Question about Aqua Flo Flomaster 1.5 H.P. 2 Speed Fmhp without Trap 120v Pump
Wiring a new pump but the wires are different colors
The new wires are yellow and black can you tell me which is live which is neutral
  • 3,600 Answers
Neutral should be white. To be sure pull the cover plate off the *********** of the motor on the back side of the plate it will have the wires color coded for which wire is neutral and which is hot. Normally Black would be hot and the yellow wire could be second speed so if you look on the plate on the new motor you will be able to see the wiring diagram. This is assumeing it is a 110 Volt motor single phase.
Posted on May 28, 2010
Which is the hot wire color
see if this helps you out.
The protective ground is green or green with yellow stripe. The neutral is white, the hot (live or active) single phase wires are black , and red in the case of a second active. Three-phase lines are red, black, and blue.
Wiring Color Codes : Color Codes - Electronics Textbook
www.allaboutcircuits.com/textbook/reference/chpt-2/wiring-color-codes/
or go to this link.
Which is the hot wire color Google Search
Dec 22, 2016 | Electrical Supplies
Hi guys just wanting to know if you can tell me how to hook up power cord to bench grinder it is single phased .
the red wire (power--active-- wire) goes to one side of the switch
the other side will be red wire (power --active --wire) to the motor
the black wire is the neutral wire and will join directly to the black wire from the motor
the green/ yellow striped wire (ground /earth wire is screwed directly to the metal body of the grinder
IN some countries there are different color codes for active, neutral wires so get an electrician in to be safe
Jan 09, 2016 | Bench Grinders
Can some one tell me where the earth wires go and the rest of the plugs on a fisher and paykel washing machine mw511
If you are not sure of the wiring contact an electrician!
Connect each wire to the correct terminal. Slacken the screw and push the bare wire into the hole. Re-tighten the screw. Make sure the terminals are tight and that there is no bare wires or loose strands of wire showing. It is often easier to push the pins up slightly when connecting the wires.
  • Brown - Live
  • Blue - Neutral
  • Yellow and green - Earth
Older appliances may have different colours:
  • Red - Live
  • Black - Neutral
  • Green - Earth
Nov 23, 2014 | Fisher and Paykel Washing Machines
Need color code on new connector
Just did my fuel pump on the 2001 isuzu rodeo. Well here is what you need to do about the different wire colors. First disconnect your negative battery. Drop the fuel tank and replace pump. Remember to have a splice kit in hand. Ok now here is how you connect the different colored wires. Black goes with black. Gray goes with black and orange wire. Purple goes wit blue and yellow. And the last wires goes together. I hope this helps.
Aug 12, 2012 | 2001 Isuzu Rodeo
My terim cooker has 3 wires - black, blue and brown. Do you know which is live, negative and earth?
green or green and yellow is the ground (earth), blue is neutral, black and brown are both lives. this is the standard european wire color code since 2004. If it is older than that, black was used as a neutral, and blue as a live. very confusing.
Jul 21, 2011 | Ovens
Breaker keeps tripping when turning on pump.
The red and black wires if ran correctly are the load lines(power). The white is neutral or ground. If its a 1/2 to1-1/2 hp motor connect the red and black wires to terminals #1 and #4. If its 2 hp use #1 and #4. If its 3 hp use #2 and #4. Connect the white wire to the green colored screw. A grounding conductor should always be connected under the green grounding screw, which is located within the terminal compartment of the motor. You can check the breaker for the wire colors, one should be black and the other red. The white wire should be terminated to the neutral/ground bar in the can.
May 16, 2010 | AO Smith 1 HP 115/230V 56C Replacement...
New water pump isn't working. There were 3 wires connected to my old water pump (red, green with yellow stripe, and black). That old pump has apparently been replaced with this part number (AP3160348) and...
lucky that the machine is plastic or you would be getting a shock
red wire is active , black wire is neutral and the green with yellow is ground
all of the wires have a color code for a purpose and must all be connected correctly
connect the pump correctly and the fault will dissapear
May 12, 2017 | GE Profile WPRE6100G Top Load Washer
Need to know what the pink and yellow wires are in computer cables is one earth other live
Here are the wire Color code for AC primary side;
US: Black = HOT/LINE, White = Neutral, Green or Green with Yellow stripe = Earth ground/safety ground.
Euro: Brown = Hot/Line, Blue = Neutral, Green with Yellow stripe = Earth Ground/Safety ground.
Feb 12, 2010 | Mass Multimedia Open Box C3H TRIPLE...
Wiring/connecting wire from fan to home ceiling
this depends on where you live UK/USA et,c or other.
It is best to search the manufacturers site, to find installation codes/colours.
i.e USA use a lot Of Black and white. UK uses Red/Black Green/yellow.
And on houses that are rewired to 17th edition electrics ( UK ) the colours have now changed on mains twin and earth household Wiring. What Used to Be Red ( Live ) Is Now Brown. Black ( Nuetral ) Is now Blue. green/yellow is earth.
*** Important Note:- you should have several reds in a ceiling junction box or light fitting, these are circuit wires. ( Live From Light to next light ) The same as with Black ( Nuetral )
There will usually be 1 switch wire/Cable. this feeds a live from the switch, to the live power up to the light. many homes use a twin core and earth, from the light switch to the fitting. this may be black ( if a black/red ) has been used. *** Do not connect a black Switch wire with the remaining neutrals***
This will blow a fuse or trip a breaker.
Your solution:- connect the black neutral To the Black neutral cables ( more Than 1 at the ceiling Rose/fitting ) if there is a green/yellow or green ( this will be earth ) You may have 2 remaining Colours Possibly red and Blue or other. The Red Should be the switched Live. ( the single cable Red/Black with red tape around It ) This will be the switched Live. The remaining cable would probably be connected to the Bunch of Reds ( Constant Live ) As ceiling fans require a constant and switched live ( if the fan has lighting )
If in any doubt, consult a qualified or competant Electrician. *****And always remove or isolate the mains supply before attempting any installation*****. After the wiring is complete replace the fuse or switch on the breaker, to test your installation.
This information, is supplied by a fully competant electrician.
Thankyou for using fixya.
Mike @ Compurepair.
Jun 15, 2009 | Hampton Bay 24002 Ceiling Fan
Power cord wiring, what is each color?
Your asking about the end that goes into the wall correct?
99% of the line cords I have seen (in the US) Have a green, white, and black wire where:
Black = Hot
White = Neutral
Green =Ground
I would suggest you use a multimeter to find which wire does what without checking it directly I would need More specifics about the laptop/power supply
Feb 20, 2009 | Computers & Internet
Aqua Flo Flomaster 1.5 H.P. 2 Speed Fmhp without Trap 120v Pump Logo
345 people viewed this question
Top Aqua Flo Pool & Spa Experts
Ian Kime
Ian Kime
Bill Jordan
David Spradling
David Spradling
Are you an Aqua Flo Pool and Spa Expert? Answer questions, earn points and help others
