Question about Ic Verify ICVERIFY 3.1
ICverify 3.1 won't open.
A window opens that says this: ID error = 0
Then another window opens that says cannot get information and to check the set file. I replaced the setup file with a backup but still cannot get the program to open.
  • 4 Answers
The issue is caused by a Microsoft Jet update. in c:\icwin310\backup directory you will find the files needed by icverify. Make a backup of the following files in c:\windows\system32 msjet35.dll
msjint35.dll
msjter35.dll
msrd2x35.dll
msxbse35.dll
msexcl35.dll
msltus35.dll
vbajet32.dll
vbar332.dll
Copy the files listed from the c:\icwin310\backup directory to c:\windows\system32 and your error should be no more.
Posted on Aug 15, 2010
2 Suggested Answers
  • 4 Answers
SOURCE: ID error = 0
the issue is caused by a Microsoft Jet update. in c:\icwin310\backup directory you will find the files needed by icverify. Make a backup of the following files in c:\windows\system32 msjet35.dll
msjint35.dll
msjter35.dll
msrd2x35.dll
msxbse35.dll
msexcl35.dll
msltus35.dll
vbajet32.dll
vbar332.dll
Driver side power window not working
can be 3 things. (4)
1: bad wiring, connections,, not a fuse that would kill others.
2: bad switch.
3: bad window motor.
4: window frame jamming.
the tests are simple and in the FSM (factory service manual).
factory FSM
Alldata online
mitchells online
others.
in short, using a meter finds this easy.
using meter you can check the voltage to the motor.
and current.
if the voltage is good an current 0 , motor is open
of the voltage is low and current excessive the motor is shorted.
if the voltage is 0 and no current the switch or wires are open.
is that what you seek or just a wild guess.
if the latter, id say, rolling dice,,, wire fell of switch.
Apr 06, 2013 | 2004 Suzuki Verona
Tip
Error messages when you try to install Windows XP Service Pack 3
When you try to install Windows XP Service Pack 3 (SP3), you may receive the following error message:
An internal error occurred
After you click OK in the error message, you receive the following error message:
Service Pack 3 installation did not complete
Additionally, you may see the following errors that are logged in the C :\Windows\Svcpack.log file: 165.672: An internal error occurred.
165.672: Service Pack 3 installation did not complete.
165.672: Update.exe extended error code = 0x1ffe054f
165.672: Update.exe return code was masked to 0x643 for MSI custom action compliance
Note Throughout this article, the C :\Windows folder represents the folder where Windows XP is typically installed.
CAUSE
The errors that are mentioned in the "Symptoms" section can occur because of files that are not trusted or because of corrupted registry keys. You can verify the cause by searching for related entries in the Svcpack.log file. Specific entries will identify specific causes of the issue, as noted in the following "Cause" sections.
Cause 1
Determine whether the following entries are logged in the Svcpack.log file: 142.391: CheckVLKForBlock: LIC.dll not trust verified
142.578: Trying CheckVLKForBlock again
142.594: CheckVLKForBlock: LIC.dll not trust verified
142.594: Error: CheckVLKForBlock failed
These entries indicate that the cause of the issue is the Licdll.dll file. The Licdll.dll file may have been altered, is corrupted, or is not trusted. The Licdll.dll file is located in the following folder:
C :\Windows\System32\
Cause 2
Determine whether the following entries are logged in the Svcpack.log file: 211.890: IsSPBetaKey:pLA->lpVtbl->GetProductID Failed: 0x80004005
213.125: Trying CheckVLKForBlock again
214.468: Error: CheckVLKForBlock failed
These entries indicate that incorrect product ID information in the registry is causing the issue.
Cause 3
Determine whether the following entries are logged in the Svcpack.log file: 299.031: Trying CheckVLKForBlock again
299.531: Error: CheckVLKForBlock failed
These entries indicate that corrupted or altered registry keys in preinstalled programs are causing the issue. Note One program that is known to cause this issue is Micrografx - Picture Publisher Professional 10. To work around this issue, see the "Workaround for Cause 3" section.
RESOLUTION
To resolve or to work around these causes, use the resolution or the workaround that corresponds to the cause.
Resolution for Cause 1
To resolve this issue, you must replace the current copy of the Licdll.dll file by using a copy from the original Windows XP media. To do this, follow these steps: 1. Insert the Windows XP CD into the CD drive.
2. Click Exit on the Setup Wizard as soon as it starts.
3. Click Start , and then click Run .
4. Copy and then paste (or type) the following command in the Open box, and then press ENTER:
explorer
5. Click My Computer .
6. Note the drive letter that contains the Windows XP CD.
7. Click Start , and then click Run .
8. Copy and then paste (or type) the following command in the Open box, and then press ENTER:
cmd
9. Type or copy and paste the following text into the Command Prompt window, and then press ENTER:
Expand CD_Drive_Letter :\i386\licdll.dl_ C :\Windows\system32\Licdll.dll
Note In the command in step 9, replace CD_Drive_Letter by using the actual drive letter for the drive that you noted in step 6.
10. To install Windows XP SP3, visit the following Microsoft Windows Update Web site:
http://windowsupdate.microsoft.com Resolution for Cause 2
To resolve this issue, you must replace the incorrect product ID registry entry with the correct product ID. To do this, follow the steps in the "Locate and note the product ID" and "Identify and change the product ID registry entry" sections.
