how to use and have a voltmeter check the resistors and the capcitors. If not just rplace them. Radio shack has all the components or a local electronics store. I fixed a 2000 dollar Samsung LCD, "mine" with 5 dollars worth of capacitors. if you need any advice or help I will pull up a shematic f the system and take a look at it, I just wanted you to have someting to start with, beng a holidat weekend, I am sue it can be fixed, and it seems it's a common problem with that system thus the one year warantee indtead of their usul 5 yr,thanks, Gymowner, keep me in the loop I will be around all weeekend
Posted on May 29, 2010
  • t_abouchar May 30, 2010
    thanks for the reply! i saw one of the pod controllers on ebay for a few buck - i was thinking about getting this but figured that it was unlikely to be related to that, and more likely to be something related to the sub as it seemed to me that all of the primary components would be housed there. however, if you suspect that it may even be remotely possible that it could be that controller i would just go ahead and try it out since its not too much.
    also, like you said it seems that this problem does not seem unique to me as others seem to have described that same issue. i am surprised that we cant find a definite explanation somewhere... do you know if even perhaps on a bose site such a knowledge base would exist? thanks!
  • George Bill
    George Bill Jun 04, 2010
    It all comes down to research, just to explain myself, I had a problem with a 3000.00 Samsung Led, 55 inch, it would take forever clicking over and over until it finally went on. It got to the point where I said that's it, and started googling all sorts of phrases. I found that this was quite a common problem with this model. Now having beed an engineer "but not having really used my skills for 3 decades" I started to look a the schematics and noticed that the power board had maybe 20 capacitors on it all but 5 were rated for 20 volts. So logically I wanted to know why those 5 were 10 volts instead. Yea "good luck trying to get an answer from Samsung admitting that they just preferred to fix them "most off warantee" because it took about 2 years for this to occur. So the repair tech came out we spoke and he showed me the board. He knew I knew. Although when I asked him why don't they just change them all out to 20v. He laughed, he said you know why, most people aren't going to do what you did. They will just go and buy another one, for 2 dollars worth of parts they will spend 2 thousand dollars on a new set, and just to see if his theory held water, I called two of my buddies with the same basic set. And they agreed that they would just throw it away and buy a new tv. Samsung overnighted him the capacitors which were still the 10 volt, not the 20 that it required, so he "the repair tech" who I had gotten friendlly with at this point and given him a $50 to do the repair in my home, "he wanted to take the module away and fix it then return it. I said no way, last time you guys did that I was without a tv for 8 months. He came back two days later removed the 5 caps in 15 minutes we screwed it together and it works better than when it was new. No more clicking and no more on and off and the volume inrcreades a good 20%. The reason I told you this is that these companys will never admit that the under engineered something, or that they know what is wrong with it but if they tell you, they will have to recall millions of dollars worth of units and face all kinds of legal and monetary problems. It is probablly something stupid like a 10 cent resistor. That is causing the problem.The best way is to spend the two or three hours on the computer and go into forums like I did until you find the exact cause , and you will. But I don't have the time to reverse engineed the unit for you , I am sorry but it just would take too long, that's why even the repair techs just change a module instead of trying to narrow down the part. It is too expensive when they are paying a tech an average of $115-125 per hour in most cities in the US.So unless it's readilly available or it's your possesion, it's very hard to get anyone to take responsibility, It just costs too much. I think you are on the right track, see if you can pick up the parts on ebay untill you find the part that is causing the problem. Unless you have the ability to use a miltimeter and measure the current and the impedence and such to do it yourself, sorry i couldn't be more help but I would rather be honest than try to give you a canned answer taht I was not sure of. Good luck,
    Gymowner
  • 506 Answers
If the Control box you described is lit faintly, There may be problem with the power unit of the speaker system. It may not be receive/ giving the right voltage to power the control board on the speaker. Let an experienced technician look at it I assure you your speaker will work again
Posted on May 28, 2010
  • 560 Answers
The sensor switch inside the speaker's headphone jack may have been stuck up in the "ON" position. I had the same problem with my speaker and I had to stick a pin and wiggle the jack sometimes it works but most of the time it is annoying and I couldn't find a replacement part to fix the problem.
How much do air hockey pucks cost?
Air hockey pucks are very cheap and cost around $1-$2. They're usually sold in a set of 3-5 pucks.
Aug 08, 2012 | Sport & Outdoor - Others
What are the rules in official air hockey games?
