Question about KitchenAid KBFA25ER Bottom Freezer French Door Refrigerator
Freezer won't stay at 0 degrees
I keep setting it and the freezer is full of ice and temp will go up to 13. how do I keep freezer free of ice crystals all over food?
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Posted on Feb 18, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Freezer temp increased slowly;ice cream/ice will not freeze
If the repairman is experienced the problem will be resolved. I have recharged refrigerators myself and it is difficult, time consuming ad tedious. Sorry the work needs to be done in your home. If he does not know what he is doing he will cause problems and make excuses for why the refrigerator does not work correctly. Hope you have the best service available for your area. Sea Breeze
Posted on Mar 27, 2009
aasc
  • 1606 Answers
SOURCE: My freezer temp registers 28 - 36, I cleaned out
That fan behind the refrig , is the fan that cools the compressor . It should be running any time the compressor runs . If not running , replace it . The center divider between the fridge and freezer ( front strip ) should be getting hot to the touch if the fan is not running .
Posted on Sep 12, 2009
  • 10865 Answers
SOURCE: Freezer seems to be working properly, but fridge cant keep temp
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Posted on Mar 25, 2010
guru_fixya
  • 944 Answers
SOURCE: oh my we had
Your temperature control board is the problem.It controls the temperature settings in the Refrigerators.Since you say power flickered.This is the obvious cause for the temperature control borad to be defective.Sudden high or low signal to the board will cause the resistors to break of it will make capacitors to be defective.You have to do continuity testing on the board to find out the exact resistors or capacitors or transistors to be replace.
Some time the fuse may also create this problem it is also soldered on the board.
Note:Sometimes switching it off for 8 hours more will solve the problem because if it is defrost issue and system takes time to defrost the Refrigerators.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 15, 2010
What does the temp display on the freezer tell me?
unless this is a dedicated freezer only and not a side by side or over/under , there's no way it's going to get down too 0 degrees inside a warm home , nope not gonna happen
also its not good for you to set this there as compressor wont cycle properly there and entire freezer will ice up , then believe it or not it will get warmer not colder wastes a lot of power as well
Sep 10, 2015 | Freezers
Leibherr freezer icing up and not staying at right temp
Probably the heating element in the defroster is not working
Mar 30, 2013 | Refrigerators
Have upright frost free freezer alarm is going off about once or twice a day.Put a thermometer it is around 20 degrees I mute the al;arm and it beeps again and again after several hours. looked to clean...
Hi most deep freezers operate at 0 dergrees. your model may have 2 temp zones. 0 or 20 deg.I'm gessind that your sensor is going off when the defroster is on to melt ice (defrosting). Lower the setting. monitor and repeat as needed. if it continues you may need to replace the unit or ad freon. If the unit is over 13 years ge a new one.
Jul 21, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
Refrigerator keeps freezing. Temp stays at about 28 degrees. temp control on door (digital) and no matter how much you turn it up, temp stays below 30. Repair man came out and said seal was bad on...
Most likely one or both of the thermistors are bad. Usually pretty easy to find behind a vented cover about 2" X 1" on the side walls of the refrigerator and the top of freezer (if freezer is on the bottom of the unit)
May 31, 2011 | Refrigerators
Frige is cold, freezer is cold & freezing . . . Ice maker not making ICE.
Hi: As we don't (as in I) know the actual temp. in the freezer, this is a simple and free try. Cold is cold. The temp in the freezer has to be 0 degrees to make ice. They are thermally protected. A good guess for temp. is your ice cream. Is it rock hard? A lot of refrigerator thermometers are inaccurate. Just try setting your freezer colder. Ignore human nature and don't check the freezer every 30 Min's. You will never get to 0 degrees. I hope this helps, Jeff
May 31, 2009 | Refrigerators
Freezer temp
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} hi!! we have read your problem..every problem has a solution.the temp depends upon your need.if you are using stronly freezers for storing food items like meat, then you can set the temperature to (0-10) degree celsius. else you can set it to (5-15) degrees.always keep the liquid items closed in the refrigerator failing to which it causes crystals.it also costs dearer since you have to defrost then. so always keep your food items covered.hope your problem is tackled..have a nice day
May 22, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
GE Profile Artica refrig is freezing food
Replace the cold control
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Refrigerators
Freezer tempature
Depends on the product you want to keep in the freezer. Usually you want to try and stay between 0 and +10 degrees for most items. Ice Cream must be -10 degrees minimum. Any warmer and it won't keep. Hope this helps.
Good Luck
Dec 24, 2008 | Nor-Lake Freezer Norlake Refrigeration 6'...
Water dripping in Freezer leaving ice all over food
need a new ice maker for the leak but the temp is another thing
Nov 29, 2008 | GE GSS20IEP Side by Side Refrigerator
KitchenAid KBFA25ER Bottom Freezer French Door Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