1. Click Start , and then click Run .
2. Copy and then paste (or type) the following command in the Open box, and then press ENTER:
sysdm.cpl
3. On the General tab locate the product ID. The product ID is the 20 digit number that is located under the Registered to section.
4. Note the product ID for use in the "Identify and change the product ID registry entry" section. Identify and change the product ID registry entry
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 How to back up and restore the registry in Windows
regedit
3. Locate and then click the registry subkey that resembles the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\WPA\Key- XXXXXXXXXXXXXXXXXXXXX
Note The series of Xs represent a placeholder for a string of 21 characters.
4. There may be several subkeys that resemble the format in step 3. To determine the correct subkey, follow these steps: a. Click each subkey in the navigation pane.
b. In the details pane, compare the value of the string for the ProductID registry entry under the Data column to the number that you noted in step 4 in the "Locate and note the product ID" section.
c. The registry subkey whose ProductID registry entry value matches the number that you noted in the "Locate the product ID" section is the registry subkey that you want.
5. In the navigation pane, right-click the registry subkey that you identified in step 4c, and then click Export .
6. Save the registry subkey to the Desktop as temp.reg .
7. Right-click the temp.reg file on the Desktop, and then click Open With .
8. Click Notepad , and then click OK .
9. In the open temp.reg file, locate the following text:
[HKEY_LOCAL_MACHINE\SYSTEM\WPA\Key- XXXXXXXXXXXXXXXXXXXXX ]
10. Replace the text that is mentioned in step 9 by using the following text:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion]
11. Click File , click Save , and then exit Notepad.
12. Double-click the temp.reg file, click Yes in the dialog box when you are prompted to add the information to the registry, and then click OK .
13. To install Windows XP SP3, visit the following Microsoft Windows Update Web site:
http://windowsupdate.microsoft.com Resolution for Cause 3
To resolve this issue, you must delete the InprocServer32 registry subkey. To do this, follow these steps: 1. Click Start , and then click Run .
regedit
HKEY_CLASSES_ROOT\CLSID\{00020420-0000-0000-C000-000000000046}\InprocServer32
4. Click InprocServer32 . A string value with the name InprocServer32 is displayed in the details pane. Click this value.
5. On the Edit menu, click Delete , and then click Yes .
6. Exit Registry Editor.
7. To install Windows XP SP3, visit the following Microsoft Windows Update Web site:
on May 03, 2010 | Computers & Internet
I cant open my orkut ANDYAHOO home page in google chrome browser.
Clear the cache memory of Internet explorer or Firefox and then try to use the link.
Jul 06, 2010 | Microsoft Windows XP Professional With...
ID error = 0
msjint35.dll
msjter35.dll
msrd2x35.dll
msxbse35.dll
msexcl35.dll
msltus35.dll
vbajet32.dll
vbar332.dll
May 28, 2010 | Ic Verify ICVERIFY 3.1
My computer with Windows XP Pro SP2 is crashing often, after i had connected a hdd with my computer ============ CPU-Z TXT Report Processors...
probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/hdd..
..plz do check the following as in order:..
the Hardware part:..
1)see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
2) 4) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
3)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
4) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
5) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)....
the Software part:..
1) hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky,remember, without updation a full version antivirus is useless)..
2) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
3) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove all the unnecessary startup items from here..(if u can't find what to remove, post me/us in ur comment with all the items listed in each n every tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
6)disable the following:..
a) 'Automatically Restart' right click on my computer->properties->advanced->startup n recovery->(uncheck on the) Automatically Restart;
b)'Error Reporting' right click on my computer->properties->advanced->error reporting->disable error reporting->(uncheck on the) 'but notify me when critical error occur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
if u r bot a professional, always better to seek advise from ur system admin/vendor....
Nov 13, 2009 | Asrock K8NF4G-SATA2 Motherboard
Webpage error details when i open streaming video
When exactly are you getting this error message? Which website you want to browse to?
Steps to try:
1. Download and install Flash Player ActiveX control for your Internet Browser.
2. Make sure that you have the latest version of Java installed.
3. Restore your Internet Explorer 8 to the default settings.
4. Check for any updates available for your Windows and Internet Explorer.
5. Try using some other browser such as Mozilla Firefox, Google Crome and/or Opera and check if the website loads correctly?
Oct 30, 2009 | Microsoft Internet Explorer 8
ERROR IN COUNTER STRIKE GAME IN WINDOWS VISTA
before you run the game right click the icon that launches it and goto properties, goto compatibility tab, check the boxes run in compatibily with xp sp2 and check the box to run as administrator, click apply ok then run the program.
Jan 18, 2009 | Microsoft Windows Vista Home Premium with...
Error in IE on windows Vista
if you open the website and your IE crash, don't open again. try windows update, maybe there is an update for your IE. Otherwise using mozilla firefox
Feb 20, 2008 | Microsoft Windows Vista Ultimate Edition
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
Ic Verify ICVERIFY 3.1 Logo
210 people viewed this question
Top Ic Verify Computers & Internet Experts
David Payne
David Payne
Are you an Ic Verify Computer and Internet Expert? Answer questions, earn points and help others