In official air hockey games, there are basic USAA rules that the players need to play by: Players can stand anywhere around their side of the air hockey table (center), but cannot go to the sides. Players cannot touch the puck (palming). If any part of their body or clothes touches the puck, a "palming foul" is called. Players can hit the puck with every part of the mallet, besides the bottom part. There should be only one puck during gameplay. A player can use only one air hockey mallet. A player cannot place the mallet on the puck in order to slow it or stop it (topping). When the puck is on the center line, both players can strike it. Once the puck is in the player's side of the centerline, he/she has 7 seconds to strike it back. For more rules, check out these websites: http://www.justairhockeytables.com/air-hockey-tables/airhockeyrulesarticle.cfm, http://www.ehow.com/facts_4868311_official-air-hockey-rules.html, and http://www.sportssearchdata.com/articles/606/1/Basic-Rules-of-Air-Hockey/Page1.html.
What's the puck made of?
Air Hockeypucks are slim discs made of Lexan polycarbonate resin. Standard USAA-approvedpucks are the yellow Lexan, red Lexan and the Dynamo green. In competitions, alayer of thin white tape is placed on the face-up side. Air Hockey pucks comein many shapes and s. The shapes could be a triangle, hexagon, or an octagon.
Jul 25, 2012 | Sport & Outdoor - Others
Looking for puck housing for a 7" Dura-Glide air
Recently moved and, somehow, on puck housing has come up missing. Can't find manufacturer name. Searched and searched. Any advice?
Jan 29, 2011 | Tornado Arctic Wind 7' Professional...
I have been given a Sony SS-WSX1 subwoofer. However |I do not have the bespoke cabe. I need the pin out of the sub woofer to connect the unit to my system.
The sub was part of a Sony DAV-X1. This whole system is highly proprietary in its connections for a reason. For all anyone knows, the original amp's output was frequency-shaped to correct for speaker response issues, like Bose would do. Substituting a different amp may be electrically unwise and audibly unsatisfying. It is certain that the DAV base unit did all the electronic magic to create a surround effect from only 2 speakers and a sub.
Your best bet to put these speakers to use would be to examine the sub and speakers for two conductors each that would be for the amplifier's audio output. Measured across them wit han ohmmeter it would read somether around 6 ohms.
Then somehow craft a physical connector to carry an amp's speaker output to it and carefully test it with very low volume.
http://www.retrevo.com/support/Sony-DAV-X1-Home-Theater-Systems-manual/id/750ci463/t/2/
Jan 20, 2011 | Audio Players & Recorders
Problem hooking up bose speakers
mcdevito75 here, The HP speakers that came with your computer work fine, the bose speakers work fine on your other computer, the plug on the Bose speakers is a little shorter than the HP speakers, and only the right Boss speaker is working, HMM, Check the Bose speakers, both of them for a volume control 1 of them may need adjustment on this particular computer. If that"s not it, I would speak to a Radio Shack, Staples etc.
Jul 04, 2010 | Bose Companion 2 Series II Multimedia...
I only need the AC Adapter Campanion 2 for my Bose spearkers. How can I find just the adapter?
Look where the AC adapter would plug in.
Look for "rating", e.g., 'DC' or 'AC',
and '6V' or '9V',
and look at the size/shape of the plug.
Then, go to a "Dollar Store" or "Thrift Store", and try to match the ratings and the plug-layout with the available inventory.
Or, contact BOSE, and see if you can buy it from their web-site.
May 28, 2010 | Bose Companion 2 Computer Speakers
I lost paper work
Simple enough,
everythink connects to the sub, so the 2 speakers the volume controll and the computer cable, then the computer cable comes out the sub into the green audio port on your computer :)
Feb 16, 2009 | Bose Companion 3 Computer Speakers
Bose companion 3
This is a common problem it seems with the electronics within the speaker set. (Companion 3 with sub and remote pod, aka, 'puck' = help desk support term)
I bought the multimedia speaker set in 2004 and had it replaced in 2005 because the 'puck' would not turn on (no orange light nor green light.) So I called help desk and they accepted the warranty exchange and I mailed the entire system (speakers and all) back to Bose in Markham, Ontario, Canada and they sent it back several weeks later. It worked 5-6 years after that as it is 2009 now, and it has the same problem again (no light on the puck). So I called help desk again and was ran through the same tests again (on/off, power plug off, various audio inputs, etc.) and the guy said to mail it in and they'd fix it as a non-warranty item. Cost: $85(Cdn) for repair + taxes, and $39 for remote pod.
So the sound that I got to enjoy from the Companion 3 system was amazing but electronic quality is very poor. For a set that cost above most other home user sets at FS and BB, it is substandard longevity.
I like Bose and have no complaints about the sound, but I will not buy another Bose multimedia package because at $350 (in 2004), I would expect it to outlast other sets. My friend bought a Logitech speaker set from another company in 2003 and is laughing at me as he realizes this is my second set and it hasn't even lasted as long as his own set.
Dec 03, 2008 | Bose Companion 3 Computer Speakers
Bose Companion 3 Computer Speakers Logo
396 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
