Question about Mtd 22" Yard Machine Push Mower
Hi, I need to replace the plastic cover for the air filter. It popped off and of coarse I didn't see that happen and proceeded to run over it and cut it to shreds. Can I buy a replacement cover. Vantage Tecumseh 3.5 HP model# 113-801A515 MFG code 1E 283I1-0058
  • 61 Answers
If you will take that information to your local lawn mower dealer they can order the part. You can also order it online, just do an internet search for
mtdparts.com
I hope this helps you
Posted on May 29, 2010
I need to know if there is a filter on the end of the pickup fuel hose in the fuel tank.i have a reddy heater ,model r100a.
Yes there is a filter. Pull up on the fuel line, or the rubber grommet that goes into the tank with the fuel line through it. There were different types of filter used. One is inside a black plastic tube. You can pick it out of the tube with a pick. Another style is located on top of the tank and is of white plastic. Your fuel delivery problem may be air related. The air pump is on the back of the blower motor, and meters a set volume of air to **** the fuel out of the tank and blow it through the nozzle. This air pressure is stated on the data plate on your heater, probably about 3.6 psi. The air filters on the air pump could also be dirty causing the air output to be reduced, and thus low fuel flow. Also check for air leaks at the pump. Spray soapy water on the black plastic cover and look for bubbles, which are of coarse air leaks.
Jan 17, 2011 | Reddy Heater-30-55,000 BTU Variable
How to relplace fuel injectors 02 chevy trailblazer
Thanks for contacting Fixya.com.
The fuel filter is located on the driver's side, centered between the front and rear tires, along the inside of the frame.
There happens to be a hole in the plastic covering that runs from just under the transmission back to the rear axle. If you can manage to remove the filter without removing the cover, you're better at this than I am.
After removing the cover, which entails removing a cross bar, four bolts and two nuts, the rest is easy. Make sure you have something to catch the gas that will drain from both lines. Squeeze the the blue clips on both lines to pop them off the filter. (This is when all the gas drains out). The filter is held in place with one screw (phillips) located above the filter. Remove old filter and replace with new. The new filter should be labled with "OUT". That line is the line that goes up to the engine. You will need to remove the blue clips from the old filter and snap them onto the new filter. Snap the fuel lines on the filter, tighten strap that holds the filter in place, replace the plastic cover then you're done.
Let us know if you have something more to know else please accept the suggestion.
Thank You.
Jun 01, 2010 | 2002 Chevrolet TrailBlazer
How do i change the cabin air filter in my 2003 ford expidition
Locate the cabin air filter container on your Ford Expedition. If you are standing in front of the vehicle, looking at the engine, it will be on the back, left side of the engine, next to the heater fan. You will see a black cover over the top of the container. The air filter is approximately 6" x 9" and about 2" deep. Look for a black casing that will be about 10" across and 8" high. The box sits vertically against the firewall of the vehicle.
Step 2
Remove the cover of the cabin air filter by lightly prying on it with a screwdriver. The cover is secured with plastic tabs that pop off quite often. If this happens, you can buy replacements at your local automotive store.
Step 3
Remove the cabin air filter, and vacuum out the container to remove any dust or debris. Wipe it down with a clean damp cloth and let the inside of the container dry before inserting new filter.
Step 4
Place new cabin air filter in container and secure the cover, replacing tabs if needed. Remove tools from engine compartment and close hood.
Step 5
You are now able to enjoy driving with clean air flowing through the inside of your car.
May 25, 2010 | 2003 Ford Expedition
How do You remove the plastic clips to pull the air intake tube
thats the part load breather pipe. you should be able to remove it by squeezing the plastic clip together by hand but it may have hardened by age making it difficult and can break be carefull not to break the stub on the cam /valve cover if in doubt cut the pipe off carefully and fit a new one. by gentle twisting/squeezing they nomally come off
Apr 03, 2017 | 2000 Jaguar XK
How to replace cabin air filter in 2003 pilot
Step 1 Take everything out of the glove box on the passenger side. Squeeze the black clips on either side of the glove box interior to free it from its retainer and pull it toward you. It will glide forward on hinged arms. Lower it as much as possible so it's out of your way.
  • Step 2 Identify the gray plastic bar that runs from left to right across the bottom of the glove box opening. This is a piece of plastic molded to the rest of the glove box assembly, but it covers up a removable bar that is mounted directly in front of the cabin air filtermag-glass_10x10.gif case. You'll have to cut this plastic bar off with a razor knife to proceed. Fortunately, this isn't too difficult; just cut carefully and steadily, and make your cuts as close as possible to the ends of the bar.
  • Step 3 Remove the metal bar you uncovered in the previous step. It is screwed into the glove box assembly with Phillips head screws on either side.
  • Step 4 Open the cabin air filter case, which is the large plastic case on the left side off the glove box opening. The hatch will come all the way off when you open it.
  • Step 5 Take the old air filter out of the case and throw it away.
  • Step 6 Look at the arrows on the filter and the arrows on the filter case that indicate the direction of the air flow. Slide the new filter into place so that the arrows are both pointing the same way.
  • Step 7 Put the lid back on the air filter case and reinstall the metal bar you removed in Step 3.
  • Step 8 Push the glove box interior compartment back into place and listen for the snapping sound. Put the glove box contents back, close the lid and you're done.
  • Dec 06, 2009 | 2003 Honda Pilot
    Air filter
    follow the black plastic hose (Going towards the passenger side fender well), remove the plastic cover should be three plastic clips, once the cover is removed you will see the air box, two clips are in the front of the cover, pop them open and you see the filter, hope it helps
    Jul 20, 2009 | 2001 Lexus LS 430
    Loation of air filter on 2005 c 2404matic
    The air filters are located within the engine cover. You need to pop the cover off and access the bottom of the cover. There are 8 20 torx bolts. The cabin filter is located in the rear engine compartment on the pass side over the battery. It is held in by 3 clips.
    Apr 04, 2009 | 2005 Mercedes-Benz C-Class
    Looking for the air filter to replace it
    look for a round plastic tubing leading from the motor. will be a large diameter. the end away from the motor should have a large black plastic box closed by either screws or clips.... remove those clips and you will find the filter.
    Robert
    Nov 12, 2008 | 2008 Volkswagen Rabbit
    Removing the back to change battery
    The plastic wrist band doesn't have to be cut away. You need to dislodge the spring-loaded end of the pin from the hole in the plastic with the blade of a sharp thin knife.
    The you proceed to lift one of the 4 snaps to open the cover. The battery is under a white translucent inside cover.
    The original battery was Sony SR621SW.
    Pay attention to the rubber seal ring when putting the watch back together.
    Jan 13, 2008 | Casio MQ24-7B2 Wrist Watch
    Motor overheating
    There is a filter on top of the motor as well. You will need to remove the plastic cover on top of the motor with a small screwdriver or other flat blade. On the front, you push in the clip and pull up ont he cover. On each side of the cover there is another clip - to pop those you put your flat blade into the angled tab and slide it around to the clip until it pops. Gently or you'll break the tab. Once the cover is off there is a purple tab in the center pull up and you will pull the HEPA motor filter out - similar in shape and size to the side, washable, filters. Clean or replace that.
    May 27, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    Mtd 22" Yard Machine Push Mower Logo
    115 people viewed this question
    Top Mtd Garden Experts
    Roland W VanLue
    Roland W VanLue
    Tim Whalen
    Phil Walker
    Phil Walker
    Are you a Mtd Garden Expert? Answer questions, earn points and help others
