Question about Toshiba REGZA 47HL167 TV
How to remove tbl stand from toshiba tv - Toshiba REGZA 47HL167 TV
  • 10,594 Answers
Usually table stand fixing/ removal is written in related user manual of tv, please check user manual of tv, if you need more info, let me know tv model number of your tv.
Thanks.
Posted on May 28, 2010
How do I operate fmdaw025 watch
Timberland Watches: Watch manuals
tbl-watches.com/en/watch-manuals.html
TBL.14323 DIXIVILLE S · TBL.14323 DIXIVILLE M · TBL.14322 MADBURY · TBL.14321 PINARDVILLE · TBL.14260 TUXBURY · TBL.14248 THETFORD ...
Instructions (English) ' SEIKO WATCH CORPORATION
Nov 29, 2015 | Watches
How do I remove the stand from a toshiba 32hl57 tv
  • 1 & 2 Remove all cables and lay down towels on a clear space.
  • 3 Set the 32HL57, screen side down, onto the towels gently.
  • 4 Locate the four screws at the bottom center of the TV. These screws attach the stand to the Toshiba 32HL57.
  • 5 Using the Phillips screwdriver, unscrew all four screws, one at a time.
  • 6 Once the screws are completely removed, grab the base of the stand and gently pull away from the TV.
  • Read more : http://www.ehow.com/how_7318172_remove-stand-toshiba-32hl57.html
    Jan 20, 2015 | Toshiba Televison & Video
    Remove stand on Toshiba TV
    To disassemble it, you have to see some illustrations. If you wish to get more details about how to disassemble Toshiba TV, check this link. http://electronicshelponline.blogspot.com/ Pull up older posts there. Disassemble procedure to many TVs are given in detail, with illustrations.
    Jun 13, 2013 | Toshiba REGZA 47HL167 TV
    What size bolts attach tv to stand for Toshiba 37"
    You will use the bolts that you take out to remove the base from the tv.
    Mar 21, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
    How do I remove the stand from a Toshiba TV 19DV616DB
    Mine isn't exactly the same model (I've a Toshiba Regza 32AV615DB) but on mine there are 4 small black screws at the back of the TV, near the lower edge. They're recessed into channels and quite difficult to see. Remove these 4 screws and you can lift the TV off the stand. Good luck.
    Jan 15, 2010 | Toshiba REGZA 47HL167 TV
    How to remove tv stand from toshiba 42 inch lcd model 42hl167
    Remove 5 screws as shown in below image to remove stand of TV.
    It is also mentioned in user manual of TV page-5, click Toshiba Support to download a copy, if required.
    Thanks.
    Aug 30, 2009 | Televison & Video
    Taking stand off toshiba regza tv
    forget the four holes on the bottom of the stand. Remove the five allen bolts on the back bottom of the tv-not the stand. Yank on stand and metal plate slides out with stand.
    Jan 25, 2009 | Toshiba REGZA 47HL167 TV
    Question on toshiba tv - fixya post
    Found this on the www.Toshiba.com website. Q. How do you remove the stand?
    Models: 26HL37, 26HL47, 32HL17, 37HL17, 42HL17, 32HL37, 26HL67, 32HL67, 37HL67, 42HL167, 42HL67,
    47HL167, 52HL167, 42LX177, 46LX177, 52LX177, 57LX177
    REF:FAQLCD00078
    1. Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand
    protruding over the edge of the surface. NOTE: Extreme care should always be used when removing the pedestal
    stand to avoid damage to the LCD panel.
    2. Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can
    be removed without tools.
    3. Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
    4. Once you have removed the five screws holding the pedestal stand in place, remove the stand from the TV by
    sliding the stand away from the TV. The Toshiba customer service number is 1-800-631-3811. Hope this helps you with your problem.
    Dec 22, 2008 | Toshiba 42HL167 42 in. LCD Television
    Removal of stand
    There are 5 screws in the back of the TV, immediately above the stand. From the stand, they are at the 10:00, 11:00, 12:00, 1:00, and 2:00 locations. If you remove the screw, and find a washer with the screw, then it's probably the right one. Once all 5 screws are removed, the stand slides right off the bottom. Unfortunately, once the stand is removed, the opening is left in the bottom. It's not too bad since once it's mounted to the wall, it's not high enough to see the bottom of the TV anyway. Good luck!
    Aug 09, 2008 | Toshiba REGZA 47HL167 TV
    Stand
    How do I remove the stand?
    Apr 13, 2008 | Toshiba Televison & Video
    Toshiba REGZA 47HL167 TV Logo
    974 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
