Question about Konica Minolta bizhub C351 All-In-One Laser Printer
I am trying to print a 2 sided booklet and it says my duplex is not installed. How can I install it?
    Brigadier General:
  • 10,406 Answers
Does your printer have an optional "duplexer" ?
It's an extra-cost hardware option to "flip" the paper over, and feed it back into the printer, to allow printing on the "back" of the sheet.
Buy the duplexing hardware, and connect it to your printer.
Posted on May 28, 2010
Well you have to get that option kit from a Konica Minolta dealership if they still have them. Sure the duplexer is installed just not plugged in would be attached to the right side door. will require two or three screws and a connector or two.
Jun 18, 2014 | Konica Minolta bizhub C351 All-In-One...
Brother mfc 8670 paper jam duplex
remove the small, or scratch into pieces inside the duplex to clear the paper jam.
Feb 10, 2014 | Brother MFC-8670DN - 30 PPM Multifunction...
Bizhub 211 double sided printing inactive
It was the same problem. To enable drop down menu open "Device Option" tab where you will see list:
Duplex Non Instaled
Tray2 Not Installed
Tray3 Not Installed
Just double click on "Duplex Not Installed" and it will changes on "Installed" and Double sides drop down menu become active.
Jan 20, 2012 | Konica Minolta bizhub Office Equipment &...
Please i want to know if konica minolta magicolor 1690mf is wireless printer? and how do i set the two sided print.
The Konica Magicolor 1690MF Printer/Copier/Scanner is connected with an Ethernet Cable or USB Cable. It is not equipped to operate as a wirleless printer. It has a 10Base-T/100Base-TX Ethernet interface port and a USB Revision 2.0 High-Speed compliant port.
To do two-sided printing you must have the duplex (double-sided) option installed. This also requires either Tray 2 or the Attachment to be installed underneath your machine. Tray 2 is the optional lower feeder unit which increases capcity of your machine to 500 pages. The Attachment comes with the Duplex Unit.
Only Letter and A4 plain paper (16-20 lb bond) can be autoduplexed. With the duplex accessory installed you can do duplex or double-sided printing automatically.
From within Printer Preferences select Two-side Printing > Automatic. Shoud have choices of Off, Manual or Automatic. Within the Layout Tab for your work you may also be able to specify duplex (double-sided).
Should you have continued difficulty, please reply and advi e if the duplex option is installed and with which software and operating sysytem you are using.
Thank you for using FixYa!
Sep 19, 2011 | Konica Minolta magicolor 1690MF All-In-One...
Trying to duplex print a Word document as booklet on my MP160. (that is, each page would be 1/2 letter size sheet.) I had no problem setting up the doc, it just won't print. Word Help says I will be...
I am MS Offfice Systems as part of my degree. I have two courses in word. What you need to do is to click on the office button, click on print, and click print again. Click on the properties button on the top right on print dialog box. In the selection box about fourth option down where it say Two-sided (Duplex) Printer click on that. That should do it for you.
Dec 01, 2009 | Canon PIXMA MP160 All-In-One Printer
Will not duplex - fails duplex quick test
Hello.
Here are some suggestions from Lexmark as to why the printer will not duplex:
The ability to select duplex printing requires the following:
  • -The printer must recognize the physical duplex option.
  • -The duplex option must be recognized by the driver under Properties > Install Options.
  • -The selected Paper Type must not be:
    -Transparency
    -Labels
    , or
    -Cardstock/Extra Heavy Paper.
  • -Under Page Layout > More Page Layout Options, the following options must not be selected:
    -Booklet printing
    Poster printing
Printer recognition of duplex option Some printers and MFPs have the duplex option built into the physical printer while others require physical connection of the duplex option or tray.
To check for an installed duplex option:
Print a Menu Settings page and check for DUPLEX under Device Information > Installed Features. (The embedded web server path is Reports > Device Settings > Device Information > Installed Features.)
If DUPLEX does not appear as an installed option, consider the following possible reasons: -The duplex drawer or tray is not properly connected to the printer. Try reseating the printer onto the duplex option so that the duplex option's upper auto-connect connector is properly aligned with the printer's bottom auto-connect connector. NOTE: A "982 duplex error" may also result from this condition.
-Turn the printer off for about 15 seconds, and then turn the printer back on. If the printer was quickly turned off and on, a low-voltage power condition could prevent the peripheral from being acknowledged during the initial printer start-up.
-The auto-connect connector is damaged on the printer or duplex option.
Software driver recognition of duplex option - reinstall driver.
Hope these suggestions help.
Nov 27, 2009 | Lexmark E450dn Laser Printer
Double sided copying
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
Slot.
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
stack.
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
orientation.
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
middle.
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
Duplex Printing
do you have duplex installed ? if you trying to copy duplex originals, you need duplex feeder.. in main displey the left tab is dupleks printing, if you have there options 1 -1; 2-1; 1-2; 2-2 then you have a duplex installed and you can copy/print duplex. also in driver menu there is a option duplex, wath you have to choose if you printing.
Apr 25, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
229 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
