Question about Roper RAX4232KQ Top Load Washer
Problem running through the cycles
Will not drain or rinse will only agitate. Was working fine and this just started.
  • 5,911 Answers
If this is a Whirlpool manufactured TOP LOADER (such as Roper), you need to check your lid switch. This is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare.
If you have questions, or need additional assistance, please post back and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Posted on May 28, 2010
I have a top load washer model LSR 8433 KQ0 the machine will not spin but agitates, rinses, drains fine but when it clicks to the spin cycle it just pumps out any water and does not spin. Would this b
Either the belt broke or the hood switch is not working. Sometimes it could be the contacts in the main control knob but if everything else is working correctly, then check the belt, and the hood switch first.
Jan 11, 2015 | Washing Machines
Two year old Whirlpool washer started failing to advance from the rinse cycle to the spin cycle a couple of weeks ago. However, the water would drain through and run until you manually advanced the system...
Hi, I just want clarification. Is the washer filling to a point when it starts draining the water before it starts to agitate? If this is the case, check the end of your drain hose and make sure that it is as high as the top of the washer. Make sure that where it goes into the drain pipe that it is a loose fitting so that air will **** back into the drain hose. Please let me know if I have given you the right information or if I have missed what you are describing so I can assist you further.
Thank
Vic
Jul 13, 2009 | Washing Machines
Water doesnt pump out to start rinse cycle
Seems the timer is sticking at the drain cycle. Manually move the timer and see if this helps. If this works then the timer is bad.
Jul 05, 2009 | Washing Machines
Washer does not spin and drain water. (Kenmore Elite Heavy Duty)
it seems to me ur washer transmission is going out or already there
Nov 26, 2008 | Kenmore 24032\24036 Top Load Washer
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
No agitation in ge hydrowave rinse cycles
you must unplug the washer for just 1 minute open and close the lid 10 times and plug it back in and put it on a light load cycle and let it wash with empty load. shoul work fine after that
Dec 01, 2007 | Washing Machines
Clicking Sound between agitation and drain cycle
Is it a front loading or top loading washing machine?
Oct 08, 2007 | Washing Machines
Amana Speed Queen (LWS34AW)
Probable gear box fault Regards Engineer
Jul 27, 2007 | Amana LWA40A
Roper RAX4232KQ Top Load Washer Logo
79 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
